Mazda RX-8 Owners FAQ
Share any RX-8 FAQs here.
Anyone?
And appearances I guess I could see, but I think they're ugly... like pieces of trash that got caught under the car while driving.
Wonder if I should just remove them, and what they would affect. Hmmmmmmmm.
Thoughts, anyone?
For a sports car, it is great. I am sure an investment in good performance winter grip tires will keep you upright between the ditches....
I recently bought a new RX-8, 6-speed manual and I am very happy with it.
I have a couple of questions though, I hope someone can help.
It's been quite a few years since I've driven a stick, and I'm pretty rusty.
First question: Quite often I'm not sure what gear I'm in so I keep a close eye on the tach. At freeway speeds, say 65-70 mph, if the engine is turning around 3500 rpm, am I in 6th gear?
Secondly, I seem to have a problem going from fourth to fifth. Quite often the revs increase, so I must be going back into 3rd, I guess. Not to worry, I've never overrevved the engine, I got as high as 5000 rpm so I shifted back to fourth. Any tips on going from fourth to fifth gear? Do I move the shifter to the right and then up? It seems to balk when I try to go to the upper right & that's when I think I'm going into 3rd gear by mistake.
I would appreciate any advice - thank you. Phil
To answer your first question I have had mine going 65-70 mph in 3rd pushing about 5500rpm with plenty of room to still get up and go. So it sounds like you are in 6th to me. But with high revs means low gas mileage. But anyways it is probably the best looking and overall car I have very owned. Very pleased driver, super pleasant dealership too, they even called me saturday to check up on me and how I have enjoyed my purchase so far. Great customer service I give the an A+ for it.
Caleb
Thanks for responding. Prior to reading this, first thing after I got up this morning, I slapped myself upside the head & thought - "get in the car and practice shifting!". So that's what I did, in the garage with the engine off, out of the Arizona heat & it's what I suspected & you are correct, fifth is to the right, then up. I'll never forget it now - had I not had a brain cramp I probably would have resolved this weeks ago and never posted, haha.
Another thing I discovered, the car has a warning sensor for tire pressure, it went off about a week ago, Mazda sets the timing beeper at 28 pounds. I called the dealer, they said to set them at 35 pounds (the owner's manual says 32 but the dealer should know best (I hope).
Thanks again for your help Caleb & enjoy your RX-8 - I love mine!!
Phil
As far as shifting from 4th to 5th, this was my first 6-speed, and I too had difficulty. It just takes time and practice to get used to the feel of shifting this car. Over-all it is one of the smoothest shifting vehicles i have driven. Good luck.
As for shifting from 4th to 5th, you're right - I'm gradually getting better. It seems a bit vague to me still. This morning I consciously tried going to the right, then up to 5th, I still wasn't sure until I looked at the tach and the RPMs had decreased - so I was there. Practice will cure this, I'm confident.
Good luck to you & enjoy your RX-8 - it's a terrific car & a real head-turner.
Back in March, I was looking at the G35 coupe, 350z, S2000, and Porsche Boxster--and i came away impressed with the Rx8's looks,comfort, handling, and backseat roominess. I was most impressed with its manual transmission. The 6 speed configuration is a bit different than the standard 5 speed=and it takes just a little practice to feel comfortable. Compared to my old so called- "reliable" cars--this car shifts much smoother. EVEN better--it is a head turner--
For future RX-8 owners:
I know Mazda is coming out with a higher horsepower automatic in '06, but I continue to recommend the manual for those that expect decent/-excellent performance. Believe me-There will be a higher demand from our younger "fast and furious Crowd" of second hand buyers seeking manuals 2-4 years from our original purchase.
Flipper, I hope you enjoy your car as well!
I'm giving serious consideration to purchasing an RX-8, though probably not the Shinka ($$), and have been pretty impressed at what I've found in my research.
I noticed on the Mazda website that they recommend the use of premium gas for the RX-8. Is "recommend" the same as "require"? Has anyone here driven one using regular, unleaded gas? If so, have you noticed any problems? With today's gas prices, I hate the idea of using premium!
I also have heard that the rotary engine burns quite a bit of oil and that one might have to put oil into it between regular oil changes. This I could live with, but I was wondering if this were true.
The rotary has always injected oil into the intake to lubricate the apex seals (equivalent to piston rings). They inject a little more than required to be safe, so hence the notion it burns a lot. If you run at lower RPMs you will go through to the next oil change without adding any - though it will be at the "min" line. If you "play" frequently, you may have to add 1/2 qt. between changes. Most owners check it every 3 fillups or so. It will warn you long before it's a problem (oil light is very sensitive). Most carry a qt. in the trunk. The oil pan carries a lot of oil - it can hold up to 7 litres, though only 5 are called for in the service manual.
BTW, oil is now less expensive than gas!
Maybe it's time for a diesel rotary!
Hi and welcome to the forum, I am new also, I purchased a new RX-8 6-speed manual in late June.
Yes, gas prices are awful but I've been using super unleaded - I figure it this way:
The gas tank holds approximately 15.9 gallons - if it's bone-dry when you fill up, it will cost you 20 cents extra per gallon over the cost of regular so that's roughly $3 per fillup. I'm sticking with Mazda's recommendation - unless you do a LOT of driving, $3 per tank is reasonable considering it's a terrific sports car that you're likely to fall in love with immediately.
As for oil, I've yet to need a quart, according to my dealer I may need to add a quart about every 6 tanks or so of gas. I think it will depend somewhat on whether you're a conservative driver or a leadfoot.
If you choose to get the RX-8, best of luck with it and enjoy it!
Phil
When you put it in terms of $3-4 extra per tank, it doesn't sound so bad. Of course, with more frequent stops for gas (relatively small tank) and low mpg, it may add up in the long run. But perhaps it won't be as bad as I had originally thought.
I've been considering the RX-8 and Mustang (and perhaps the Eclipse), but really am leaning towards the RX-8, so I'm just trying to weigh my options.
I've had mine since last Oct. and I used to screw up 4-5 sometimes, but I found the easiest way is to push it at a diagonal forward and away from you. It is an awesome car
btw, you are in 6th if you're goin 65 @ 3500 rpm's
Gas saving tip: a second intake port opens when you go above 3750 so if you keep it under there (72 in 6th) you'll get slightly better mileage
DO NOT buy this car if you live and a wintry-area and dont have another alternative!! Luckily we have another car, and I love it for the summertime.
I have never had to add oil, and always use premium - although who knows with the rising gas prices...i may put it up on bricks for it's bad mileage!
I'm Canadian. The Nokians are made by Fins. You have to know all season tires made by people who live in their or our climate have to be good on ice and snow!
my rx-8 has 225.45/18's on it.
does nokian make a tire to fit?
did you change the wheels?
Peter
Talk to a Nokian dealer for your options. The replacement wheels don't have the tire pressure monitors, but all that means is you will have a light on during the winter driving season.
The Pirellis are significantly less costly than other brands, Maxda would do well to sell these tires as factory installed tires on the RX 8 which has a notorious reputation for winter driving capabilities. The wide profile may be a disadvantage, however the cost may be prohibitive if you also invest in thinner wheels- however this would disable the computer controlled Dynamic Stability Control.,
The all season Avon's have 90% of traction of the performance tires and 90% of the traction of the snow tires. They cost less than half as much, and the tread wear on the Avon all season is 360 vs 180 for the performance originals or the non-rated snow tires which simply melt away it seems.
All seasons are very quiet compared to the performance, so on the highway at high speed, on good road, there's very little tire noise.
I use premium gas (why skimp?) I generally drive in city traffic and get around 19-20 mpg. I am not hard on the car, but I give it a run once in a while.
