Brake rotors and fan belts
While on a service visit at the dealership for my 1999 BMW 328i (manual shifter, Sport Pkg), I was told that I should soon replace the brake rotors (together with the pads) and the fan belts. The car has 29,000 miles and is driven mostly in town, commuting. I don't consider myself an aggressive driver. I can understand the brake pads, but I am not sure about the rotors and the belts, given the relatively low milage. Is this work likely to be necessary, or is it just a way for the dealership to make more money?
Any way to tell for sure?
Are they:
1. warped? How did they determine this? (dial gauge, also called "run-out" guage).
2. out of spec? If so, what is the thickness measurement of the current rotors on your car versus the factory minimum?
3. Severely grooved? (show me please)
As for the belts, you can ask why also:
Are they:
1.Conspicuously cracked?
2. Shredding?
3. glazed from slipping?
So ask for measurements on the rotors or visual evidence on the belts. If the shop can't give you either, go somewhere else where they don't recommend repairs based on using a dartboard in the office.
However, brakes do not just age.
Your mileage sounds alarmingly low for a 4-5 year old car. With mostly city driving, and a likely average of 400-700 miles a month, you are likely doing a lot of stopping and too little driving, so you just might have lost your brakes (though your mention of manual tranny makes that less likely).
Second opinions definitely.
ksso
As for my locale, I do live in Central Florida, which is known for hot and humid weather. This could explain the belts, but not the rotors.
I bought the car new and always pampered it: the dealership's advice does sound perplexing to me.
Thanks to all for the advice.
Of course, I'm a big fan of preventive maintenance. As Confucius say: "Journey of one thousand miles begins with broken fan belt".
If I were to replace the rotors, who has the best ones? I thought maybe cross drilled and slotted would be best but don't know what brand is best.
They also told me that the pads AND rotors need to be replaced. About 2 weeks later the brake light did come on so they were right about that. FWIW, there's no need to replace the pads early and you have awhile even after the brake light comes on.
I'm going to shop around on the brake job. I did ask the questions and was told that the rotors were undersized due to wear. I sincerely doubt that. The rep is probably recommending this because it is "non-optimal" for performance and BMW could be liable otherwise (that is just my personal opinion). I had this happen to me once before (on another vehicle) and went somewhere else, had the pads replaced and drove for another 50K with no issues. I plan to do the same here. It really can't hurt much. Replacing the pads should be less than $150 so I guess the worst case scenario is that new pads won't work well and end up warping the rotors (due to being undersized). What's the fix? New pads and rotors. Seems like the risk of losing $150 (i think it will be less) is worth avoiding just getting everything done for around $600.
I'm looking for a qualified service center now. I don't want to get this done at Pep Boys or something foolish like that. I'm also looking for pad recommendations. I have the 323si so any advice would be great!
I know pads normally have those little wear indicators on them that let out a horrendous shriek when you're getting close, although I've also learned not to get too dependent on those!
