1998 kia sportage 4wd not kicking in
i have a 1998 kia sportage and want to know if there are any recalls on the four wheel drives not working in them, supposedly mine does not kick in. help
http://www.safetyalerts.com/recall/autorecall/00/sportage.htm
I did a quick scan of all these and while the car seems to have its share of problems and people complaining about them, nothing at all on 4WD.
I suspect with a car 5 years old that you are just having typical wear and tear issues. If the car has an electrically operated "shift on the fly feature" that's probably the area to look at, that electrical circuit. There is often a solenoid and/or a little motor that engages the transfer case. This is where I would look first.
Does anyone have the time to post the TBS itself so we can see what's up?
The seals fail, causing the hubs not to engage. When I was with the Chrysler/Kia store, we did bunches of them. Most Kia dealers treat them as silent recalls.
Anyway, that makes sense.
I can't believe I used the word "thingy", but what else to you call the whatchahoosit that's inside the hub cover?
Dennis Rodman's getting back into the NBA? First I'd heard of it, but then I usually stay away from the "sensationalist" news stories.
I have heard stories about '98-'00 Sportages getting the new hubs...so, anyone who has hub problems might want to give this a try.
