Another words -- will it run on 'regular?"
clipper1,
Yes, the new Avalon will run on regular unleaded. The owners manual says:
"Select Octane Rating 87 or higher. For improved vehicle performance, the use of premium unleaded gasoline with an Octane Rating of 91 or higher is recommended."
Mackabee
There are European standards that require self-leveling.
NHTSA is requesting comments about HIDs including proposed solutions to the glare problem such as self-leveling devices. I could find no final ruling or even a proposed ruling.
NHTSA does have lighting standards that HID lights must work within.
For more information look at nhtsa.dot.gov and consumer reports.org
The earliest date I found at NHTSA regarding HID is 2001, so we may see a proposed rule any decade now.
"D.1. Assembled exclusively at Toyota Motor Manufacturing, Georgetown, Kentucky (TMMK).
a. engines built at TMMK.
II. All-new high-output 3.5L V6
A. 2GR-FE DOHC 4-valve V6
4c. Short-stroke variant of 1GR-FE 4.0L V6 from 4-Runner, Tacoma, Tundra
5. New 4-valve engine developed for this high-performance sedan."
They tried to install after-market XM radio in my Avalon with a separate display unit, but luckily they called me to confirm the placement of the display before they started working on the installation.
I hope this link still works..
http://tinyurl.com/5m94b
But as a new owner you should already know where the engine was made because the American Automobile Labeling Act requires every passenger vehicle sold in the US after 1994 to have a label, which among a number of requirements, must name "the country of origin of the engine and transmission", more on this can be found at
http://www.ita.doc.gov/td/auto/aala.html
"My only complaint with this engine is that there is almost too much torque on take-off, and without the optional traction control (which is only available on the XLS model), it's easy to spin the front tires, particularly on wet or slippery surfaces."
Given that I had a trade involved, trying to post an honest "buy" price would be challenging and even a little misleading because when there is a trade, determining what you get for a trade allowance can become a shell game. All I know is that I'm very happy with both the buying experience I had at Bernardi Toyota in Framingham, MA and the deal I got.
I have been a member of Edmunds discussion forum for about four years ( Toyota, Acura, Lexus ). In fact, Edmunds was very useful this past spring when I bought a 2004 Honda Accord ( V6 w/Nav ) for my wife ( A great car ). This site and, most importantly, its members, is of tremendous value.
I will post my observations, both pro and con, after I get the opportunity to put some real miles on my new toy.
Regards
Dan
jeffcarp,
You are correct, the existing radio head unit handles all the XM tuning, presets, etc. Also, the steering wheel audio controls allow you to cycle thru AM, FM1, FM2, SAT1, SAT2, SAT3, & CD. There is nothing else added to the dash area. The XM receiver (brains) is installed in the trunk, under the lining on the passenger side and is not visible. My XM antenna was initially installed on the outside of the trunk lid, on the passenger side, which I did not like when I took delivery. I had the dealer move it to the center rear of the trunk lid, by the back window, so there was more symmetry. Here are the pictures:
Interior Audio Controls:
http://img.photobucket.com/albums/v715/dshim/5.jpg
XM Antenna Initial Install Location by Dealer:
http://img.photobucket.com/albums/v715/dshim/2.jpg
http://img.photobucket.com/albums/v715/dshim/4.jpg
XM Antenna Install Location After Relocation:
http://img.photobucket.com/albums/v715/dshim/6.jpg
http://img.photobucket.com/albums/v715/dshim/7.jpg
The explanation that I received from my dealer when I made the deal was that in order for them to install the XM Radio, it required the JBL Synthesis Audio System since it was already wired and configured to accept the XM Radio. The owners manual shows 3 different audio systems, Type 1, 2, and 3. Types 1 & 2 do not have the SAT (Satellite) button.
I hope this helps
Can you share the link to the Toyota Georgetown website?
http://www.toyotageorgetown.com/
Here is an URL: http://www.clublexus.com/forums/showthread.php?s=&threadid=25927&- highlight=hid+es300
Excerpt: "Just be cautious about buying some of the kits advertised on the BAY, because they may not include a self leveling kit, which is the DOT requirement for "true" HID/Xenon lighting systems."
Suggestions?
What indirect lighting does that refer to?
How do the anti-theft and engine immobilizer systems work in the Avalon?
I checked for HID and leveling at
http://www.nhtsa.dot.gov/portal/site/nhtsa/menuitem.e649cd1b2b018- c71d8eca01046108a0c/
On Google, the Lexus comments came up, but had no reference to a source. Perhaps the author refers to a particular state "DOT"? California likes to layer on legislation.
jl618,
I have the OEM All Weather Mats in my new Limited and they are very good quality. They are just as good as the Weathertech after market ones that I had in my '01 Avalon. In fact, the back seat mats have a perfect fit, as opposed to the Weathertech which I had to trim for them to fit. I would recommend you go with the OEM mats. As an added benefit, they have "Avalon" imprinted on them, whereas the Weathertech do not.
For the person who wrote about the dual exhaust and it is essentially the same, it is not. It is a copy, from the Acura make, to pretend to have dual exhaust from the rear, but it is from the CAT back that it is dual exhaust, while it reduces backpressure, it is much more heavy hit on replacement, especially if it has two mufflers associated with it. Wait till someone has to replace that part.
As far as the XL and different size tires go, compared to the other models, I would not worry too much about it. Yes, the ride and handling will be slightly different, but major differences are had when you start changing componetry such as stuts, bushings, sway bar sizes, etc. rather than tires and wheels. And in addition to that, bigger tires and wheels are an added increased replacement expense. Just look at the difference between the cost of a 15,16 and 17 inch tire times 4. Over the life of the car. And the incidence of wheel bend increases as well. You do get more transient response but at the expense of ride comfort. The wear is usually faster with a lower profile tire.
ONLY IMO, the XL and the Touring as the "best buy"
Shame on Consumer Reports April 05 for omitting the Avalon 05 in one of there lists comparing Large sedans. It is incomplete and some of us expect more from that thorough magazine from the obvious omission in their annual April car report.
abfisch
~alpha
That's generally true. When you increase wheel size on a specific vehicle, the larger wheel generally comes with a lower-profile tire which will improve handling at the expense of ride.
What I meant was, an 18" wheel is not necessarily going to improve handling over a smaller wheel, IF both are equipped with similar profile tires.
"So in this context 2005+ Avalon XL is likely to have smoother and less noisier ride compared to XLS (assuming everything else remains the same)."
Again, I agree. Although the difference in sidewall profiles between the XL and the higher trims is pretty small (60 series vs. 55 series) so I doubt the XL will differ much from the XLS in noise and ride smoothness. The Touring is a different animal, since it has a firmer suspension as well, and as you note the Limited has the special windshield which will reduce noise.
Yes, I do and here is why. You will notice that you have more brake dust on the front wheels than the back. While a normal process of the pads to wear, there are remedies, some good and some bad to combat it.
I have much less brake dust on my set of steel wheels I use for winter driving. When you change your pads, select a pad that has minimal dust accumulation. Usually, the higher quality pad you choose, the more dust but not all the time.
Select your wheel choices BEFORE you buy the car. More spokes, more surfaces to clean, and it is more time consuming. A flat disc is easier to clean. Some of the Avalon or Toyota wheels, since they cross parts alot, are painful unless you like to clean wheels. Some forethought would be good before the purchase, unless you have someone else do it and you don't care.
There is a product called clean wheels that goes inside the wheels and is a black aluminum vented disc, that dramatically decreases brake dust on the outside of the wheel, but it doesn't let the discs cool very easily and that could lead to premature warpage of the discs. Cannot recommend them personally.
The old Avalons additionally, had alot of front end nose dive under hard braking. This stresses the front/rear brake basis and loads the fronts a bit more, making them work harder. I have found that premium struts prevent alot not all of the nose dive problems under high speed braking and thus decrease but do not eliminate front wheel brake dust.
The less you are on the brakes, the less dust.
I hope this helps. Front wheel drive cars and cars drivin very sportingly have this problem.
I hope this helps.
abfisch
Agree totally. I think also the width (215's now) are the same, so the footprint is the same. Just the diameter and the profile have changed, the same as the previous type model.
It should be noted that there is a significant difference in replacement cost of a 16 versus 17 inch tire and or rim.
A different tire could make a significant difference in ride qualtiy as well as others too. Toyota has put good but not great tires as original equipment in the past.
abfisch
abfisch
any thoughts?
thanks for your reply. i waited for the 96 maximas to come out before buying the 95"s, which were mildly troublesome, whereas the 96's were bulletproof. the 05 avalons (based on this forum's feedback) are not trouble-free, so perhaps waiting a model year makes the most sense.
dean
