wondering if back pain was an issue. My back started to hurt after only a short test drive. I
wish the lumbar support was available on the 2wd model.
B4000 4X4 Extended Cab at the end of this year. I think they are sharp looking trucks, and Mazda has a reputation for making solid vehicles. Has anyone out there driven one with the 5 speed automatic? Will appreciate any feedback.
Great discussion...what kind of mileage are u getting with the 4.0 6? And where can I see the y2k trucks?
Thnks
zig
I agree with you. Again I refer back to my cousin's experience and a family friend's experience. They both have Mazda B-series trucks: 2500-2months and a 3000-4 years, respectively. The reason that they purchased the Mazda was because they went to both dealers and were given a total different price range. The choice between the two was not based on personal likings or experiences (since essentially they are identical), yet it was which would end up cheaper. The argument that Edmunds sets forth about the import parts being more expensive, is valid under a normal import vs. export battle, but I fail to see the point of that due to the fact that they are both built off of the same platform assembly line. Any problems related to the electrical, power trend etc. would be parts made in America. What's the deal Edmunds?
You are planning on buying what I bought 2 months ago. Mine has the 5 speed auto and works fine. The only problem so far is the driver seat started squeaking real bad so I pulled it out and lubed it and now everything is great. For everyone else I think the Mazda is a better buy than the Ranger. When you compare all the option the SE comes with against building a Ranger to the same specs the Ranger costs more. When I got mine the rebate was $750 more for the Mazda also.
I've noticed a slight knock in the driver door when I stop and start when the temp is greater than 80 degrees. I didn't hear it all winter, and now that it's getting hot here in Texas, it's back.
Anyone else ever get this?
My friend owns a b-3000, It is a 95. Everything works fine on the truck, including the doors. We live in South Beach, Miami. Temperatures get higher then 90 during spring, and summer is unbelieveable. My point is that most of the time it is 80+ and there is my problem.
My cousin has a 99 B-2500. The only problem that he faced was electrucal, which was fixed under warranty. He has mo problems with the doors so far, So sorry to say, you are the only person that I know with this problem.
My only recurring problem is with the front driver side wheel bearing (inner). I have replaced it 4 times since it first gave out at 76,000. Not a single problem with the passenger side. I have no idea what could be causing this bearing to wear prematurely and I wonder if anyone else out there has heard of this happening. I have had a complete 4 wheel computerized allignment and all the steering and front suspension components appear to be in perfect condition. I'm dumbfounded!!
danimal
The 3.0 motor seems pretty bad with the Auto.
Very poor performance, terrible mileage (17 hwy) and not very smooth. If it turns out that mine doesn't have some problem, like missing 2 or 3 cyl, I would not recommend this power train combo at all.
I considering a new chip, any opinions ?
Mine was the last of the Japanese Mazdas sold in America, but the rebadged Rangers are nothing to sneeze at. I like their styling better than Ford's, and prefer their warranty and option packages.
Thanks for the input,
The Merg
- The Merg
In 18,000 miles, I've had the front steering gear replaced once under warranty (it got creaky after long drives), but no other unscheduled work.
The black paint seems to chip and scratch easily...
I found the back support to be wanting, as mentioned in a previous post, so I bought a little velcro lumbar support from pepboys. Tada! No more back support problems - suddenly, it's as comfortable as any car I've owned.
The power steering pump is awfully loud, and I'm the second person here to mention it. Dealer says it's normal, but I'm taking a wait-and-see approach.
The tailgate's kinda squeaky. If I ever get off my lazy backside, I'll lube it and hope the noise goes away.
I've noticed the slippage at low speeds in first gear (as mentioned in a previous post) but I'm positive it's rear-wheel slippage. For a 4-cyl truck, this thing squeaks the rears with remarkably little effort - in fact, I've grabbed 2nd and 3rd with chirps when I'm pushing it. I blame the Firestones...great progressive breakaway in corners, but less than stellar traction for launches.
Regarding the above paragraph...for a 4 cyl, this is a fun little truck to drive in the city. Perky (with 5 speed, that is), handles great, looks great, great stereo and you don't see many of them around.
Last, but definately not least...when cold/wet, I've occasionally experienced brakes that grab on first application, or freeze on the rotor until broken loose with a little extra throttle. This has been mentioned in the Ford Ranger section, but not here. Anyone else having trouble with this?
All in all, still very happy with it and keeping it for at least three more years (unless my fiance convinces me to buy something with an automatic instead.)
I bought the Mazda because the warranty was better, and with the options that I wanted (A/C, 5spd, alloys, bedliner, sliding rear window, 4cyl, AM/FM/Cass, NOTHING else) it was notably cheaper than the Ford.
At the time, packaging discounts and option levels (at least in 1998) made the Ford the cheapest stripped model of the two AND the cheapest fully loaded model, but the Mazda could be optioned up to midrange for less than the Ford.
By the way - haven't had a lick of problems with my B-4000. I even added a K&N Air Filter and a Flowmaster exhaust. Not to mention the running boards and lighted lunar visor! An exceptional truck at an exceptional price!
5 speed Automatic Transmission and 17K has been
getting very SLOPPY - it no longer shifts smoothly at all. Has anyone seen this Problem!!
I am ready to bring to dealer but I am weary that they will balk, saying there is no problem.
when i first got it was difficult to discern shifts - now i can feel every gear 1st is especially bad. I will let you know how 128 mazda in wakefield ma, treats me!
Cap question: the bed of the 98 mazda is the same size as an older ranger - like 87, so caps made for that will fit. I know from experience here.
Thanks for the answer..
Just got the 99 B3000SE 2wd and my neck and back are killing me. Of course there is the recall on the cruise control and a short with the windshield wipers that have a mind of their own. I have a 2 door and getting in the back is a bear!!!!! Bring back the '94 style ....PLEASE!!!!!
Am now looking at F150 due to seating concerns. Looked at Dodge, GMC, and Toyota. Toyota comes close but the head rests are tilted forward. I don't want to go with a larger truck but I may have to.
Am ready to see if my old one is still on the lot!
sales rep. will not meet with me despite numerous
request to have a meeting. The truck is defected and the only explanation I get is "IT IS YOUR PROBLEM, YOU BOUGHT IT". I have tried to trade it in but no dealership will give me anything because I cannot convince them that it has not been wrecked. And for the record it has not been
wrecked. Mazda may make some good vehicles but when you get a bad one from them this is what kind of treatment you get. I will never own another Mazda if and when I ever get rid of this
one. That is a promise!!! To anyone who is looking
for a new vehicle I would strongly recommend that
they look elsewhere because Mazda does not follow through with any literature they print on their
product
Heath Guidry
Pineville,La
looking at a new Ranger or B-Series (2 wheel drive
X-Cab)but I'm not sure what engine would be good
for me. Most of the time the truck would be just
be used to drive to work and back with some light
hauling. Don't have anything to tow write now but
I would like to buy a small boat to tow in the
coming years. I was looking at the 2.5 liter but I
hear when you turn the a/c on you have no power.
The 3.0 liter seems to have mechanical problems (Is this correct?) and the 4.0 liter cost $1000 more is it worth the price. Also I like to drive a stick but I see the towing is almost double when
you have an automatic. Any other options I should
look for in my truck. This would be my first truck
so any help would be appreciated.
Thanks in advance
James
No "trouble" so far but the performance is really awful. No power, erratic acceleration (several flat spots). trany shifts whenever it feels like (upshift and downshift), terrible fuel economy (~18mpg) and sounds like a diesel.
On the positive side, the idle is very smooth.
Dealer will go through the checks but admits these are not very good motors.
I do know that I should have paid a few extra bucks for a Toyota....or Chevy or Nissan. This was my first and last Ford.
Update:
this is a report on the above problem:
Brought truck to dealership in Mass where i
bought it - 128 mazda imports - they fixed
it explaining that it needed a special lube
somewhere on the drive train. this was causing the slop in the drive train. not sure if they replaced any u-joints - they said they did but part does not appear on the receipt, so i don't think they did.
Good news is that it works as good as new and
i am again quite happy again with my b4000 auto 4L. I guess 4L is the way to go - this engine
is not geared to be quick (only 160hp), and the shifting was rather slow, but it has great tourqe,
and the best acceleration is at highway speeds..
However the service dept at 128 mazda was suspect -i had to leave the truck there over night for them to simply add some 'special' lube to this drive train joint (i presume the joint inside the boot on the drive shaft, right after transmission)
They said they damaged my side step and had to replace it. When actually they did not and just wanted to charge Mazda (under warranty) 200 bucks for a new side step
- stating "Customer complained about the finish on side steps" - this of course was a total lie! I was worried about other damage and checked out the side steps - when i realized nothing had been replaced at all only these guys milking the mazda warranty. Mazda you listening?
Anyway if anyone out there experiences a jolt/slop/non smooth shift in each gear you should
check this out. I will respond if this problems reappears and am still interested if anyone else has seen it.
I can't imagine any other reason they would have let this pathetic motor into the marketplace.
There may be a Turbocharger but before I spend $2500+. I would take my lumps on the sale and get a better truck.
Daved
frankc55@hotmail.com
PS: My first tank of gas returned 19.7 mpg. We'll see what the next tank does.
