I'll happily take modern fuel injection and the starts-every-time-you-turn-the-key reliability, thanks very much!
-juice
Manual choke. My van had one of those, but I promptly removed it and installed an automatic choke on the carb. Sheesh - those things are bad enough on ATVs (though I imagine even newer ATVs have done away with them, right?).
-juice
-mike
So, I have figured out a couple more ways to outsmart the car that do not require using the key to lock the driver's door.
*One way (if inside the car with engine running) is to lock all the doors using the lock button, then unlocking the driver door with the manual switch. Open the door, then lock it with the manual switch and close the door.
*Second way (if you have not put the key in the ignition yet) is to lock all the doors, with the driver's door open, using the door switch (the remote will probably work as well, but I did not specifically try that method). With the door still open, start the engine, exit, and close the door. The car will actually chirp to notify you that it is locked.
In all cases, make certain you have your door key handy before closing that driver's door! :P
One way to bypass this was to pull the inside door handle on the driver's door and then lock the door using either the button or the power lock switch. This could be done even with the key in the ignition. It might work on Subarus as well.
Really, not that hard.. The lock button on the Accord was down by the inside door handle.. When exiting the car, you could pull the latch with your first two fingers, and flip the lock closed with your thumb, all in one motion..
Otherwise, you had to use the key to lock the door.
150,000 miles on the Legacy, still impressed with the car.
Any cons to consider ?
No problem with mine, in fact I'd recommend it. If we sell our Legacy first, I'd probably go through the trouble of moving it from the Forester to the Legacy.
It saves a ton of time, and also makes the job neater.
Cons? I'm not sure that all of the oil drains out completely. Mine does have a spacer and I add half a quart to help rinse out the old oil, since I only need 4.5 quarts.
-juice
-mike
As for the jack, why would someone use the oil pan as a jacking point? Use the front cross member if you must lift both front wheels.
-juice
-mike
Mine you have to move in two directions to open. First you lift it, then you slide it to the side.
Could happen, I guess, but I doubt it's common.
-juice
They are also replacing the trim around the radio and climate control console because of terribly bad squeaking. Also have some rattling in the dash somewhere, but that occurs only ocassionally so can't diagnose.
I have had way to many major components go on this car than I care for (just over 2 yrs old, with 18 K miles). I am trying to rationalize that this would not be happening if I had not bought one of the early runs of a newly designed vehicle. But the fact is, this is rather disappointing for a Subaru.
Yesterday at the ski hill, when I first started the car (it was about -15 C), I heard a strange groan that disappeared when I engaged the clutch pedal (shifter in neutral). Checked this morning, and same thing. So, will have to bring it in to the dealer again while we still have this cold weather. Who knows, maybe they'll tell me that I need a new tranny?
Don't get me wrong....I generally love this car, but these issues have me wary of holding onto it after my warranty expires. Honestly, when I bought my current XTL, I was trading in my 00 OB, and really didn't look much beyond Subaru for a new vehicle. Next time, I will look the competition much much more closely.
The center console trim will still squeak if you replace it. The trick is to line the contact points with tape (I prefer friction tape or a nylon/cloth atheltic tape) to keep the plastic parts from rubbing. I did this to my 05 XT and it completely solved the problem. By now, your trim will have developed rub patterns underneath and those are the places that would benefit from tape.
My 05 XT was around # 19000 off the assembly line and was nearly perfect for the 2.5 years and 36000 miles I owned it. My major complaint is that the battery died at 36000 miles.
Craig
I relayed two "original" rattle points to the dealer last week when I scheduled a time to bring it in for the moisture-in-the-headlights problem, but now I will have to be sure to tell them about the 3 new rattles. This morning it was rattling so bad that it was in surround sound - I could not even tell which was which any longer!
Mine died after 5 years but it was my fault - one cell was nearly dry.
-juice
-juice
The dealer said they had to keep the car for a day to trickle charge the battery and make sure it was really dead, then order a new battery, then wait for it to come in. With a holiday in the middle, I would not have gotten the new battery until the following Wednesday or Thursday! I decided to just buy a new battery for $60 and save myself some aggravation. So much for the warranty....
-juice
Unfortunately I missed the weather report and took the Miata to work today, and we might get an inch of snow. I may have to leave it here and take the Subway home.
It's not even that I can't get around, rather the other cars on the road that play bumper cars.
-juice
In the 90s my peer group was very fond of E36 BMWs which while they are terrific in San Jose, they are less than ideal in Tahoe during ski season. For the 2-3 ski trips a year, we rented a car. It seemed to keep everyone happy, we didn't have to fight about who had to drive their own car up there, we didn't have to worry if we got in with snow on our boots, etc.
Where I am located now, I see plenty of Miatas running around all winter on Blizzaks.
-juice
I share your fear of SUVs.
-juice
:sick:
Why give away your next move? It's a war out there.
-juice
Whats the general consensus on Subaru dealer service -- is it worth it to pony up $350+ for the the 15,000 mile service, etc, etc?
-juice
Oil Change
Air Filter
Tire Rotation
The major one is 30k which includes:
Oil Change
Rad Drain-fill
Brake flush
Tire Rotation
Air Filter
Fuel Filter (if it has a replaceable one, some newer models don't have a replaceable one)
Diffy Fluid Change (rear on ATs, Front and Rear on MTs)
We used to charge about $400 for this service at AZP so expect to pay about $500 for it at a Dealership.
-mike
Definitely watch the dealer so that they don't add extras onto the service (such as the unnecessary air filter you paid for at 7500 miles). At the 30K mark, that can add a lot of extra $$ onto the bill. Make sure they stick to the book.
Yup - you got shafted. Don't order a package - dealers load them up with a bunch of unnecessary, expensive services to pad their profit margins.
If you need a 15,000 mile service, look in your owner's manual for what is required. Go in and order those specific services. Their "15,000 mile service" could total twice as much. How do you think they stay in business selling cars for $500 over invoice?
Or just take it to a private garage and be done with it.
We have owned both, and they are both excellent cars. However, they are different enough that it deserves some careful consideration.
-mike
I have lifetime rotate and balance on my tires, for example, so paying the dealer is going to be more costly as well. And in my experience few technicians do any of the checks suggested in the manual - they're paid flat rate so less time means more money for them and the dealer.
If there are imprtant checks that require removal of bolts, panels etc, I rub chalk on them to see if they've been touched.
Personally I do the min amount of maintenance possible, usually I do my own as well so not really an issue for me.
-mike
When I brought this to SOA's attention, they cut me a check for the $95.95, and picked up my next oil change. +1 for SOA. I have never been back to Exeter. Rob M.
