JAC
Did you use the Mopar kit?
How was the installation?
All went well until I went to install the wiring pigtail into the 26-way C-5 wire plug bundle. The sockets that the instruction state I should plug into ALREADY have wires in them. Now I an stuck as to what to do or where to seek help. The dealer would be the last resort.
Any ideas ?
I have seen bundles taken by just the wire the dealer has going TO where the fog lights should be, so that you can just plug the light straight in there.
Best of luck.....
The kit comes with a replacement factory light control stalk which has the foglight control included. You are supposed to swap it with the one on the steering wheel column in the car. To get it to function I need to hook the wiring up per the instructions.
Need to figure out a way to determine what the wires that are already in the designated slots are for.
Ive never hooked up the new stalk.......
All's well that ends well.
Now I just have to worry about how long before the tranny acts up like all the others.
Has anyone installed the old-style receiver on a new Pacifica?
Has anyone seen the adapters for this 'new' style receiver?
Specifically, is there an adapter which converts this to a typical 2" receiver, or are the various adapters strictly 90 degree drawbars?
The dealer seems aware that the new hitch is different, but unfamiliar with the adapters (how to use the damn thing).
Lets all try and post pics of your rides in your profiles, Lets see what you guys are doing......
if you have an extra set of wiring harness for fog light i can purchase it from you.i added the auto headlight switch to mine with the fog light option on the stalk and bought the aftermarket for lights but i could not find the little clips that is going to hold in the 26 way connector.i do not want to pay $120 for a set where i only need a harness.if anyone has a spare wiring harness for an OEM fog light please let me know.and i am not sure if it is same with 07 s but mine is an 05 touring if you don't have the auto headlight you could just get a stalk with the auto headlight option and a rearview mirror with autodim option you could have auto headlights as well.i love that option.if you need a part number for the stalk with both options let me know.this stalk has both auto hedlight and fog light like the limiteds do.they should be about $50 at the Stealership.
My fiance' and I just bought a used 2004 Pacifica that came with just a cd, am/fm player. I want to upgrade my system so I bought a ceiling mount screen with dvd player. My problem is that I want to connect the audio to the existing factory stereo. Can this be done? If so Do I need to add any other wiring harnesses or anything? Also I wanted to know if I have a factory amplifier because I wanted to install an aftermarket amplifier and subwoofer. Please help.
And I sure will take pics to share.
What are you trying to mount? the amps? subs? or the dvd player?
Are you installing the dvd type that goes on the ceiling? or what? describe the setup you have.....
Can you imagine? You must take the cover off if you get caught in the rain or if you wish to wash the vehicle.
I've requested a RMA number from Wyckoff to try and get a refund ............. and have already ordered a LeBra replacement.
I might add at half the price ( $130 versus $66. )
I have one site that says it will and another that says they are definitely not the same.
My 2007 pac does not have the harness for the overhead consols and I want to add some of the extra features (Homelink) I bought the console off ebay and I expect the wiring to be similar.
ezpar722@yahoo.com
I haven't tested it yet, but from what I understand it should work. I will know soon.
You can't use the changer because your radio controlled it. Too bad they don't make a controller just for the changer.
totallywirednyc@yahoo.com
email_me@totallywired.info
1 - X114 20GY/TN - FUSED B(+)
2 - X211 20YL/GY - IGNITION RUN/ACC SIGNAL
3--
4--
5 - X915 22GY/LB - VIDEO CONTROL
6 - X515 22GY/OR - VIDEO SIGNAL
7 - X530 20GY/DB - VIDEO RETURN
8--
9 - X555 22VT/OR - VIDEO PLAY SIGNAL
10--
11--
12 - X955 22 - SHIELD
You can get the systems and everything at Best Buy, ordered by vehicle and also interior color.
I have a 2005 Pacifica that does not have the clock. I was able to pick one up, including the bezel, and would like to install it.
Before tackling getting the existing bezel out-which does not appear to be easy-I am looking to find out if anyone here knows if there are wiring accommodations for the unit? The digital clock on the radio is just too small and down more than I would like it to be.
Thanks in advance for any and all info.
Bob
I am assuming these are the headphones I need to get to work with the system. I have a screen that I am hard-wiring in to the harness, so the video problem is solved. Question is, if I pick up the remote and these HB75's, will I have a working system? Are these the right headphones? I ask because I've heard of others buying them and find out they don't work.
Thanks in advance!
