Subaru Outback: Catastrophic Engine Failure at 70K Miles---Need Advice!
I looked into rebuilt engines but they are few and cost was about the same as having the dealer do it.
I looked into used engines but here were very few that were useable and once again the cost after freight and everything else was about the same as dealer rebuild. I did find out that almost all of the 2.5L engines available as “used” were listed as having some sort of timing belt damage!!!! Call a junk yard that uses a national parts finder, and check for yourself.
I would have had the dealership do the work if, Subaru would have offered some “Good Will” to restore my confidence in the quality of the engine, but they choose not to do so. Being true to my word I will never spend one more cent on any Subaru products, including parts. I think their decision was, “penny wise, but pound foolish”.
The up side to this situation is that, I found one junk yard that was willing to give me way more than I thought I would get for it. With the money I would have put into the rebuild, the money I got from the junk yard and all the buyer incentives out there, I think a new car might be more affordable than I earlier thought. With Subaru out of the running shopping should be a snap.
For anyone interested, the car is at a junk yard in St. Louis. They specialize in “modern imports”. There are a lot of good parts, heated seats, tow hitch, tires w/only about 10k on them, cargo mat, rear break rotors just resurfaced, engine block heater, hood w/scoop, spare tire never used....etc.
Thanks to those who offered insight.
Good luck shopping. I'd really suggest picking a very reliable brand and then getting an extended warranty as well. So many things can go wrong with modern cars, even reliable brands are a toss up. Toyota had sludge, Honda has those tranny issues, every make has its share of problems.
Good luck with your next vehicle.
-juice
If an engine is in serious distress, it disintegrates pretty quickly.
-juice
Good luck
To the other valve problem, can you tell me if the bent valves were all on the side of the engine that didn't have a true head gasket? I think the possibility of coolant leaking into the cylinders on that side is quite possible. Yeah, it would be amazing that it lasted that long without a good seal, but silicone can fail over time quicker than a proper gasket. That's why they make proper gaskets and don't suggest just using silicone.
DaveM
Every engine requires some kind of maintenance. Most high compression, overhead cam engines are "interference" engines.
Gates rubber has a list of interference engine applications at http://www.gates.com/downloads/download2_common.cfm?file=31-2020P- CCD.pdf&folder=brochure&CFID=1128154&CFTOKEN=5942664 .
It is a little out of date, but many new vehicles are using the same engines, or upgraded version of the same engines.
Curiously, the Subaru 2.5 boxer engine is not listed as an "interference engine".
Good luck,
gearhead4
DaveM
Non-interference means it won't. You'll still stall and need a tow truck, but it'll be much, much cheaper to repair.
Note - the 2.5l calls for an "inspection" at 90k miles. Given the labor involved, I plan to go ahead and change it at 90k.
-juice
Anyway good luck to all.
DaveM
-juice
