Dodge Dilemma
I have a buying problem that maybe some of the wise sages here could help with. I am considering purchasing a Dodge Ram. I have two I am considering and both have good and bad.
One is a 99 Ram 1500, 2 whl. drive, extended cab, 5.27L V-8 with 53272 miles. It has the basic accessories, but nothing fancy(pwr windows, pwr.locks, etc). The body is in great shape except a dent in the back fender. They are asking $13995.00. If I bought this one, I would get 4.7% financing for 4 of 4.5 years. It has a 50/50 1 month warranty from the dealer.
The second one is a 97 Ram 1500 SLT 4X4, extended cab with a 5.9L V-8. It has all the bells and whistles (pwr. widows, locks and seats, am/fm-cd, alloy wheels, ac, cruise, tilt wheel, bed liner). The body is flawless except a small flaw in the chrome bumper. It has 66000 miles and comes with 100/100 3 month warranty from the dealer. They are asking $12888.00 for it, but I would pay 5.9% interest for the same time period.
Which should I go for? I am torn both ways. Any advice from present Dodge truck owners would help in this decision.
Thanks for help.
Thanks for help.
I have heard you may do alright if you go with a manual transmission. If one of these trucks comes with a manual, that would be my deciding factor. If a manual can't be had, I would look at something else.
BTW, have you looked at any new trucks? Especially with the economy right now, and this being the time of the year to buy a 2003, you may be surprised how easily you could slide into something new. Those prices for the Dodges seem awfully high to me. Do some research before you buy.
Just my $.02
Dodge has had problems with automatic transmissions in the past but a large portion of the problem was lack of maintenance or use of the wrong type of transmission fluid. I have had 7 Dodge vehicles over the years and NEVER had a transmission problem! I do routine maintenance according to the owners manual for severe service.
(When someone dislikes a particular brand any example of a problem serves as reinforcement of their biased beliefs. Since the majority of people in my family own GM and Ford products, I can tell you that transmission failures are most certainly not unique to Dodge.)
My experience is that automatic transmission problems are most often linked to the type of service, use, and/or maintenance specific to that vehicle. It is true that from about 1989 to 1997 Dodge truck transmission failure rates were higher than industry average. This was due to two major areas: a component quality issue with shift solenoid packs, and marginal fluid flow to the overdrive unit in the transmission.
The basic "RE" series of Dodge trannsmissions are based on the A904 (smaller version) and the A727 (larger version) of the 1960s, both extremely rugged and reliable designs. When Dodge modified this series to incorporate overdrive in the late "80s, they did experience higher failures when used for towing and snowplowing, and exacerbated by conditions of low temperature operation. As noted above by another contributor, a fairly large portion of the failures in Dodge truck (RE) series was the result of incorrect automatic transmission fluid being used. Mercon should not be used in Dodge truck transmissions.
In 1998 the "RE" series received a number of fairly significant upgrades to the design which resolved any reliability issues. The "RE" series now has a lower repair rate that their competition.
The 545RFE transmission which was introduced in '00 (2001 in Dodge RAMs)is totally new and has proven to be a solid and extremely reliable design. There are very few reported problems with this transmission, and even fewer failures.
Best regards,
Dusty
Thanks again for your replies,
Happy truckin,
Mike M.
