2000 GMC sierra steering pulls right
My 2000 GMC sierra 4wd pulls to the right. Dealer
says there is nothing they can do! I drove another
2000 and it does the same thing.
Later,
Mike Freeman
Initially set at the factory - but can get out of wack when driving over bumpy roads. Can range from mild to frustrating as hell.
If you notice it on the test drive make the adjustment part of the agreement to buy.....
why do you say that they are supposed to pull to the right?
tuckyboy
What I've learned: All things being equal, steering will have a tendency to pull in the direction of the more positive camber of your front two wheels. The crown of the road accentuates this by causing more wear on your right front tire outside edge. Cross your tires to the opposite side, on the same axle, and your pull will go the other way, or neutralize. If it doesn't, and the alignment is good, the tire dealer will replace your tires under the factory tire warranty.
i think that thats what it is supposed to be, thats the way i was taught about it, but i may be wrong
I did this and it was indeed out of alignment. The mechanic corrected it and on the retesting it still pulled to the right. He rechecked it on the machine and the alignment was right on the money. I know as I was looking over his shoulder.
He swapped the front tires and the problem went away. The tires were Firestone. He could offer no reason for this problem.
However, the truck runs ok now. Was the only problem that I have had with it.
Am quite happy with my purchase.
Got it back from dealer today. One ball joint was falling out and had to be replaced. Dealer replaced front tires too (570 miles)for good measure. Steers and drives perfectly now.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
