OIL CHANGES 00 SILVERADO 5.3
IM LOOKING FOR ANY ADVISE ON OIL CHANGES FOR A 00
SILVERADO 5300, 4X4 AS FAR AS REGULAR OIL OR
SYNTHETIC OIL AND TIME FRAMES OR MILEAGES. THE
TRUCK IS USED FOR ROADWAY DRIVING LOCAL AND
HIGHWAY, RECREATIONAL VEHICLE IN THE L.I. AREA OF
N.Y.. PLEASE INCLUDE OIL VISCOSITY. THIS IS A ONE
MONTH OLD VEHICLE WITH UNDER 1000 MILES.
My 2¢...
Jeff
I'll probably go 3000-5000 between changes...not sure yet.
I hear more talk of waiting 3000 or so then i do 25000.....course some cars have it from day one also??
I'd say a lot more damage can be done waiting 25000 miles....VS...putting it in too soon..
- Tim
YIKES!
- Tim
Jeff
I personally changed oil on my new Silverado at 1000 miles with regular dino and you could see all the metal filings on the magnetic drain plug. Changed again at 3,000 to Synthetic (no metal fragments on drain plug this time) as this was the minimum mileage recommended for break in by both a good mech and the Syn oil company rep. I plan on 5,000 mi intervals for average driving.
PS. no oil leaks or problems of any type to date with 7K on the clock.
Tony
Is Amsoil, Redline, etc. better? I could not factually confirm it. I do know that Amsoil was the very first to provide synthetic oil based on the same commercial airline grade synthetics that are used in turbo jet engines. The high temps and demanding use of those engines required a special grade of oil. The founder of Amsoil was a military pilot that left the military and engineered the synthetic products based on the same oil that these jets used. It is also about $7.00 unless you are a dealer or know someone who is. They also claim once a year or 15,000 miles oil change intervals with it though.
If you are asking if Pennzoil synthetic or Valvoline synthetic is as good as say Mobil1 synthetic. I would say so. I think with the oil readily found in Walmart, Kmart, and Autoparts retail stores, its all pretty close to the same stock.
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
