Tundra Maintenance
commodore1
Member Posts: 5
I don't have my Tundra yet, but I would like to
know something about routine maintenance. I would
like to know if the Tundra v8 has a timing belt or
a timing chain
a timing chain
Again, I am guessing, but wanted to give my opinion anyway. Have you asked the Tundra group over in the Tundra topics yet?
I would call a Toyota shop and ask to speak with one of the Master Tech's. They have alway's been really knowledgeable about the Toyota's I have had.
thanks again
commodore,
rs petty is correct. Toyota recommends a 90k mile replacement for the timing belt.
Oil changes take a little over 7 quarts(I think it's 7.2 quarts) of oil if you're interested.
And........
As a general rule, Chevys are NOT as reliable as Toyotas. Simply a fact!!!
The only domestic trucks or cars I saw on the application guide were compacts, mostly 4 bangers.
Didn't see any Full size trucks on the application guide.
There appears to be a lack of knowledge concerning how engines are constructed (you can't drive an overhead cam engine's cams with a gear due to the large distance between the crankshaft and the cams). And bud light dude is way off concerning belt stretch with todays timing belts. In fact, for a belt and chain of the same length (your typical timing chains are rarely as long as long as your typical timing belt due to engine configuration) I would bet that you would get more stretch (or elongation due to pin and link wear) with a chain than a belt.
The reason the Toyota 4.7 V8 uses a belt is because it is a dual overhead cam engine (thats 4 camshafts on a V8, similar in design to the Lexus LS/GS 400 engine), unlike Chevy, Dodge, and older Ford V8s which mount a single cam low in the block close to the crankshaft and uses pushrods to lift the valves. I'm not sure if the new GM engines use gears or chains to drive the camshaft, but the old GM engines use chains. I think that the new Ford engines are single overhead cam. Not sure if new Fords use belts or chains.
Another reason for using a belt verses a chain is that the belt has much less mass. This translates into less energy required to accelerate it and it also allows higher engine RPMs.
The reason small cars and trucks are listed in Gates belt guide and full size domestic trucks are not is because the smaller vehicles typically use higher revving overhead cam engines that use timing belts whereas the full size trucks (with the exception of the new Fords and Tundras) use single cam pushrod engines that don't use timing belts.
Hope this clears things up a little.
Alan
The main reason belts are ever used is to limit destruction if they go out, slip, etc. to the rest of the engine components as well as they are simply cheaper in cost.
As far as using a belt vise chains or gears because they are superior in any way is simply a very false statement. Ask any highly skilled tech, and you will get the very same thing.
But since it gets worse mileage, in a lighter truck, the obvious answer why Toyota uses them is because they don't have a truck engine.
Oh...so you drive a Toyota? (That don't impress me much) - Shania Twain
and,
"Don't be stupid."
-Shania Twain
LOL!!
You must really like that chick! I kinda prefer
Faith Hill myself. I wouldn't kick either one of them out of the bed for eating crackers, though! Oh well, it's nice to dream. Later.
I don't have to worry about rusting floor pans.....
You don't have to worry about chicks eating crackers in your bed.
As far as the number of valves versus gas mileage. The two don't have anything to do with each other. You use 4 small valves instead of 2 big valves to decrease the time of the air/exhaust needs to enter/exit the combustion chamber. Even though both 2 valve or 4 valve head can have the same valve area, the 4 valve setup will have a larger valve edge area. This allows the the mixture to get into/out of the combustion chamber faster. Also, 4 valves are used to increase the valve opening area.
Increased flow does not have anything to do with combustion effiency. It will allow higher top rpm and higher horsepower, which translate (loosely) to decrease gas milage.
If you want an example of this, compare an old 1000cc 2 valve motorcycle motor to a modern 4 valve motor. The new motor makes much more hp's, but the gas milage is terrible.
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
