Accord Stuck in park
louisianna
Member Posts: 5
My 1994 honda accord only has 88,000 miles on it and i've had so many problems with it in the last month alone! Now it's stuck in park and I can't get out! Yes, i've done the parking brake thing, i've tried pumping the brakes, turning the steering wheel, and the key lock thing - nothing. Just stuck. I'm just hoping it's not the transmission - it doesn't have that many miles on it. Is anybody else having this problem and if it is the transimission - it it worth even fixing or should I just get rid of it?
I have heard that it may be that our tailight(s) are burned out, and that this is a "safety feature". I am going to see if they are tonight. Also, there may be a cable or solenoid that needs adjusting. I will call a mechanic or two tomorrow and let you know what I find out. In the mean time, you can still drive it by using the shift lock mechanism to shift into neutral before starting, than just shift into drive or reverse normally.
The fix for my problem ended up being a $29 brake light switch from Checkers Auto Parts. Thankfully the first thing I tried ended up fixing the problem! The mechanics I called all wanted around $150 for this simple job. I just unhooked the old one and snapped in and adjusted the new one. Wallah, now it shifts out of park normally and the brake lights work. Thanks for the ideas...
Louisianna--
How much $ have you put into the accord lately? It seems like it should have nearly half of its life left (mileage wise), assuming you don't have a lemon or it hasn't been maintained. New cars may look nice, but I figured I'd have to spend mor than $2000 in repairs a year to make it worth it to buy a new car (new car cost, interest on loan, higher insurance, etc.).
