Need information on Nissan 350Z problems & issues
I am seriously considering purchasing a 2003 or 2004 350Z. I would love to get information from current owners on any problems or issues they have had with the car.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I am a Nissan Sales Rep. at Downtown Seattle Nissan. I have worked here for over a year, and there has only been 1 real issue with the 350Z. On the early models the windows had a problem staying fully on track, and would put grease marks on the windows. My service guys quickly corrected this problem by installing a new "window regulator brush kit". That is the only reoccuring problem we have had. I hope this info helps you in your decision. 350Z's KICK BUTT!!!..........ZANE
We both have a problem with the paint(Both are Redline Color)Appear to have what looks like an overspray pattern on car. More concentrated in some areas. It looks like it is under the clear coat,almost like paint is lifting. There are several places(12-13 on mine which sits in hot sun & 8-9 on hubby's)that look like rock chips on both our hoods. Let me tell you... his is 5 weeks old and only driven 3days a week and sits under shelter with cover on it. Mine is 3weeks old.
Dealership says they will fix it by sanding it down and re-coating it. But...If it is not completely redone wouldn't you expect problems later? And if it is on both cars doesn't it seem to be a problem originating from the factory?
Any advice or info would be greatly appreciated.
About the only thing you can do is either use a conventional bra or the clear 3M firm. A bra is cheaper, but IMO ugly and requires maintenance. When my 350Z was a few days old, I had the 3M clear film applied to the front and mirrors. This stuff is great. Almost invisible on the car and can be waxed just like paint. It is pricey -probably $500-$1000 for a 350Z.
If you're getting your car repainted, after the repaint would be the time to get the clear film applied. The problem you might have is that the paint may have to cure for a while before applying the clear film. While waiting for the paint to cure, you may pick up more stone chips on the new paint.
Hope this helps. Let me know if you want more details on the clear film.
It is a tire design problem, the inner and outer tread blocks squirm under pressure. Unfortunately tying the blocks together causes wet friction problems....no where for water to go.
3,000 mile 90 day demounts and flips on wheels are the only solution! The Michelin Pilots tend to be the least offensive but they still have to have the process.
Impossible to find non directional tires now that are close enough to oem standards to avoid the flip demount.
When you push the envelope something has to give and tires are cheap considering the 10% improvement in performance.
Consider the Pirelli P Zero Nero as a adequate non directional tire almost performance tire, at least rotateable with out flipping.
I am in the final stages of deciding on a new car.It is between the 350Z and the STi.
I would like to know MPG figures for the 350Z cruising at 70-80 mph, which is normal for the central valley when the CHP is not around.
Thank you guys and gals.
Fred Hood
