Honda S1000: Build it? Bring it? What is it?
                    The most recent issue of Road&Track has a short blurb and picture of a new Honda concept.  It's a tiny roadster with styling related to the S2000.  Another similarity is the engine, which is reported to be a high-revving, 4 cylinder, 1 liter (yes, very small) block mounted up front.  Output was quoted at 120 horses.  That's quite a bit lower than the Miata or anything else on our market, but the vehicle is expected to weigh only 2,000 lbs.  R&T labeled it as a 2006 design.
Should they build it? Should they bring it over here? Does anyone have any more details on this little rascal?
Also, the S1K is FWD. It's more like a Del Sol done properly than a scaled down S2K.
FWIW, this is my review of the Miata. varmint "Town Hall Test Drive Team" Jun 24, 2003 5:57pm In the part where I compare it with the S2K, you'll see my reasoning for why Honda should bring this S1K over here. The S2K is wonderful as a high speed kamikaze machine, but the Miata is able to dance at lower speeds. I'm thinking that the 2,000 lbs S1K would be more tossable.
I think the S1000 represents the potential for dirt cheap fun. Much like the CRX. This car could do for Honda what the Civic Si has failed to do. The S1000 could become the darling of the tuners and aftermarket crowd. It might be a good halo car for the youth brand Honda is considering.
While fully loaded Miatas can sticker at $28k, you can actually buy them for $22k. (and the color of the 2003 SE is amazing) And you can get a stripped Miata for about $17,000.
I like the idea of the S1000, as long as it's a 4 cylinder, not 3, and light enough. The CRX Si is sorely missed, IMO, nothing since has been able to take its place in enthusiasts' hearts.
I'm not worried about Escalades because I avoid congestion and stick to 2 lanes. I doubt you'd be any better off in an S2000 to be honest, you're road kill either way.
So one vote in favor, yes, definitely bring the S1000. Keep a cap on prices and build it in the spirit of the CRX Si (light, spunky, affordable, and fun), not the del Sol.
-juice
http://www.honda-club-ems-jade.de/Honda%20News/S1000/s1000.html
Been a while since this thread was started... Since then, Honda has stated that they will not be following Toyota in creating a youth-oriented brand name like Scion. I have also not seen any other publication or concept car that resembles the S1K.
That said, I stick by my original assessment. The S1K, or something like it, could become the next el-cheapo performance icon and a tuner's delight. Clearly, Ford and Dodge have latched onto the hot-hatch market that the Civic Si once dominated. Subaru and Mitsubishi have become lords of the not-quite-cheap performance arena. The S1K would provide something fresh for the cheapest end of the spectrum.
Miatas have gained weight over the years. Early ones were 2200 lbs, now they hit 2400+ lbs loaded up. The MR2 weighs 2195 lbs, and that article says the Honda would weigh in at about 2000 lbs.
If so, the 120hp would be perfectly fine. My Miata has just 116hp and weighs 10% more, and it's no slouch.
Well under $20k sounds good. They could do it, how much does a 1.0l engine cost to make? The Civic Si is selling slowly, so let it replace that model in the Honda lineup, for about the same price even.
Build it! :-)
-juice
Insight has the batteries that add a lot of the weight. I bet minus those it's a featherweight.
-juice
