Sly
-- Ditto. I love my VDC. Well worth the extra $, especially if you consider it over the length of the entire ownership period.
With respect to gas mileage, I agree 100%. I think it's great for this type of vehicle. Premium gas is absolutely required to avoid rough idle, etc. The 93 octane Shell is the best.
I do admit my driving is probably not that conducive to good MPG, but it hasn't changed from when I was getting 19.1 miles to the gallon. My DH doesn't drive the car, but once he was with me on the highway and he said it smelled funny, like a brake was stuck. Then the smell went away. I can't smell anything because I am constantly stuffed up from allergies. I am going to make an appointment at Subaru to get an oil change and have them see if there is anything up with the brakes. It does kind of worry me that my MPG is so low. As of today it was 17.1.
Besides my gas mileage woes, I love the car.
Good luck!
Ken in Seattle
While I don't have an LL Bean model, from your narrative, I think you might've outlined a pretty good "recipe" for why your gas mileage isn't optimum.
1) It's winter: If VT uses oxygenated fuel (to reduce emissions) during cold weather, knock 2-3 MPG off your mileage for that.
2) Snow tires: Most every snow tire I've run across has a more aggressive tread for the purpose of gripping snow/ice. This adds rolling resistance, and reduces gas mileage. How much? Only you can tell (given how/where you drive) by paying attention to your mileage after you swap back to your summer treads. I've seen probably a 1-2.5 MPG reduction with my snow tires.
3) Average speeds: Since your average speeds are less than highway speeds, your LL Bean is definitely not taking advantage of its higher gearing. Consequently, your gas mileage won't stray far from it's "City" mileage listing. With my XT's summer tires, I get probably around 18-20 MPG with pure "around town" driving, between 25-27 MPG when driving between 55-70 MPH, and between 22-24 MPG when driving over 70 MPH sustained (don't even ask about 85+...you won't like the answer!).
4) Miles on car: I don't believe you mentioned how many miles you have on your car, but if you've read any of the comments on this board Re: gas mileage specific to vehicle mileage, you'll see that nearly everyone on this board has reported substantially better gas mileage after their cars have had a chance to break-in, e.g., between 10k-20k miles. Again, I don't know how many miles you have on your car, so this may or may not pertain to you.
5) Driving style: I believe you said "I do admit my driving is probably not that conducive to good MPG"...I took that as: "I'm a little heavy on the pedal". This is one of the biggest mileage-killers you'll find on ANY car.
Keep in mind, each of the items above would add to the cumulative reduction in gas mileage! That's a lot of variables/factors, huh?
So, just from the information you've provided, I think you've probably also provided your own answer. Some variables are beyond your control (e.g., "Winter", "Snow tires", "Average speeds", "Mileage on Car") but those pertaining to "season" should change soon, as will your engine breaking-in if it hasn't already. One of the largest contributors is "Driving Style", which only you can change if the gas mileage is that important to you.
Hope that helps!
Rgds,
Tim G.
'05 OBXT - 5MT
11k miles and climbing
WR = weight reduction
The guy reporting this supposedly spoke directly to this SOJ guy.
Bob
Tim - Thanks for that long post. It was pretty helpful!
I'm not sure if VT uses oxygenated fuel or not. Is there a way to tell at the pumps? I have just over 7000 miles on my car so far. I got it in late August. I do drive on the interstate sometimes, but its never a long drive, so I dont think its enough to see an improvement in my gas mileage. (And I like to do over 70 alot!) You're right I need to change my driving style in order to get better MPG. I'm going to have a baby in November so maybe that will turn me into a more conservative driver? I can only hope! I'm not a crazy psycho driver, but I am not a slow one either. LOL. Oh well! Thanks very much for your post.
The other thing I noticed about my Outback a few weeks ago is that they must have damaged the back window when they installed it. I have a huge chip in the lower right corner, on the inside. You can't get to it from the inside or outside, because its covered my the frame of the car. So it must have been there since I purchased it, I just never noticed. I am going to see if they will replace this when I have my next service. I also got a letter saying they need to reprogram my "Manual" mode with new software, so I will have that done also.
Thanks again!
Kristen
You're slacking off, man! LOL
-juice
They have offered something like this before in Japan -- Car and Driver did a write up a few years ago:
"Further complicating things is the designation of our test car: Type RA Spec C. RA stands for "Rally Applicant." It's a car intended to go racing and is, therefore, stripped of luxuries such as a sound system of any kind, air conditioning, power windows, trunk trim, airbags, underbody coating, and other things—all in the name of weight reduction. It also has an adjustable center differential that can be locked from the cockpit and a roof vent that opens manually—as on rally racers. The hood and roof metal is thinner, and so is the car's glass. It has a quicker steering ratio."
I believe the US STi already has some weight reduction over the standard WRX, including thinner glass.
Craig
Craig
As far as Vermont gas goes, I get some of my best mileage out of the Rutland Shell station so my guess is that Vermont is treating gas the same as any other New England state. I regularly purchase gas in PA, NJ, NY, and VT.
Not sure how to post a picture on the forum, but if someone advises me... I will try and get a picture of the "chip" posted.
I am still suffering through the "jury-rigged" antenna connection. I have refused to go with the modulator because I know the direct antenna connection produces a better result. Eventually, they will get the plug made. That's what I get for buying a 2005 in July of 2004.
Craig
FJ-60
'05 Legacy GT Wgn Lmt 5MT
I purchased my VDC from a dealer in Bethlehem, PA. I split my time between PA and VT. The Lehigh Valley is not "VDC" country so I believe they actually got the car from the Washington DC area.
For oxygenated gas, I am sure that the gas has winter additives, otherwise it would not run well and potentially freeze. I just don't think VT's gas is any different (at least it does not seem to negatively affect mileage) than any other winter gas in the Northeast.
Is it jiggling like loose mechanical parts? Is it still there when you open the sunroof?
Ken
FJ60
Thanks for the info, khallock.
FJ60
I am due for the 15K oil change here shortly and will have the dealer take a look.
connectors"... I am trying to connect the sirius version of the commander... I have a brand new outback and assume I have the non standard connector... Help !! :-)
If you talk to Pete, ask him if my VDC adapter part is available yet?
Good Luck!
Craig
I am just learning about these radio problems
What is a vdc radio.. ??. I am guessing the OEM
Subaru Radio..??
Craig
Sly
will play.. I expect the penalty is not as much capacity as a standard mp3 disc and no ability to
index , sort or get any text information on the file
Sly
Bob
Is it me or did the review seem unfairly biased towards the BMW? Everything I've read about the xi has been less than flattering. Also, auto climate control and sunroof -- don't the other models provide this standard?
Ken
Pretty dumb to compare an Outback instead of the GT, really. The whole premise is faulty.
Compare Outback to an allroad or a XC70 instead.
-juice
The adapters have been available for several weeks at least. My earlier post with more details was deleted so I can't provide more info than that, unfortunately. Edmunds is not always the best place to discuss mods and solutions because we cannot link to external sites.
Craig
Let me know what happens?
