Dakota Axle Ratios---Help!!!
I am trying to order a 2000 4x4 Club Cab Dakota
with a 4.7,5speed, and 3.55 axle. There is a
restriction now on this setup. They are telling me
I have to get a 3.92. How bad will this hurt my
mileage? Or will the overdrive in the 5speed be
okay with a 3.92? Should I just give in and buy the
automatic? They said this restriction may not be
lifted. I was a little scared of the automatic
after reading about some of the problems with them.
Then again, I heard there wasn't a problem with
the 4.7 and this automatic. I need some advice
here.
here.
Can't think of any problems with 3.92 and a 5 speed - its what I have, and you should see my grin.
Automatic is out of the Grand Cherokee as well as the 4.7. Have a look in the SUV conference - looks like everyone loves the engine but still transmission problems.
Thanks for any advice..........
I personlly enjoy shifting a machine that has a little power to it. I simply can't help it if everyone else wants to just sit in it and take a ride. It's just not the same thing. If I could go back one more here. I don't understand completely why someone would like to just sit in a vehicle that has all this potential to really scream and put an automatic behind it?! Now I do relize that they do make automatics today that can contest the best power shifting person. But you just can't beat the thrill of how the 5sp can run.
I also relize the resale of this truck most likely won't go as fast as one with the auto. But there again so what! I just would not be happy with a truck like this myself and a auto.
I am getting a little used to that concept though. Years ago I ordered a corvette. Ha the dealer looked at me strangely when I told him I wanted a 4sp. with it. He said I was the first one in 3 yrs. to order one like that. But you see in my line of thinking if it's a machine that is going to really run don't handicap it with an automatic. No offense meant to anyone that has one with an auto. It's just where I come from and what I personally enjoy about driving.
Good luck in your decision making process.
Jim
Secondly I live in rural Ontario, where the weather isn't exactly known for its pleasantness 5 months of the year. In addition I dog sled and so I drive in some pretty inhospitable areas. They haven't made an auto yet that gives as much control in foul weather as a stick.
Definitely had to order, I actually bought before 2000s were officially released in Canada so dealer did a search in Ontario & Quebec to try and find a 99 that matched my spec - no standards.
I use my truck for daily driving, carrying dogs, sleds, quads and snowmobiles and towing a 23' boat (around 4,000#). Periodically pull overconfident drivers out of ditches in bad weather too. Incidentally on this subject, first bad storm last week, almost didn't throw a chain in the back. Good job I did, F150 4x2 managed to put its back end in a ditch and ground the differential. Scary part - it had a plough on the front, really scary part - it belonged to the town!!
Resale doesn't bother me too much, especially here where standards aren't that uncommon. Sure the price will be lower than an auto, but so was the cost - and mean time I drive what I want.
I notice you mentioned Tacoma, not sure which is a better comparison for Dakota, Tacoma or Tundra, and I don't want to start a debate on it. BUT, anyone reading this considering buying a Tacoma - the star rating for side impact just came out for the 2000 Tacoma - one star. Think about it! Tundra figures not due yet, and no more tests planned for Dakota because nothing has fundamentally changed.
Thanks again
My very first tank of gas was 16.9 MPG and this is during break-in with very little use of the OD 5th gear. It can only get better!
Besides, My (extensive) research into this powertrain tells me that the 45RFE automatic is still experiencing "teething-pains" and I did not want to be a guinea pig.
I have been reading some different sites to see what other Dakota owner's have been doing to improve mileage and performance. Looks like a new airfiltration sys. and exhaust would certainly improve on these figures for another 3-4 mpg.
bpeeples You are right that you can get better mpg. from your 5 sp. The only reason this dosn't always happen because we or I should say I don't drive em for economy. I like to put my foot in it and have it wind out a little.I belive that I'm not alone in this. It's a problem I've had since I was 16 I guess. An auto just goes the same way all the time. The engine will run at the same rpm all the time. Much less likely to be wound out like you would with the 5 sp. Looks like your getting good milage. What size tires does your Dakota have?
Jim
I am guessing my mileage at around 15-16 now, that's with the 3.92 and 31x10.5 as well as being a 4x4 V8. Also remember that mileage will improve slightly as the truck breaks in.
Now if you want to max out on economy equipment - 3.55 rear end, 4x2 etc then you will probably get close to 17, maybe better. Also if you want to improve with aftermarket then probably air filter is the biggest bang for your buck - K&N is always the name that gets mentioned.
Bottom line if you want a truck like the Dakota then you aren't going to get Honda Civic gas mileage, but I don't think that the figures are bad. After all, would you want the 4 cylinder just for economy?
Thanks........
PS. Is everyone happy with their 2000 dakota so far? Any complaints?
You can add an afermarket anti-sway bar, no problems. You can then get exactly what you want - though of course you will probably end up paying a little more. Still if you are thinking about customizing your wheels / tires this may not be a big deal.
Just a thought on that (sorry if this is obvious), don't forget to have the computer tweaked if you change your tire size.
I am very happy with my 2000. I have noticed the 'ticking' that is discussed at length in the Dakota topic, but I can't say it bothers me.
(dbarky)Sorry to hear about the 'restriction' on the 3.55 track-loc Diff. (I was told that that one HAS to get the Track-lok axle with the 4.7L and 5sp?)
I had the same delima with the "Handling package" and went ahead and got it. However, after ordering my Dak, I stopped by a local "customizing shop" and picked up 2 free catalogs just FILLED with cool Dodge 'stuff'. There are nice antisway bars available in NON-OEM market. I am quite impressed with the handling of the my 4x4 Dak. Do not forget this baby has RACK-n-PIONION steering for precise control over the positioning of the front wheels. My last real truck (1976 K10 Blazer) rode and drove like a TRUCK.
1. Quiet
a. no wind noise on interstate.
b. motor is very quiet.
c. no rattles squeaks.
d. no ticking (for me)
2. Handling
a.smooth enough to take refreshment
drink along.
b.has a very tight turning radius.
c.not a vette but I can take this
where I'd never take the vette.
3.Power
a. 4.7L @ 235hp is no slouch.
Sure there is room for improvement in my mind for the power but for what you get starting out isn't bad.
I don't order a new vehicle all the time but from my previous experience in the past I have always had problems with em from day one. This one I have had since 10/12/99. And I don't have any complaints at all with the Dakota.
bpeeples no comparison with a 1976 Blazer 4x4. If I remember back then you would have to pick your stomach up off the floor after a ride in one of them. I would compare this more to one of a more luxurious cars for the ride. Not sure what I would say because that's another catagory to but I like it better than my wifes Aurora.
Jim
So far as I know you are the only one that has been able to get the 3.55 ratio. So just would like to know what th trac loc axle is since I had to go with the 3.92.
Jim
ratios in relation to the Dakota?
Much appreciated!
R.
Basically the axle ratio is the rate that drive shaft revolutions are translated into axle revolutions. The bigger the tire, the greater the circumference and therefore the further the vehicle travels for every axle revolution.
Obviously the further you travel per axle revolution, the greater the fuel economy.
So the maximum economy comes from the 3.55 rear end with the larger tires, alternately the 3.92 rear end with the 31x10.5 is close to the 3.55 with stock tires.
it stated 3.92 axle for 'no charge', that's what confused me. How can anything be for free and still be any advantage. Anyway, for my purposes, possibly towing a tent trailer, it doesn't sound like it matters much. But the acceleration...hmm.....
(See page 19 of 2000 Dakota sales brochure for details/restrictions)
I think that the different axle ratios are "no fee" but the optional payload rating is xtra cost.
I am paying 800.00 over invoice for a quad dakota, v8, 4x2, auto, loaded.
good luck,
robert
Don
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
