Thx
Rodranier
There's a chance it may be defective.
When you start up in the mornings, do you get a rattling noise from the engine? It reminds me of a timing chain tensioning issue. Once oil is up and circulating it quiets down...takes about 5-7 seconds. I am getting a little concerned about it now. The truck has about 150K miles on it.
Thx
Thx
It does not seem to be damaging anything but it is anoying. I changed the timing chain on my engine at about 100k miles and it still does it, no change. I guess we just live with it.
Austin
I am very new to car ownership. I bought this truck 3 weeks ago. The mileage on this truck is 92,000 miles. Since I am new at owning a car, what steps should I take to insure the this truck is well maintained? So far the motor of the washer fluid is burnt out since it does not operate. This makes me think I should go to an auto repair shop to ask for a full inspection. However, since I haev never done this before, what should I ask the mechanic? I want a full inspection/diagnostic to identify key problems and potential problems in the future. How do I go about this and what price should I expect? I live in the monterey, Ca area so the truck is at high risk of rust with the salt water from the ocean. Your assistance is greatly appreciated.
And you'll want to check to see when the engine oil was last changed, as well as the transmission oil and the transfer case oil too if it's a 4x4.
Check the coolant and brakes too. You might check the spark plugs if they're easy to get at and look at the spark plug and coil wire set too, but if she's running well I wouldn't be too concerned with the plugs and wires.
Most any mechanic will know the basics of what needs to be checked. Have fun and good luck.
Any help would be appreciated...I love and miss my truck
PS: I am NO mechanic, obviously but I can do some things mechanical.
I'd never buy another Nissan again...
Comments anyone?
My sister has a '95 Nissan, as I recall, small pick-up with the 4 cylinder engine in it. It would only start and barely run with no power after I replaced the plugs, wires, distribuitor cap, and rotor. Cylinder compression is good, adn fuel pressure is also good. After replacing those tune up components, I hgot it started only after setting turning the distributor up against on of the stops, counterclockwise. But as soon as you put it in gear, the engine would die. Hence no power. It has a timing chain, and has 160,000 miles on it. Could it be any f the camshaft/crankshaft position sensors have failed? Or the ignition module, as no check engine light comes on? Or a stretched timing chain, or bad tensioner. It sort of did make a racket from the fron of the engine. A broken timing chain would not allow the engine to start at all, but a loose one would sure throw everything off. Any help would be appreciated. Thanks!
The only fix is to replace the timing chain and guides with a good QUALITY replacement kit. Don't do as I did and buy a cheap kit, you will just end up doing it all over again in a very few miles......
Good Luck!
Gary
Remove the valve cover and check the front sprocket on the valve cam, You should see a DOT on the cam near one of the teeth. At that point there should be an odd colored link in the timing chain that matches up with the DOT, If not the chain has probably jumped. This will require removing the front of the engine and installing a NEW timing chain kit.
Good Luck!
Gary
TIA
Dealer is outrageous,claiming they don't build them anymore.I don't want to spend more than the truck is worth.
Merry Christmas
