Problem starting car
We own a 1995 Volvo 940 with 86,000 miles. During this summer, on several occasions, the car hasn't started after sitting in the hot sun for the day. The next morning (when it's cooler) the car starts. The engine sounds and we can smell the gas when we try and start it, but our mechanic says he can not fix it unless the problem of not starting happens while it's at the shop. I've tried to have it towed to the garage, but each time the car starts before the mechanic can look at it. He's checked everything out while its running and says its all in working order. Does this sound like an electrical problem? Or (sounds unlikely, but) something related to the heat? Any ideas?
One trick I've learned is to ask the parts counterman if he sells a lot of ignition parts and if so which one?
I have a 92 mits mirage..last year I let the car sit for four days during 4th of july. car wouldn't crank or anything, it was corrosion on the connectors.
cute... Mitsu Mirage battery terminals love to corrode. This has happened on my sister's '93 Plymouth Colt on several occasions, causing nothing to work, or the car to start. Right now, they're corroded again, and are about to get cleaned.
Had an unfortunate experience with the repair at Jaffarian Volvo in Haverhill, MA. They claimed the repair took 4 hours and overcharged by 3-1/2 hours times a hefty labor rate. Be interested to hear how you make out.
