Tires for infiniti G35 coupe
Which replacement tires will be best when time comes. I feel as though I will have to mortgage my house considering the price of these tires. Seems like prices range from about $175 per to 275 Per tire, and they can't be rotated because different sizes front and rear. How many miles can we expect to get out of a set of tires?
Tires make up 85-90% of what's possible from a vehicle.
Directional tires while offering a 2-3% improvement in certain wet braking situations are the bame of mankind.
In order to optimize wear [minimize heel toe feathering] the directional tires will have to be demounted and flipped on opposite rims every 3,000-7,500 miles depending on exactness of alignment and your roads. Exactness of camber and toe alignment is critical as is the proper inflation adjusted as the ambient temperature changes.
Tire balance must be set every 3 months on a Hunter 9700 radial force machine.
This sport coupe will require lots of precision and perfection to maintain as new performance.
Nissan has brought the COST/benefits of performance down to the masses [in a $33k car].
Owners driving style has a lot to do with tire life but the average should be around 23,000 miles with some getting 12k and some 30k.
The Michelin Pilot Sports are as good as you can get.
Don't worry the Koreans and Chinese will come out with cheap tires in yours sizes.......just don't follow too close or speed in the rain.
We see this all the time as the 1990-2002 Q45 came with the most expensive highest performance tire money could buy. Cheap owners substitute cheap tires and live or die with the consequences.
This whole 18" - 22 " tire wheel thing is so "bling bling" [brake rotor sizes can usually be accomidiated by 17" wheels and tires]
I have read that the Bridgestone S-03 Pole Position tires are a good alternative to the OEM Michelin's. They can be purchased at Costco for about $50 less per tire than the Michelins. I hope this helps.
Checked out the new Bridgestone RE-750 specs on Tire Rack (have had three sets of RE-71/RE-730 17" tires on my TRD Solara - good tire for the money). Wear rating is 340. But the closest sizes are /40s, which gives a minus ~3.5% speedo error and a harsher ride. Grippy, though, and don't squeal and chirp in hard use like Michelins. Set of 4 ~$630.
Also checked out the Goodyear Eagle F1 GS-D3. Highly rated - performance similar to the S-03 and Pilot Sport. Offer the same /45 rear size, but you have to settle for /40s in the front. (At least no speedo error). Wear rating 280. Set of 4 ~$740.
Then there's the Toyo Proxes T1-S. (These are shaved 50% and used as the race tire for the Speed World Challenge Touring Car series.) Have to settle for /40s on the front. Wear rating 280. Internet price at Frisby Tire for set of 4 ~$1000.
Tire costs for this car could equal insurance costs!
You're right I should have just stuck with LOW COST vs being specific.
US, UK, Japanese, French, German, Malaysian, Finnish, Indian, and Italian companies make some horrible cheap tires also! Everybody does to be competitive at the bottom and middle price ranges.
You can find $25, $50, $75, $100, $135 each tires in the 15" size. Retail cost doesn't always reflect quality on every tire.......but everybody's most expensive tire is probably satisfactory for most drivers.
AS long as the tires meet OEM PLACARD: load rating, size, and speed rating your insurance company should stand behind you and not refuse coverage for improper or illegal fitment.
I suggest members consult:
http://www.tirerack.com/tires/surveyresults/index.jsp</a
or Tire Dealer or Tire Retailer magazine which have annual surveys of quality and uniformity as view by the sellers of tires.
Shifty the Host
Again, I don't know the validity of this story, but will try it out next time I need some tires for my 6MT Coupe.
