2001 Accord brake pad replacement
I have a 2001 Accord EX with 35K miles that needs new rear brake pads. The Honda dealership said I need to buy Honda brake pads or they will squeak. He indicated that Honda parts aren't necessary for everything, but that I should always use Honda brake pads and steering wheel fluid. I would prefer to buy brake pads at Autozone as I have in the past because they are cheaper (by about $25). Has anyone had this squeaking problem with non-Honda brake pads? I'd like to save the extra $ but don't want to use the wrong part.
I haven't had any problems in the past. Strange that you need rears at 35k, earliest I have ever changed rears is 70k mi. Musta gone through at least a set of fronts already(60/40f/r brake ratio)
good luck
A lot of the aftermarket ones will squeal.
It seems that on the later Accords, they will go through rear pads before the fronts wear out. The rear pads don't come with as much material as the fronts.
My 99 V-6 coupe needed rear pads at 45,000 miles. I probably could have gone another 5000 miles but I decided to have them replaced since the car was already up in the air.
The fronts are original and still had 4.5 MM left to the wear indicators. That's about 50%.
I'm pretty careful myself but I'll probably need front pads around 60,000 miles.
Course, there are lots of hills around here too!
They don't get affected as much as drums in foul weather, and are much easier to change than shoes..
Very few aftermarket parts will meet the quality of certain OEMs.
