Towing restrictions on the Titan
                    I see that the Nissan Titan will tow about 9400 lbs (I've also seen 9500 mentioned).  Considering this is a 1/2 ton, will this tow a 5th wheel?
The 5th wheel weighs 7500 lbs dry and probably under 9000 loaded.
FYI, Ford says DO NOT tow a 5th wheel with the new F150, as it will most likely void the warrantee.
Thx in advance for the help.
I dont think a short bed would be a good idea for 5th wheeling
Harry
My wife will not trade the Jeep for a truck. She just doesn't want to have the image associated with driving a truck. (I don't blame her). So, if we get a truck, it will have to be me trading in my Infiniti G35 for a truck. Which is why I want a decent riding truck.
There are many weight ratings on any given truck. But the three that you need to be most concerned with is GAWR (Gross Axle Weight Rating), GVWR (Gross Vehicle Weight Rating) and GCWR (Gross Combined Weight Rating). The GAWR is the max that can be loaded onto that axle. The GVWR is the max the vehicle can weigh. The GCWR is the max both the vehicle and trailer can weigh. If you go over anyone of these three, then you are overweight.
Sorry can't let that go without asking you to explain. What truck image? The function over form practicality perhaps.
As opposed to the grand Cherokee (nice suv btw) which for most owners never gets within 10 miles of "off roading", seats no more than a sedan getting nearly twice the mpg, etc. etc. At least the truck says "useful, practical, modest, etc."
Lastly, the new F-150 claims over 9,000 lbs max GVRW in most configurations
So the truck will do the job, however, before you lay down the cash, check out the fact that max. payload @ #1650 for the supercab 144.5" wb. This is best-in-class for a 1/2 ton, but get that tounge weight of the fiver and figure out what else you are going to have in or on the truck for additional accessories and people. I've seen far too many people who chronically over-load for the job that needs to be done.
I actually selected my last trailer by taking a few I was considering to a scale, hooked to my truck with all passengers, then calculated my reserve for water, waste, LP gas, groceries, camping gear, etc. You have a huge consideration for the safety of yourself, your family and others on the road in an emergency stopping or manuvering situation. You really do need at least a 3/4 ton to do the job.
To address the 5th wheel issue in a 1/2 ton, the warranty issue would apply to any vehicle when it comes to altering or modifying the chassis, such as a 5th wheel installation, and the risk the manufacurer doesn't want to bear in the event that you cause subsequent damage to the vehicle, you or others.
It was full of metal particles and they wanted to tear it down, I said ok only if my Ryan extended warranty would cover it. Ryan proceeded to send a rep to look at it and report his findings. The flywheel flex plate gearteeth were also broken due to a bad starter.
Ryan wanted to pay for nothing on my 0 ded policy.
After a heated discussion on the phone they agreed to pay for the gear and labor. After calling a local tv station the dealer agreed to pay for the transmisssion parts. I still owed $790. All the problems with this 150 with 60k on it there will be no more Fords for me, nor any other Detroit iron. Don't buy a Ryan warranty which is next to worthless.
First, I don't know of any truck that has been used for 60k that wouldn't have some metal shavings in the pan, they all do, it's a moving part that has slip built into it and thus wears.
Kinda like the rubber or leather that wears off the bottom of your shoes. As for the starter gear, ditto. That's why a transmission flush is worth the trouble every 30k to reduce that contamination from causing more wear than need be.
Second, guess you learned the hard way, like me, that unless it has the manufacturer's name on it, extended service plans from others companies are usually worth about as much as the paper they are printed on. I still won't own a vehicle past the original warranty without a service contract. Just read the fine print if not from the manufacturer who's name is on the back of the vehicle.
Too bad you're not considering the all new '04 F150, it really is shoulders above anything else on the road in about every aspect.
offering 10 yr. 100,000 mile warranties on SUVs the race is really on.
Companys like Ford can use lesser grades of steel on drive train gears and other parts, why not, they only have to last 3 yrs.
People cannot afford to play the obsolescense game as Detroit has so well done in the past.
Coming out with a redesigned F150 is a call to arms by Ford but that warranty will have to change
drasticly and they will have to be serious about it. Where did you find the improvements in the 2004 so encouraging?
Will Nissan change Titan's number? again, too?
Any way, if you go by the numbers, the new F150 should be your best bet.
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
Read this story in USA Today.
