Cabover Camper Chat
1235710
  • vince4vince4 Member Posts: 1,268
    6.0 all the way! A great motor I hear, I haven't put it to the test yet. Just so so mileage though at 13-15mpg. It's hard to find a 3/4 ton with the 5.3 because the 2wd HD and 4wd both have the 6.0 standard.
    Sorry to say Brutus but the 6.0 outpulled the Ford V10 in a Car & Driver TV test I saw recently. The extra 800 lbs on the SD really hurt it in the comparison. I suppose that weight buys something like a stronger frame etc.
    I just received something I ordered from www.rvpartsoutlet.com. It came in only a few days and the price was reasonable. They have a pretty good selection too.
  • BrutusBrutus Member Posts: 1,113
    I'm pretty sure that was a 99 V-10 (like mine). The 2000 V-10 has 35 more hp and 25 more ft-lb of torque. The advantage of the V-10 over the 6.0L is basically when hauling or towing near the max weights. The bigger engine is going to have an advantage if you strap a trailer on that both engines can pull with ease.
    If you put a 5th wheel trailer on a 3/4 tone truck with the 6.0L that is hits the maximum tow rating of the vehicle and then you strap that same size trailer on a 3/4 ton Superduty with the V-10 and then have both of them travel a few thousand miles through the Rockies, the torque advantage of the V-10 will be obvious.
    The extra 800 pounds wouldn't be a factor at that point since both trucks would be carrying a heavy load. The Chevy would be at max tow limit and the Ford would still be a few thousand under since the Superduty has a higher tow rating. Of course, it's an assumption that all else is equal, such as axle ratio, cab size, 2wd vs 4wd, etc.
    This isn't a knock on the 6.0L. Most people don't need more engine than that. The trailers towed in the TV test are likely closer to what most people will be towing. It just goes to show that most people don't need more engine than that. When they do, and if they are determined to buy a Chevy and stick with the gas engine, they will just move up to the 7.4L.
    For me personally, with the weight of my rig, I like the torque of the V-10, especially in combo with the 4.30 axle ratio. I do a lot of traveling through mountain passes. MPG wasn't an issue for me or I probably would have considered a diesel. I know someone who has the same size camper as me and has a Superduty with the PSD. He gets about 5mpg better than me with the camper on.
    Speaking of mpg, I lose about 1mpg in the winter since I tend to start the truck up about 10 minutes before I leave in the morning to de-ice and I also use 4wd more. I use the ESOF alot in the winter and have never had a problem. The shift to 4wd is pretty instantaneous. The shift back to 2wd usually takes a few more revolutions of the wheels.
  • mledtjemledtje Member Posts: 1,123
    I was over in the PlaneJane topic and I saw the pictures of your truck. Looks good! Not as good as mine of course, but good.
    I like your choice of std cab. Pewter was our first choice for color, until we saw it under street lights - it looks too brassy! We ordered Charcoal Metallic and love it! I have added the fender flares (in matte black) and they really set of the truck.
    One of these days I'll get out the camera and post some pictures. Boy, I've been saying that for 6 months now.
    You've probably got the camper on now and will be on the road every chance you get.
    Later,
    Mike
  • nasvikingnasviking Member Posts: 43
    Hey guys, looking at an 11'truck camper tomorrow. It's used and I'm guessing will run in the area of 2,800 pounds. I'm worried about the weight, but its a real good deal, better than an 8.5' I was going to look at. In your experiences can the Silverado 2500 longbed, 6.0 with 4X4 haul that ok and pull a boat,about 3,000 pounds?
    I sure trust you guys more than the dealer. I asked the dealer he said it would because a customer just hauled an 11 footer out on a new shortbed Chev. Thanks Steve
    It will be close to the max ratings of your truck, probably over.
    I've seen it done. You will need heavy duty air bags for the rear. Rental units in Alaska put 10.5 campers on 2500s. And tourists don't care about the truck.
    Weigh the camper if you can. A 2500 is rated for a maximum payload of 3300 lbs (base). If you add AC and other equipment on the truck it comes down. A couple of passengers, clothes, food, etc can easily weigh 500lbs. My guess is your total payload will be 7-800 lbs above the weight of the camper.
    My Silverado has a max payload of 2000 lbs and a 1200 lb camper put me 100lbs over max.
    Let us know what you do.
    Mike
    I'm sure you will be over your rated payload. My truck is a reg cab LB LS 4wd and the glove box sticker says 2800 lbs. I would think an ext. cab would be 100-200 lbs lower (you didn't say which style). You have to add passenger + cargo + tongue weight to the camper weight. Also the tongue weight of your trailer will be increased because you will need an extended hitch (leverage).
    I'm sure the truck will do it even though you will likely be 1000 lbs over limit. You will need to beef up the rear suspension with bags or springs for sure. The lifetime of the driveline components would be a concern if you use it this way a lot. I assume the brakes are good enough now that it would be safe. I don't know any way to verify that up front.
    That kind of load should go on a 1 ton truck. The Lance dealer here told me they won't put a 11' camper on a 3/4 ton truck.
    Remember, even though the extra space is nice, you have to maneuver that extra length around. If you expect to get into tight spots (off-road etc.) then I'd lean toward the shorter unit. You should look at both before deciding. One item I've found important is holding tank size. My camper is 9.5' and has small tanks compared to the biggies. My black water tank is 13 gallons which is a problem for extended use. I can get about 3-5 days with two people using it sparingly. The gray water is similar but some people have been known to dump it if really pushed (not that I would ever do such a thing!). The big units have tanks more like 20+ gallons. One other thing to check, mine has a nasty design feature; the shower drains into the black water tank. Some smaller campers do this. It is a drag because it fills up the black tank fast and if you aren't near a dump station then what do you do. I've actually built a pump system to get around this but it's a hassle.
    Let us know how they look.
  • stabburstabbur Member Posts: 75
    I'm interested in the postings about GVW. What one can get away with really depends on how the camper/truck combination is going to be used. It is one thing to cruise down a well-paved interstate into a well-groomed campground and quite another to travel dirt and gravel, especially in the west and far north. Lots of springs have been broken on U.S. Forest Service Roads. We travel in a '95 Ford 250 2wd 5speed super duty with the 351cubic inch V8 that carries a 10 foot Sunlite pop-up. On top of the camper we have a 17 foot Mad River Revelation canoe that weighs 84 lbs as rigged for white water travel. At the local gravel pit scale here in New England we weigh about 7,600lbs as we head west, just 1000lbs less than our max GVW. The "wheel well" access is packed with waterproof bags containing camping gear and a month of food for two.
    That 1000lbs feels mighty good as we pass the frequent broken down RV's on roads in the far north. Even with the Alaska highway pretty much paved there every gas station along the way has big signs advertising welding/shocks/springs/tires. If you get into the Northwest Territories slogging through some deep mud and heavy duty ruts you need all of that 1000lbs exta GVW. Anyone who starts 300 miles of gravel with a truck camper better have new 10 ply tires or be prepared to get help. If I were younger, I would think of opening a tire store in Inuvik.
    Our rig is just strong enough to handle this type of travel and has taken us to the start of some adventurous canoe trips. We spent 5 months going to Alaska and the Yukon in '95 (28 days in our canoe on the Yukon River) and two months in the Northwest Territories in '97 (25 days on the South Nahanni River).We have also driven various Utah/Wyoming desert roads in getting to portions of the Green River we have canoed.
    Along the way we spotted a wonderful restoration of an Avion slide-in camper done by a real craftsman. He had taken the original all aluminum shell and installed beautiful new woodwork, all new systems, etc. I've been looking for a basket case Avion to restore ever since without any luck. Anybody have one? Then, I would have to get a truck that would have a bit more oomph for the mountain passes - we spend a lot of time in 3rd - and we would be all set.
  • grizzly1grizzly1 Member Posts: 111
    It FINALLY happened! I picked up my truck this morning. I never thought I could be in love with a beautiful hunk of iron. This truck is amazing! Just like you all have said.. This is one fun truck to drive, & the power is awesome. I'm glad the seats have head restraints, I wouldn't want to get whiplash. The electric buckets are most comfortable- glad I ordered those. Can't say a whole lot at this time, since I only have 76 mi. on it. That's going to change real soon. Now all I need to do, is get is set up for the camper, & see how the truck will handle it. I think I'll be real glad I have the 6.0, & the 410.
    I'm going to install Nerf bars, & a bug shield, but not too sure on what shield to get. I,ve heard the Lund, & the Bug deflector II might be a good choice. Any thoughts? Love this truck!!!!!!!!
    Gary-
    Well finally you can join the club. See, it was worth the wait wasn't it? That first week it was so fun to go out every morning and get to hop in that beauty. It's still fun but the newness is beginning to wear off a bit.
    Take it easy during the break-in period and be sure to complete the 500 miles before putting the camper on. As you may have read in other topics, the bug deflector may make the rubber windshield gaskets chatter. If so they just need to be glued/taped down. Let us know how it's going and what your impressions & questions are.
    Wow, those sound like some adventurous trips! I am a big fan of overkill so I agree with your comments on excess GVWR. When pushing the truck in off-road use you never know if the manufacturer was conservative enough in their ratings. From my experience there is quite a bit of excess capacity in the rating for normal road use, however I wouldn't push it unless I had to. I have a normal hardside unit and would be very nervous doing much more than mildly rutted dirt roads. It is just too heavy and tall to push the limits.
    I didn't know they made popups that long. Does it have a full bathroom? How much does it weigh? Your truck weighs about 5000 lbs so that makes the camper about 2400 pounds? Sounds heavy for a popup.
    I wrote up a long winded explanation of how to install the aux battery in the new Silverado. If anyone is interested let me know.
    Grizzly,
    Congratulations. I've got 21,000 on my truck and I still feel good everytime I get in it. Hope your new never wears off. It is one of the benefits of ordering the truck you really want instead of settling for what the dealer has. I agree with on break-in. Relatively slow speeds, no hard starts or stops, plenty of shifting, no hard pulling. A winding road through the hills is a good place to go.
    Stabbur,
    I'll definitly agree with you on tires. I think anybody who puts a camper on a truck with P-series tires is asking for trouble. There is not enough safety margin built into those tires. LT series only.
    My truck is loaded to max GVWR and we had it up in the far north (as far north as you can go on a road) and through the NWT (it was dry) and at least 2000 miles of northern dirt and gravel on Load Range 'C' tires. I think that is equal to 6 ply rating. No flats, not a single tire problem. We saw a lot of tire problems, but most were P series tires and/or balding. LT tires with plenty of tread go a long ways towards preventing problems. But then, maybe we were lucky.
    Vince,
    I for one would like to see your explanation of installing the aux battery tray. If you don't want to post it here, you can e-mail it to me. How is your truck/camper? Got that bad boy up and running yet? Going camping for the long weekend?
    Take care guys,
    Mike
  • ahollowellahollowell Member Posts: 14
    Vince,
    Since I just finished installing the aux battery box and an isolator in my Dodge, I'd be interested to see what had to be done for a Chevy. My battery box, hold-down, bolts, etc. cost $55 from my dealer. The isolator (120 Amp) was $49, and another $20 for cables and a circuit breaker. The only major change I made was to feed my 7-way trailer hitch positive connection from the aux battery, rather than the truck battery, since my camper plugs into the truck's receiver connection.
    I did not want a hole in the bed for the camper connection, so I extended the electrical wires back to the receiver, and connected a 7-way adapter to fit. I also added a 4-way flat connector, so I can still tow the boat with the camper installed.
    One company that makes some pretty big popup campers is Alaskan Camper. They have 8' and 10' models and also an 11' Alcan Camper. The 10' model advertise a dry weight of about 1700 pounds and a wet weight of about 1900. Obviously options will add weight. The campers are not cheap. The base price is about $16,500. My guess is that you would have around $20,000 into it after options and installation.
    www.alaskancamper.com
    www.alcancamper.com
    Thanks for your comments. My 10 foot Sunlight (Condor model) weighs about 1850lbs dry. I think that much of the weight is in plywood interior walls required to stiffen the sides. This would not be necessary if it had a standard roof. The cabinets, shower walls, etc, even the curtain valences are structural. Also the counter/table tops are particle board - heavy. It has a full bath, but being a pop up the walls vanish at about 60 inches and it is shower curtain from there on up. The walls are not missed. The furnace makes a hell of a hair dryer if you sit on the floor under the discharge. I agree that the gas appliances, furnace and frig, are the most important components, the hot water is also very nice to have after a cold hike in the rain or sleet. And to be able to reach the stove top from a seat at the table has certain advantages.
    This slide in has no provision for an auxiliary battery and the Ford 250 with the 251 has no room under the hood for an extra battery. I mounted our deep cycle auxiliary in a carrier along side the left frame member just in front of the left rear spring shackle.(Where the infamous Chevvy gas tanks were located!) It tucked up well in that location and has been undisturbed for 4.5 years now. I put a piece of plastic against the frame since I worried about acid splash, but with the no maintenance batteries I don't think I should have bothered. When wired into the Ford trailer package no isolator is needed since this circuit is isolated when the ignition is off. It was originally installed without a fusible link and this was added after I realized what might happen if we had a short. It was possible to route the cable to the camper up through the narrow space between the fender and box-side, into the post socket and then out into the top of the box through the porthole in the post socket. I slipped some wire loom over the cable to protect it over this route and it put the plug right in the front left corner of the box where the connection on the slide in is located.
    Electric has been just fine. I added a low wattage inverter which is handy. I replaced the 30 amp vinyl covered cable supplied with the camper because it was too unruly on cold mornings. The new cable is better, but still is a pain when it is really cold. I may switch to a heavy duty rubber covered cable.
    Plumbing is another story. Leaks in the blackwater system. Each repair worked its way down the piping to where I think it may now be fixed. I suspect the problem is large diameter PVC to ABS fittings in too short a distance to accommodate torsion/flex etc. I have now put in a neoprene coupler and if it stays where it belongs and gives a bit when required, our problem may be cured.
    Nice to hear about the new trucks. It is a great day when you finally take the wheel. Who has the Northern Lite. Do you like it?
    That's a good place for the battery. It's cool that the trailer circuit is already isolated, GM doesn't do that. I wish the manufacturers would utilize that space. It's really quite a large volume and would be great for things like tools and jumper cables. I remember some 1970's or so Fords used to have a locking door that would open to that area, I assume it was a compartment but I never saw inside one.
    I have (soon to be had) a '89 F-250 with the 5.0L and I managed to squeeze a second battery in the engine compartment. It's located against the firewall on the driver's side, between the brake booster and the fender. It was a tight fit. The worst part was the crappy tray and hold downs I bought at the auto store. They are made overseas and didn't hold up well. My camper has a battery too but I wanted two in parallel for longer stays without driving.
    I've never had any plumbing problem with my Lance but it doesn't go off road much. That banging around must take its toll on the plumbing and more. What do you use the inverter for? I bought one but have yet to use it.
    Wow, those are expensive. But they have some nice features. I really like the comfortable looking seating, it's even angled like a real couch! Why the rest haven't figured this out is beyond me. That is my #1 complaint of campers: lack of comfortable seating. Mine isn't bad with a pillow or two but they could make it good if they tried. I really don't like the location of the seating though, you have to climb on the table/bed/couch to get to the upper bunk. That would be a little tough in the middle of the night if both beds were in use.
    I hate to say it but I got the inverter because it was the easiest way for me to power up my laptop computer. Any reasonable person would not bother to go from DC 12 volts to AC at 120 volts and then transform and reinvert to get the DC for the laptop. BUT cables and connections just made no sense any other way. Now, of course, the inverter can be used for anything that doesn't consume more than 500 watts. For instance, my wife has a electric spinning "wheel", except that there is no wheel, just a small motor and the spindle. She can spin wool while we cruise, etc. I would rather have her read works aloud by our favorite author as we travel and I, in turn, read aloud while she has the helm. As a break from reading, however, she finds spinning a pleasant activity and I shouldn't complain.
    I agree that the Alcan looks nice. The first camper I ever looked at was an Alaskan that unfortunately had sat too long in a puddle of water in the pickup body. It was well cared for otherwise but the bottom was going to drop out of it when it was moved. As I remember they wanted $300 for it. I like that utility body that the Alcan is sitting on. That would make our gear much more accessible than it is when stuffed down in the truck bed.
    Vince, Mike, tell me what you think of this. My sales person, who is/was a mechanic, told me not to worry about babying the truck. He says the way they're built today, there is no need to baby the truck, & also, bring it in for the first oil change & differential at 3000 mi. He said, with a locking diff., you need to change the diff. oil at 3000 mi. for sure, & change the break in oil at the same time. I think I'll call a couple of dealers, & see what they say. I know everyone says 500 mi. is the magic #. What oil have you guys used. I've heard Castrol & Havoline are the way to go. I'll be putting some miles on it the next few days- can't wait to get back in the seat.
    Vince, I also would like more info. on the aux. batt..
    Mike, I hope the newness last a long time.. I think it will, since I won't be driving it to work very often. I'll give it hell on the week ends though. When you say shifting, are you talking about using 2& 3, as well as drive?
    To all the group- have a GREAT Thanksgiving! Love that truck!!!!!!!!!!!!!!!!!!
    Gary-
    My opinion is, why not follow the manufacturer's recommendation? It's no big deal to take it easy for 500 miles and just seems like common sense to me. There is an awfully lot of newly assembled moving parts.
    For the first oil change, I'll do mine around 1500 miles. If there is ever a time to change the oil early, it's the first time. For the differential, I don't agree with the salesman. The manual actually doesn't specify an oil change at any time. He was probably thinking about a limited slip differential, in which case the fluid is very important. The rear diff has synthetic oil in it which holds up for a long time.
    For brand of oil, I use Castrol but suspect I'm a sucker for advertising. I believe the frequency of changing is more important than brand as long as you stick with a good oil. I'm going to switch to synthetic at about 10,000 miles.
  • ckitchensckitchens Member Posts: 67
    We have a 1991 Scamper 9.5 foot fully self-contained truck camper for sale. We just don't use it anymore. Our 1988 F-250 pulls it like it is not there most of the time. We are original owners - no kids, no pets - never had a problem with the camper. It is like-new - stored under a carport. Would like to get somewhere around $3,000 for it - that is about one-third the cost of a new one. This is a pop-top style camper and self-contained includes flushing toilet and shower. Anyone interested? We are in New Mexico.
    Opps... thought I was clicking the spell check button...that was ugly!
    Is there anyway I can tell if they (GM) gave me the right locking diff.? Why would the fleet dealer tell me to make sure to have the diff. oil change at 3000 mi.,if it's not a limited slip. Another thing he said, it's going to cost me $80.00 to have the oil changed because they have to take the cover off. According to my brochures, it has a drain & fill plug, so as to eliminate the cover removal. I know they were having problems getting the locking diffs. for awhile, which was holding up some production. I sure hope they didn't install the limited slip to get the order out. I would sure think I would have some recourse. This would not make me a happy camper. HELP!!!! Other than this possible screw up, I love the truck. Have 370 mi. at this time. I got the s/s nerfs & Lund deflector done this Fri., & also the Line-X spray in. It looks absolutely GREAT. Was going to do the Rhino, but really glad I went with Line-x. No vibrations, noises, rattles, etc. I hope it maintains.
    I suppose if I go out & spin my wheels & there's two black streaks, not one, then I have the right locker?
    Gary-
    They only put one type of locking diff. in this truck, either you have it or not. Don't put so much importance on what a salesman says (always a good rule to live by!). Look on your window sticker or invoice and see if it lists the G80 Locking Diff., if so then you have it. By the way there is an interesting web site for this Eaton locker, have you seen it? (URL found on other topics)
    I just went and looked at mine, there is a check plug and a drain plug. So much for his expert knowledge. Mine also has a streak of wet coming from the driveshaft seal. That doesn't seem right for 1300 miles. I'll add it to my dealer to-do list.
    That sounds like a fair deal. If anyone on the web responds they would likely want to see pictures, you may want to take some and have them scanned.
    Congratulations on your find. It sounds like a lot of camper for the money. There are 3 basic types of tie downs: stake pocket or rail mount, body mount, and frame mount. Don't mess with the first type, they are weak and flex a lot. I don't know who makes the frame mount type or how much they cost but Brutus has them and described them in a previous post (~20 back?). The body mount type are the most common, they are made by HappiJac (www.happijac.com). The front brackets mount to the bed front wall and the back to the bumper ends. The turnbuckles are easy to use and have a spring (front) or rubber (rear) shock absorber inside to relieve peak stress. The bracket kit costs $80-90 and the turnbuckles are $70 for four.
    At a labor rate of $70/hr and say $120 of parts (brackets,electrical) that works out to four hours labor. That seems a bit on the high side. My dealer quoted one hour to put the brackets on. Gary, what did the Lance place quote you?
    So why is your Silverodo going to take so long? Did you order 4 doors?
    My advice on break-in is to follow the manufacturers procedures. Unless you know someone who has more knowledge of the product than the engineers who design and build it, you should follow their advice.
    If the trucks needed no break-in, then GM would say so. It would be a sales feature. They suggest a break-in method that reduces warranty. Your mechanic might suggest a break-in that increases his repair income. GM has nothing to gain and everything to loose if you don't break it in properly. Follow the factory method. I changed my oil the first time at 500 miles. Went to synthetic at 3000 miles. Now I follow the oil minder light on the dash and change when it tells me too. With conventional oil I change every 2500 miles because it is easier to remember than 3000 miles. I know I have to change at 52,500, but with 3000 mile changes is it 52,000 or 53,000?
    Gary, by shifting, I meant all gears, but I have a manual transmission. But it is good to go slow and use some of the other gears. Use everything, first to make sure it works, second to allow the parts to mate under less load.
    Went down into the Los Padres Natl Forest this weekend. Some bad roads in there. 5-10mph in 4wd low range for miles. Some very impressive views in there also. My wife picked Limekiln State Park to spend the night. On Hwy 1 with both beach and redwood camping. We were way back in the woods. Hiked back to the lime kilns, and way back to the waterfalls. That's a very nice place. My wife picked up a tick however. And by the time we noticed it, it's head was way deep. Kaiser took it out, cause I couldn't get it out, and didn't want to leave the head inside.
    I sure do like that low range in the transfer case. I found the fuse for 4wd in the left side of the dash. Open the door and pull the end panel off the dash. Locate the fuse. Pull the fuse and you can have 2wd low range. Perfect for loading and unloading the camper, pulling on pavement. I think I will put a switch in that line, so I don't have to pull the fuse to get 2wd Low.
    Back to work,
    Mike
    Vince- Here it is:
    1. $375 installed ( Air bags)Two
    lines
    2.$85 for tie downs, including a
    1" piece of square tubing
    to reinforce the two front
    brackets from torqueing the
    metal.
    3. Around $50 for all the elec-
    trical
    These Air lift bags are made for Lance only, which have an inner bag so you can deflate them entirely & ride on your normal suspension. The inner bag protects the outer bag. Anyway, I'm going up there Monday. Get it done & over with.
    I've determined I have the G80 lock, & as far as the oil & rear end, I'm going 1500mi on the oil, & the rear end I was told it doesn't need to be changed at 3k.
    Mike- Those ticks can be real nasty. I've pulled many a tick out of animals, but never a human. I went out today, & found a place to go through all my gears, 4Hi, Lo etc.. Works great. Never been to Los Padres.. Sounds real nice, except for the ticks.
    Gary-
    Is Limekiln that one with the entrance just at the end of a bridge? (I think, fuzzy memory) I passed by it when I was in Big Sur a few months ago but it was closed because of the fire. Tom's book says it is mostly oriented to RVs, true?
    How do you find those rugged roads you describe? Is it okay to just drive on any dirt road you see? What about fire roads? I haven't done that type of driving yet but would like to explore a little. Did you have the camper on?
    Your 2wd low trick is clever but I don't see the point. I think I've got plenty of low end torque to do anything normal and would just jump into 4wd if I really needed low range. I guess turning a lot on pavement could be an issue but how often do you need to do both?
    Let me know about the road, I'm interested in what would force you into 4wd low.
    Vince
    Those are fair prices. The air bags cost about $220-260 so the installed price isn't bad. The mounts are so cheap I'm skeptical. I paid $90 for the brackets (a little higher for 99/00 Chevy than older ones) and $35 for the stabilizer bar you mentioned. That's just the part price, they quoted 1hr to install. So $85 is a gift if they actually do it.
    I didn't know about the special air bag design. Air Lift is very adamant in there literature that the #1 cause of failure is under-inflation. The rubber gets pinched if you bottom out with no air pressure. In fact I get double warranty because I installed their compressor kit which has pressure switches to automatically keep at least 5psi in the bags. I guess the inner bag in yours offers the same protection.
    Yes, Limekiln entrance is right by the bridge. Camping is under the bridge and on the beach or back in the trees. We on saw one RV of 25' or more. Mostly tent campers. Two P/U campers. No trailers. The sites are two small for big campers. You can go out on the beach and watch the sunset, or just watch the waves break on the beach. There was a total of 43 sites. The ones on the beach right next to each other, but the ones in the woods can be well spaced. Hot showers are a bonus. The shower down by the beach is a pay shower for the day users, and the ones by the woods are free. Camp in the redwoods and walk to the beach. California has some real advantages sometimes.
    The roads we went on were all on our maps, so we think they are fair game. Actually, anything that is not marked 'No Trespassing' or so, is fair game. Yes we had the camper on, so we had a fair amount of weight and needed low range to pull up some of the hills. And to creep along at very low speeds on the rough stuff. My wife did not like hills that steep. Going up one canyon, we saw a car and a truck 1/2 down the opposite side. Kinds of makes you respect the road a little more. Found some really nice places to camp back in there, and we will return.
    I've tried 4wd on dry pavement and it binds up and stops the truck when you try to turn sharply. Because the driveshafts both turn at the same speed, something has to give. Either a part breaks or tire slips on the pavement. It puts a lot of stress on the drivetrain and I worry about breaking something. I've got enough power to pull in 2wd high, but want to go slower. In low range the speed is 1/2 what it is in high range. So I can idle back under the camper at 1-2 mph w/no throttle. Usually in high range I have to give it some throttle and slip the clutch. I guess this is one case where an automatic has some advantage. Now where is that stump that needs pulling?
    Mike
    When I drove up the Alaska Hwy in January, I opted to take the Hudson Hope Loop bypass of Dawson Creek. It was a nice detour. The farmers had bails of hay and the deer were standing next to the cows eating from it. They were semi-domesticated it seemed. Anyway, this loop had a hill with an extended 10% upgrade and a 10% downgrade on a not-too-wide road. This is not a hill that I think many RVs could have made at this time of the year without 4wd. I took it slow and climbed most of it in 2nd gear, but did drop down to 1st gear to keep the speed where I wanted it. I never had to use 4wd low since I could really crawl in 1st gear if I want to (I do have the automatic).
    I've got shift-on-the-fly in my truck. I use it quite a bit. If the roads are dry and not iced, I'll keep in 2wd, especially on the hwy. If I need 4wd, I'll shift out of it right before I enter a parking lot to avoid the "wobble turn". Even if it doesn't hurt the truck, I've got to believe that it does put some excess wear on it. I'll shift back into 4wd right before I exit the parking lot, so I can easily get out into traffic. I tend to use the 4wd to get out of parking lots into fast traffic even I end up turning it off right away once I get on the road I am entering. There is nothing fun about needing to get out into traffic quick only to be halfway out in the road with your rear tires still in the parking lot spinning.
    A good rule of thumb that I like to follow with hills is to use the same gear to go down the hill as you used to get up it. Generally, you're climbing through a pass over over a hitll where you climb one side and descend the other side. The temptation is to go faster on the descent, but with a camper, you could get up too much speed and have to use excess braking or hard downshifting. If you climbed the hill in 2nd or 3rd, you should probably descend in that same gear. That's produced the best results for me most of the time.
    Yes, going down hills is often more hair-raising than going up. I think that your type of driving is why GM came up with the Autotrac. It does automatically what you do with your knob. Likely Ford will come out with something similar.
    If it didn't take so long to drive to Alaska from here I'd go for sure. The combined trip is so long I'd have to take an extended vacation or leave of absence from work. Some companies around here give you a 4-5 week sabbatical after 5 yrs employment, I was really hoping to get one of those jobs for just such a reason. But alas, I decided I wanted to work for HP and they don't offer such a thing. So here I sit reading about Alaska.
    This is my first 4wd truck and I'd like to take an off-road driving class. Does anyone know of any or have any experience with such a thing? Since it doesn't snow here I don't get much practice in that environment either. That must be a strange concept for you Brutus since you deal with it every day. I'm not out to tame the Rubicon trail. I just don't want to be one of those unlucky fools in the ditch you talk about, or one of those cars 1/2 way down the canyon Mike mentioned. I know of one school that used to be taught by the daughter of the guy (Mark Smith) who founded the Jeepers Jamboree Rubicon thing. I don't know if they still have that school but I guess I will check. It's way up in Gary's neck of the woods so kind of a long drive.
    Limekiln sounds nice. I'll plan on going soon. Have you been to the coast in really bad weather? It's wonderful. (Of course I'm weird.) We went during the El Nino (sp?) storms and I've never seen anything like it. Wild seas, raging wind and rain, eroded shores strewn with debris. Very cool to experience for a few minutes. Then run back to the camper and get warm.
    For winter driving experience nothing beats a few turns around a solidly frozen lake. It offers the opportunity to recover from early spinouts without overcorrection, learn about broad-slides, and gives the chance to let the rear hang out in the turns. We have lots of these in New England, and with the last two mornings in the low teens, we will have some more soon. Wait until there are plenty of ice fishermen with vehicles out there. Most of our ponds have access at boat loading ramps. It is a good idea not to be first, and those guys have augers that allow them to measure ice thickness. I would think some mountain lakes in California would have some ice fishermen? There may be some 4 wheel driving schools mentioned in the car and driver web page. They did an article on one a couple of years ago.
    I find that there are two important ingredients to snow driving: Momentum, and friction. The two should be quite independent of each other but become related fast with sudden moves. Don't make sudden moves. To cope with lots of snow you need momentum, but don't forget that when you need it, friction may not be there. I wouldn't practice with a camper on the truck, but the few times we have run into snow with the camper that lake practice experience has come in handy. We live on a dirt road in New England and we have lots of snow. Up to now we have been 2 wheel drive. Because our roads have been empty I could keep momentum as my trump card. Now more people are moving to the area, the roads are more crowded, especially with people who creep along in their SUV's. Maybe we'll have to go to 4wd next.
    I agree that you need plenty of time to take an Alaska trip. I decided to go when a fellow showed us a movie of rafting the Yukon River when I was in Boy Scouts back in 1944. I had to wait until 1995 when I retired to make the trip. It was great and we will go again.
    stabbur,
    You're right on with the advice for snow driving. I usually tell people to take the vehicles to a large empty parking lot at night, like a Walmart, after it's closed and practice slamming on the brakes and making fast turns. I really like driving in the winter, although I wouldn't like it as much without the 4wd. With my duallys, it's night and day in 4wd vs 2wd. I've sat at a light in an icy intersection before and practically been stuck in 2wd. When I shift to 4wd, I can pull away from the light with a heavy throttle and no loss of control since all four tires are rotating.
    Of course, breaking traction at hwy speeds is a major no-no, regardless of whether you have 4wd or not. Most people that I see that get in trouble o the hwy are either breaking traction, following too close, or changing lanes too quickly. I'm a fairly agressive driver, but those are things that you can't do in winter conditions, regardless of whether you do them in the summer or not.
    I've been up and down the Alaska Hwy several times. The last time was returning to Anchorage in January. I had my camper on at the time. I had just picked up from a dealer in BC. It was my first truck camper, so I was just getting use to driving with it on at the time. I kept the truck in 4wd most of the time since there was plenty of ice and snow on the road. I'm sure the extra weight of the camper helped rearend traction, but that is not as vital of an issue if you are in 4wd. With the front of a pickup pulling in 4wd, the rearend will pretty much follow it anywhere. It's when the rearend is trying to push the front end without any aid from the front axle that causes you to get squirelly (yeah, I made that word up).
    I hope I don't have to wait 50 yrs to make the trip! Glad you finally made it though. I would love to practice on a frozen lake, that is the perfect training ground for learning slide control etc. However where I live a very cold winter night is when we get frost on the plants. Oh my God, break out the tarps it's 30 degrees! A good substitute to the lake is a nice big muddy field. I'm sure there are such areas around for off-road driving but since I don't hang with the 2-foot lift crowd I'm not well informed. I'll just have to become a little more adventurous like our friend Mike.
    Hey Mike #2 are you out there? (I received an e-mail from another soon to be Lance owner with a 2000 Silverado 4x4 Xcab 3/4 ton.) Was my battery story helpful?
  • mcollins2mcollins2 Member Posts: 24
    Hi Vince, thanks for the 2nd battery info. Gave me some good answers to questions I had. Sure could use your Air Lift tips too.
    Just mounted the Titan hitch on my 2500 LS 4X4 ext cab SB. Installation was smooth. What a hitch! Also mounted the Torklift frame tie downs,
    fronts mount smooth, rears mount with three 1/2" bolts to the titan hitch (drilling required). You may want to look at their Web site www.torklift.com where they show some damage to trucks from the box mounted tiedowns.
    Look at your truck, my truckbox appears to be mounted directly to the frame ( without any rubber mounts ) which is why I went with the frame mount.
    My camper spec (glove box) is 2215 lbs with A=65" and B=0". My Payload (from 2000 brochure) is 3115 lbs, which is a difference of 900 lbs.
    Compare to your 2500 LS 4X4 reg cab LB: camper spec is 2800 lbs with A=81" and B=14". Payload (from 2000 brochure) is 3334 lbs, which is a difference of 534 lbs.
    The A and B specs may be due to SB vs LB camper layouts? The the differences in B dimensions (min camper CG) between our trucks may be why they have more "padding" on the SB. Hope I'll be OK with about 2800 lbs with CG about 20". Once I get it hooked up I'll measure the GAWR and if I'm OK front and rear, I'll be happy.
    I looked at that web site and my old Ford looks just like the picture with the damage at the front of the box. But it took an unusual situation (towing on a flatbed) to cause that. I'm surprised the Happijac front brackets aren't simply made thicker if that damage is a known problem. I went with the box mounts again on the new truck, I hope it never gets damaged. Maybe I'll leave the front turnbuckles a little looser from now on. They have a spring inside which is supposed to reduce peak stress.
    You will be over the recommended max with the new camper but with the air bags etc. it should be fine. The motor and trans are easily up to the job.
    I'll write a note on my Air Lift Super Duty bag installation. There are things to know that I learned the hard way. I'll e-mail it when ready.
    I finally installed the rear stabilizer bar I purchased long ago. It went on okay, but not perfect. Hellwig blew the design by not making it 1 inch longer. Because of that I had to flip the driver side shock mount bolt around and relocate the parking brake cable. Once I figured out those tricks then the bar had just enough space to rotate without hitting anything. The revised frame mounts seemed to work fine but they barely fit the 3/4 ton frame and could have used a little more adjustment range.
    Anyone try the Hotchkis (expensive) sway bar on the 2500 Silverado? Hope they have it figured out, I'm getting tired of returning hitches, air bags, etc. that don't fit. Oh well, thats what happens when you get something new!
    Vince I have the happi jac camper mounts ordered for my new Lance 820 but I gave up and got the Torklift mounts. I might use the spring turnbuckles from the happi jac on the torklift. The Silverado really sticks out at the front of the box ( right where the happi jacs will hit ). I agree with you, why don't they stiffen up the metal bracket so it doesn't flex as much? I have the installation instructions for the happi jac model CA-CG9 and the stabilizing bar, and don't see any major changes that would help avoid the dents. The stablizer bar stiffens up the guide plate mounting but does not control the bending of the black anchor plate.
    Hi Vince,
    I noticed your camper has plumbing (drains) running under the back of the camper. Will this plumbing block access to the spare tire winch? If it does, you should think of a way around the problem before you have a flat and cannot get the spare out.
    Other than that, the winch works well.
    No big problems installing the bar? I think it would have gone easier if I had seen a successful installation before I started.
    We're looking forward to seeing your trip reports on this newsgrooup. You don't have to go directly to Alaska. Make that trip out to the Dakotas and Montana. If you want to know some places to visit, ask and you will get some. But, we want to read that trip report when you get back.
    Mike
    I take back all the nice things I said about the Hellwig bar. Some hours after I wrote that it dawned on me that the end links must be oriented to rotate front-to-rear and I had to twist them to get it to fit. They don't point this out in the directions. I have to try again but I'm pretty sure the problem is with the new frame mounts. They don't allow the brackets to go rearward enough because the frame gets wider there.
    I had a thought and called Hellwig. Sure enough, Robert thought they used a 1/2 ton to redesign the mounts (and I'll bet to design the bar). So I'm going to whine about the mounts and the bar itself. It is just too short. I suspect the truck they used had a smaller rear differential. Does anyone know if a 1/2 ton diff. is smaller? Maybe without locker? Robert was very nice and said they would fix it. I guess I get to do the job over again, at least twice if I get new parts. It's amazing how a vehicle that's been out well over a year is still such a mystery to parts suppliers.
    The tank drain is on the rear, driver's side. Since the winch access is on the other side I don't think that will be a problem. As I think you pointed out long ago, the camper overhang may be a problem. I didn't need to drop the tire to put in the bar so I've yet to ever use the winch. I'll wait until I get the camper on and give it a try.
    I changed my oil tonight for the first time. The magnet did have some metal goo on it (1550 miles). Kind of wish I'd changed it earlier but I had a long trip over Thanksgiving and that bumped up the mileage. Then I spent 2 days looking for a dumb oil filter. Wal-mart & K-mart only carry the PF58 and I needed a PF59. Finally found them at Pep Boys. They had the Ultra Gold AC Delco filters but again only up to PF58 so I bought a regular one. The PF59 cost $5.99 whereas the PF58 was only $3.29 ($2.89 at the 'marts) and they look the same.
    Vince,
    I just changed my oil last night too. Not much on the magnet after 750 miles ( right behind you Vince ). Didn't find any PF59s at Wal and K-mart here also. Auto-Zone had AC Delcos PF59s for 2.99 though.
    Too bad on the sway bar troubles. Talked to Hotchkis and they are going to have a 3/4 ton 4X4 model available in about 2-3 months (model 2232 or 2232R for rear only). I can't wait that long, I was hoping your Hellwig would work out. Going to try IPD today and see if they make something.
    My lance 820 should be on its way from the factory this week. Need to finish all my "mods" soon for some Christmas camping in south Florida.
    Mike2
    If I ever got a flat with the camper on, I wouldn't even consider changing the tire without taking the camper off, at least not with the standard jack that comes with the truck. I thought I had a flat this summer when I was fishing in Homer. It turns out that it wasn't a flat. I had a rock stuck between the two duallys. That's almost as bad. We tryed using the tire iron as a cro-bar, but that didn't work. I finally lifted the camper up. Fortunately, lifting the weight off did the trick. I thought I was going to have to take the outside tire of. It was still a pain.
    Auto-Zone seems to have good prices. I wish there was one in my area. Eventually I want to switch to syn. oil and a premium filter. So far I'm aware of AC Delco Ultra Gold, Purulator One (?), and Mobil 1. On the bar issue, don't write off Hellwig yet. I still have to get under mine, loosen everything, and try to realign the end links. Once done I'll know what the problem is and Hellwig seems willing to revise the design. It seems I'm the first person to complain about 3/4 ton design. So it may take a month or so but eventually they may have a good offering for an attractive price.
