Visitor Agreement.
Bilsteins will help with leaning, or at least in swaying back and forth. However, you will get more help from a rear anti-sway bar.
Hellwig has a bar and you can buy it many places, including JC Whitney.
And we have two characteristics most owners will be looking for. Better ride. Better control.
One owner wants firmer control when towing and hauling, so he chooses Bilstein.
Another owner wants a more compliant ride in his daily driver, so he also chooses Bilstein.
Other owners likewise choose Edelbrock for the same reasons.
The point is, we really don't have many choices. Many of us will choose one or the other, looking for exactly the opposite characteristic that another is buying the same shock for.
As soon as the Bilsteins are on the market, count me in for "yellow". (only 5 more days left on the Edelbrock rebate . . .)
The Bilstein valving I think is less complex. The difference is in the execution. I owned Bilsteins before, and it was the longest lasting, best shock ever, but was stiff.
Does anyone know the diameter of the Edelbrock or Bilstein. The stock Z85 is 36 mm, the Z71 is 46 mm. If a Bilstein was any smaller than the Z71 spec, the question I would have is for its durability over the life of the shock. I would have the same question for the Edelbrock also.
website: http://www.bilstein.com/index2.html
The shocks are not yet available for the new Silverado's/Sierra's; but they are supposed to be available on the 1st of Sept. I already have mine on order and the will be shipped from Bilstein as soon as they are available.
Mike
I would guess they also have shocks for 2wd but I never asked about them.
In another 1-2 weeks I should have my shocks and then I can find out if the Bilsteins are worth the money or not.
Mike
Front BE5-2902
Rear BE5-2903
Also - has anyone looked into the Rancho RSX series stuff yet - sounds like an Edelbrock clone; "smart" inertial valve thing - not available for 2wd GM's until Dec '99
I ordered a Hellwig from JC Whitney. $135 + 15 s/h.
Should be here next week.
Mike
Mike
If you're carrying a slide-in truck camper on a 3/4 ton truck camper, you're probably getting some pretty significant rear end squatting. Better shocks will help with some of the sway, but they are not likely to help lift the rear end. With the rear end sitting back, you're not going to have the best handling since the truck was not built to drive that way. There are other safety issues such as braking. If you're getting a significant squat, you may want to look into airbags aka airlifts to level the truck out. They are pretty common on trucks that haul slide-in campers, especially if you don't have a dually.
You can find some additional info on shocks and air bags for towing at www.happycampers.net. Go into the Chat area and you can search by a topic.
They are not harsh, but have good control. The control is better than the Z71 shocks I took off.
And they are currently $50-60. Much better than the Edelbrocks.
Mike
I've said this before, but it's a case of new concept for the Edel vs fine execution for the Bilstein. Love to hear from some one with the Edels too.
About the ride height?
Mike
Eric16
Mike
Mark
I've got a small camper on my truck, and I am right at 6500lbs vs. GVWR of 6400lbs. So I am harder on shocks than most people.
I put 16,000 miles on the Tenneco's and they are not bad. The Bilsteins are just a little better for a fully loaded truck.
Mike
I wonder if you wouldn't get the best of both worlds by putting the Edelbrocks on the front, for the best ride, and the Bilsteins on the rear, for the best load control?
Aren't Tenneco the same as Monroe?
Still taking a ddeepp breath befor buying 6 shocks for my Bronco.
I would like to know how they ride on the new Silverado?
Better off road manners for the Belsteins.
Around $60 ea.
Mike
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
