I remember reading somewhere that stated Silver is the most popular car color in the country. I wished that Toyota would have given us more of a choice of colors that does not exactly mimic what other manufacturers are using (vice versa). But then again, I can understand that Toyota want to stay with the current color trend for the industry. I really hate seeing a bunch of cars that has a similar color to my Salsa. The last thing I want is to blend in with the crowd. I prefer to be different. Thank goodness I don't drive a Camry or Accord...you can not go to a stop light here without seeing one (along with a sea of SUVs).
My first choice was Salsa and my second (which is actually my wife's choice) was Silver. Luckily, the Salsa was available first and I decided to go for it. I do like the Salsa very much and IMO I prefer the contrast between the head lights/tail lights and the body color. The Silver does not show as much contrast in this respect as the Salsa because the whites/silvers of the lights blend in with the body color.
Sorry for the rambling...Good luck with your choice. Tony.
I have no complaint about this car with the way it rides and handles. Wind was not blowing so did not notice any cross-wind. Ambient temperature was in the 70's (southern Arizona).
Using "B" going down hills a few times was noticeable and felt good.
Wife is 5'1" and I am 5'10". We both feel quite comfortable with seating and visiblity. More adjustment in the seats is not an issue whatsoever.
Navigation works quite nicely, but took me quite a bit of study and experimentation to use it. I am not very impressed with the Nav manual included. I am somewhat of a computer "nerd" and enjoy new technology (part of my reason for buying the Prius).
Color we have is Seaside Pearl...why don't they just call it Metallic Blue? Looked rather dark in our garage and on the Dealer's floor...but looks quite nice outside in the sunlight.
So far I am very impressed with this car. Only thing that concerns me is what it will take (cost and time) to keep it maintained. My philosophy in owning cars is to keep them maintained while driving the hell out of them (distance...not necessarily speed...our other car is a 1992 Camry XLE which has 238,000 miles on it).
But.
First, VSC (PSM,etc.) is almost always coupled with Trac.
Trac is fairly simple to explain in that all it really does is prevent wheelspin if/when too much gas is being applied for the circumstance. Early versions applied braking to the driven wheels while simultaneosuly dethrottling the engine.
Newer, more modern versions still apply the braking immediately but delay the dethrottling slightly to give the operator time to react and lift the throttle on his/her own.
VSC/Oversteering, more common to RWD.
If the rear is coming around to the right then the right front brake is applied lightly to create a braking "moment", force, counter to the motion of the rear. To the left then the left front brake...
VSC/understeering, more common to FWD.
The assumption would be that you're trying to turn left and the car isn't tracking the steering angle. At the moment there are two different methods in the marketplace for overcoming this problem. One of these is to simply apply both rear brakes on the theory, correct, that slowing the car will always help. The other method is simply the reverse of the over-steering cure, apply a single rear brake to create a "moment", force, this time as an aid to the steering angle.
The problem with all of this is that driver's will see/feel its, VSC/PSM/etc, effect as no different than a new set of tires with a larger contact patch.
Without some feedback to the driver (providing a learning experience) indicating that the car has just approached the "edge", and why, most driver's will simply begin to rely on VSC, again and again, just as they would the bigger contact patch.
One of the reasons I like the ABS implementation is that vibrating brake pedal tells me that the tire/roadbed adhesion coefficient is not up to the task at hand.
Do you know that BMW now has a system that will counter-steer the car, against the driver's steering inputs, if their VSC says the turn is too tight???
Now that's going a bit too far!
We did note the gas gauge problem and hope that it will work itself out.
The color is "tideland pearl." We had no choice here. This color is a striking, although slightly muted green. We think it's quite handsome.
Unless you require lots of space or lots of off-road driving, this is the best car I can imagine. Of course, I'd like a few additions. How about a solar array on roof to add to battery charge?
Thanks to group for providing some useful info on gas gauge.
They recognize that safety is a big, big issue in consumers minds and the typical approach to packing safety items with pricey options (a la Toyota, etc.) isn't socially responsible.
Sure, the Jeep can be driven over the "edge" while a FWD vehicle with VSC/Trac cannot, at least not as readily, but in the end it is the driver who is responsible.
But I would be willing to bet you that I could take your Jeep and beat your Prius in a snow or ice storm anywhere you want to designate.
If you drive your Jeep as a "well trained and familiarized driver" it will always outperform the Prius in ice and snow.
I only have about 900 miles on my ODO. After returning from a 300 mile trip, I had only one segment on the fuel guage. I had about 45+ miles in MPG but I went ahead and filled the tank. Temperature was about 35 degrees and it only took 6 gallons to fill the tank. Have others experienced this condition and go by the number of miles traveled since "reset" to determine when to refuel?
However, we don't like the light tan interior as far as showing dirt. (The salesman told us that the grey was just as light in color.) Has anyone bought/found well-fitting seat covers for this vehicle? With our family needs we need a dark grey color to hide our messes.
Basically, VSC depends on differential traction coefficient F/R. Understeering, rear brake(s) are applied on nthe theory that front traction is clearly already all used up. Oversteering, etc.
I thought I'd be patient, hit refresh 20 or 30 times, and maybe it would just appear. It hasn't...
Update on my Kansas City wait for M.Silver Pkg 4, order placed Oct. 17: Dealer said they're getting approx. 3/month - opined that people are becoming disgruntled with the wait time and are instead running over to Honda and scooping up Civic HB inventories. He seemed just a little peeved at that concept ;^)
Thanks for all the great info on this board. I'll keep reading and bugging the dealer when the excitement becomes too much to deal with!
I guess there isn't much dealing you can do with a car that is in such a high demand.
I just went to the Edmunds site and had no trouble calling up the Full Road Test so maybe try it on another computer at the library?
Also good luck with getting your Prius. Didn't know Kansas City would be a hot spot for that car. One dealer here in Colorado said that since they sell a lot of Prius that they get preference when they ask for more. Don't know if that makes sense to me or not.
> no help on black ice.
ABS is great on black ice!
I've tried it both with my previous Prius and my Taurus. It won't allow you to stop any sooner, but it certainly provides much better control. That way you can aim the vehicle to hopefully still avoid a collision by going to the side of the obstruction instead. Or if you have not option but to collide, you can aim to insure a direct impact allowing the crumple-zone and airbags to deliver their fullest potential.
JOHN
-juice
the computer readout in MPG. For instance at a steady: 50 MPH / 60 MPH, and 70 MPH
I would think that at a steady 50 MPH mpg should be around 60 MPG.
Just my thoughts
Alster 2
Yeah! I like all the bright colors the New Beetle comes in. Toyota should introduce some bright colors for the Prius, since it's a distinctive car to begin with and most Prius drivers aren't trying to blend in with the crowd. It sounds like maybe they use the same colors on all their models, so it would cost more up front to bring in more colors. Also, it's not Toyota's style to be flashy, in general.
http://pressroom.toyota.com/photo_library/display_release.html?id- - - =12082003a
Colder air is more dense. That means it is harder to push through. So naturally, efficiency will be lower during the winter. (And other cold weather factors push it even lower.)
JOHN
And you want me to put my life at risk on that advice?
How am I to know which is "scattered about" and which is not?
Just beware of bridge decks and/or a close by tree line that shades the road continuously, or not, in the early morning.
In a practical situation, at some point you will regain traction, and VSC maximizes your chances of being able to regain control.
So yes, VSC's goal is to correct your heading if something like black ice took you off track in the first place.
-juice
http://s87059328.onlinehome.us/images/04Cutaway.jpg
-juice
Think of yourself balancing a broom, working side upwards in the air and the end of the handle seated in the palm of your hand, hand open. At the instant the working end starts to "fall over", if you're quick and agile enough you can move your palm back under the broom's center of gravity.
Once it's beyond a certain point your actions will only serve to accelerate its fall rate.
When the car begins to oversteer the opportunity for VSC recovery lasts only until the centerline weight/mass crosses the line of momentum of the center of mass of the car. Once the majority of the car's mass is outside the original line of travel VSC activaty will be detrimental.
Under-steering is a completely different story. That's probably why Toyota has commited to applying both rear brakes instead of only the one needed to provide the logically correct moment/force. Once the car has seriously understeered both brakes cannot hurt whereas the single one might end up putting you into a full spin.
The biggest factor during the winter isn't the density of the air, it is the composition of the fuel. In the winter the gasoline you buy has a higher vapor pressure. It is made of lighter hydrocarbons so that cold starting is easier. In summer the gas is "heavier" to reduce evaporative losses.
So the gas John is getting right now has a lower energy content than what you buy in Phoenix in July. A 10% change in mileage would be within range. Especially when you also include the longer time the car will idle to keep the emissions system warm. This is similar to the longer time a traditional car will spend on "fast idle" while warming up.
The oxygenates that are also often added further lower the energy content. When they were first introduced they caused some real mileage dropoffs in many cars...
Why did I buy one?
Hey, life is made up of compromises. I know that the RX will never be ALL I want it to be but....
Hmmmm...maybe the upcoming BMW X3.
Highender: buy the 04. But personally I would spent my nav money on a portable. Besides which the nav in my 01 RX had gotten me lost more than once. So many flaws I don't use it unless I first crosscheck before leaving home.
Oversteer in particular would be nearly impossible in the Prius.
-juice
I would guess that the warmer you want to keep the cabin, and/or the colder it is outside, the lower the MPG will be, on a direct relationship.
If VSC cannot prevent loss of control within the first few milliseconds of detection of "impending" loss of control, then it most likely cannot be of any help at all.
> the engine for A/C (pre-04) in the summertime the system
> may run the ICE more often in the wintertime simply to
> provide a heated cabin?
Just talk to someone in the extreme south that runs their A/C 100% of the time during the summer. Their numbers are reversed, where winter is better.
Of course, with the A/C now being electric, the game has changed.
JOHN
Yes, leather seat covers can be installed with side airbags, no question.
But.
If the airbags are in the outside of the back of the seat then I have very little doubt that your dealer has compromised the proper operation of your side airbags.
You are absoultely correct. We chose Tideland Pearl (see post 1159) based on the color sampler on the Toyota website (checked on several different high-quality computers). We expected a bit more green. In actuality, there is only the slightest hint of green and only in certain lighting. It is essentially grey. My wife, who is more familiar with tidelands, says the color is aptly named so I searched for a picture of a tideland and found the following:
http://www.asahi.com/international/aan/hatsu/images/jpg/020824d.j- pg
This is much closer to the color of the car than the sampler on the Toyota site.
Gas mileage update:
First highway trip, Cleveland to DC round trip. 4 passenger. Drove 73 mph in 65 mph limit areas (most of the trip). 60 degrees for outgoing leg, 31 degrees for return. MPG: 47 outgoing, 41 return. On the return, there were some stiff crosswinds which were definitely noticeable. However, one of these crosswinds blew a Windstar 1/4 of the way across a lane so I suppose this was extreme.
What a great car!
I've been reading this topic for a while. I ordered a silver or tan #8 in October (I'm in So. Cal). No word yet on delivery. Anyway, I wanted to know if the CD changer has a random feature? I really really like random and would be depressed if it weren't there.
Does anyone know who has seen or bought the Tideland pearl (prius4meus) know if it is darker than the silver? I like how it's described above (#1690) but I want to know if it's a masculine dirty green color or a pretty light green. Toyota's website's color is way off. I saw a blue prius in Santa Monica and it was much darker than both the website and the brochure...
Yes, it does. In fact, it has 2 random modes: within the same CD and in all loaded CDs.
JOHN
John...what do you think? Lately here in Dallas, the temp has been like a roller coaster. Some days the high is in the 60s other days it's in the 30s. I have to use my Auto A/C and Temp buttons on the steering wheel alot to adjust for warm and cool air circulation. I read in the manual and it say if you use the AC (to cool your cabin) your fuel economy is worst than if you do not use the AC. I thought that since the AC is electric, it will not affect the fuel economy? It also looks like the car takes the outside temp into account and adjust the AC/Heater accordingly.
I remember getting into the car and it's about 60 outside and because it was a clear sunny day, the cabin was pretty warm (guessing 75?)and when I power the car up, the fan was blowing really hard. I know that I did not leave the fan on that high when I powered off the car. Could it be that the Prius is trying to adjust the temperature inside the cabin? Very interesting
http://www.misssideless.com/homepage.html
http://www.seatcovers.net/car-seat-covers.html
http://www.seatcover-mfg.com/
http://www.seatcoverworld.com.au/airbags.htm
And a solar radiation sensor.....
