Any information woudl be greatly appreciated.
Scott
Good Luck
The problem is that the name of my car "Century" only appeared on that lens as a sticker. The name Century is no longer etched into the side moldings.
The part I installed, depsite being OEM, does not say Century on it, presumably because it is the same part for the LeSabre, the Century and the Regal. I wrote to the president of GM with no reply. I emailed GM and after three requests for information, I was told that a plastic applique with the car's nameplate would be an additional $50!!! Can you believe this? Another $50 to have the name of my car on my car. BYE BYE BUICK, HASTA LA VISTA GM. This was the straw the broke the camel's back.
Sue
79CustomD
Steve
you send any info. on removing front door (drivers side) panel?
Need to fix window... either regulator or glass off track.
Help!
When reversing or pulling forward form the parked positin a loud, single "Tunk" noise is heard from the front drivers side tire area. Sometimes I think I hear this noise also when making a sharp left hand turn.
I have already had the driver side and passenger side bushing's tighetend and the swayarm replaced (it was cracked near the front driver side tire) But the noise is still occuring. Any suggestions? Thanks in advance.
And I've heard of your problem.
It's common to all Buck Centurys with a 3.1 engine form that time period (also the Olds Ceria).
Do you get water in the engine oil or oil in the radiator?
If so, then what you have is a leaky intake manifold gasket.
During that time period [94-96] GM was phasing out the Century/Ciera and they had alot of issues with the intake manifold gasket on the 3.1 engine.
I found out about it on a very useful website www.carsurvey.org
It's a pretty costly repair because the mechanic has to remove not only the intake manifold, but everything on top of it. including the fuel rail,fuel pressure regulator and the throttle body and then put it all back together and reset the engine's ECM.
I just bought a 96 Century from an elderly couple recently and the bill for that repair was over $725. in '04.
Try to get to carsurvey and just look up the make and model. They have some pretty useful info about alot of cars from people that had owned them. And you can add your own comments about your experiences.
Im having a hell of a time trying to figure out wats wrong with my 1989 buick station wagon.The proplem is my gas gauge and speedometer doesnt ligth up, all my other dash ligths ligth up tho i cant figure it out.ive replaced all the ligth does it matter that it had some green tinted ligths that i swicth out for clear ligths is this my proplem if anyone can help me, I would be greatful :confuse:
Also, the car has a miss that can only be felt if the car is idling and the engine is revved up. At normal idle, the miss is not there. I assume these two things are unrelated, but I included the second problem just in case.
make sure that the engine is hot and your parked on a level piece of ground. If the fluid is brown/black color you got some issues.
for the second problem, you could have a clogged or weak fuel injector (which could be related to the 1st problem) try adding a couple of bottle/cans of fuel injector cleaner on the next couple of tankfulls of gas.
Stupid question: Where is the thermostat housing located? I can't find it!
JMorales
