1999 Siverado Locking Deferential
I have a 1999 Silverado that came with a locking
rear deferential. I know what locking and limited
slip are, and my truck acts as though it really has
only limited slip and not a locker as advertised
in the options list. This is one option that I did
not research real well. With out getting the axle
tag off the truck, does anyone know what this axle
should really be or what Chevy advertises it as?
Does Chevy just say this axle has locker
capability, when in actuality it is just limited
slip? I would expect a button on the inside that
would turn off/on a locking deferential.
My best seat of the pants explanation is that the locker has a sharper (jolt?) engagement than a clutch type limited slip.
While playing rally truck this weekend, was able to get locker engagement at speeds up to and exceeding 50mph. Doubt there is anything in the locker to disengage it at speeds over 15mph.
Does anyone know of one that does? Even the Jeeps that claimed "full time" true 4WD only had 3 wheels with traction at one time. How would you turn the vehicle in 4WD if they did?
This is my understanding,
Mike Freeman
The front does not "lock", it engages the front drive axle and the hubs. This is different than having a "locking front diff" where "both" front wheels "drive" the momentum of the truck.
Did I explain that very well?
Correction... the rear drive shaft needs to turn slower in a turn.
My question is - if there isn't a front differential, how could the two front wheels NOT be locked?
It does seem logical to me that every 4x4 has a front differential, although the terminology may change.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
