Lincoln Town Car Maintenance & Repair
Karen_SKaren_S Posts: 5,094
Problems with your Town Car? Post them here and share any solutions with other TH members.
Edmunds Manager UGC Click on my screen name to send a personal message. Need help navigating? Check out Getting Started in Edmunds Forums.
Need help picking out a make/model, finding inventory, or advice on pricing? Talk to an Edmunds Car Shopping Advisor
«13456737
  • I have a 2001 Lincoln Towncar. The radio has been working flawlessly since I bought it. The panel lights on the radio are supposed to turn on automatically when the lights on the car turn on on auto or manually. The panel lights on the radio most of the time do not turn on. Used to be for a while that if I turned the car off for a few minutes, opened the door and closed it again the radio lights would come on when I turned the ignition to on and started the car. Now it doesn't do it at all. But sometimes, low and behold, they turn on when it begins to turn dark and the car lights turn on automatically. It is really annoying. The CD and Radio work great but the lights are possessed by Gremlins. Has anyone had this problem or know the solution? What causes this to happen?
    Henry
  • nvbankernvbanker Posts: 7,285
    Are you talking about the lights on the panel of the Stereo controls, like the button lights, or the window LED display?
  • patrikpatrik Posts: 2
    I have a 1999 towncar in which the carpet on the right side of the car, both front and rear gets soaking wet when the car is left outside in rain.
    Any suggestions what may be causing this?
    Wow....my only guess would be a bad windshield or backlight seal is letting rainwater in, and it's running over the floor pan. But I've never heard of this problem before......
    Have ya considered moving to Nevada or Arizona?
  • homerkchomerkc Posts: 113
    Do you have a sunroof? Leakage there could find it's way down the door pillar - and could explain the wetness in both front and back. I can't believe a leak around the windshield would soak the back as well.
    Thanks for your idea about the door pillar. That is in line with my own theory. I do not have a sunroof but a carriage roof and the sealing on the top of the door pillar looks a bit suspishious.
  • I have a 1998 Lincoln Town Car. Just recently I thought the A/C quit working. I started troubleshooting. When I push the MAX A/C button the compressor kicks on and it is getting cold. I them hear a vacuum shuttle and it starts blowing MAX heat. The A/C and receiver are ice cold under the hood. I thought the climate control crapped out. I bought a used one and replaced it and same problem. Could they both be bad or is there another place to check for the vacuum activated shuttling from heat to A/C. Thanks
    I bet you replaced the head unit on the panel? The brain for the system is elsewhere I think. But, you may only have a stuck blend door. That's what I'm betting on. The one time I had this happen to my 92 Continental, a power down (take the battery off the terminal, and reconnect) fixed it, never happened again. Kinda like a re-boot.
  • tried the disconnect. Problem still exists. Where is the blend door? How much disassembly is required to get to it? Thanks
    Oh, I've never had a stuck blend - door, just heard about them, it's a dash out issue. Your basic nightmare. Ugh.......
  • I don't know the answer to your problem, but I wish I did. I have a 98 doing the same thing.
    I'm digging and if I come up with anything I'll let you know. You do the same please!
  • My '89 had a sticking heater door on it, or, to put it more right, it just plain would only open half way. If the heater system in your 98 car is still vaccume powered (which i highly doubt) check the vacume motor on the heater door itself.
    You will probably be able to gain access to it by taking out the stop in the glove box that keeps it from falling down on your knees and dumping its contents on your lap. Check to make sure the vaccume line is well attatched.
    One problem with that problem though, is that the vaccume line is iether on or off. It really can't be in between, and if its off, you will get heat only.
    Another item that you could check is the heater control valve, which is under the dash pad in '80's models, and I would assume the same is with your 98. If yours is still a vaccume powered unit, which i doubt, it could be bad (those things had a tendacy to crap out in '80's machines). Again, the problem with that has a different failure mode than what you have mentioned. When the vaccume powered heater control valve fails, you usually only get luke warm or ambient temperature air from both the heater and the air, since a bad unit will only provide a range of low-mid vaccume to high-mid vaccume.
    That said, I think your unit is electronic servo operated. In that case, the servo on the heater door could be failing, overheating when in use and shutting off, causing the heater door to return to its home position, which is wide open. That servo would be my first suspect.
  • dacuzdacuz Posts: 1
    I need help -
    just picked up a new Town car and because of the following design characteristics I find this luxury car to be extremely dangerous -
    the brake and gas are so close
      I have almost driven thru my garage door and
      rear wall
      it is almost impossible not to hit the gas and brake together
    the metal strip on the dash reflects thru to both side view mirrors creating a double line in each mirror thus distorting the view on both sides and limiting the viewing area
    the defroster vent is so far away from the window (closer to the driver) that it also reflects into the windshield decreasing visibility by 25% in the front windshield
    the green LED lights from inside at night also reflect in the left side view mirror that that also distracts and limits the viewing space
    if anyone has noticed any of these please reply asap
  • I have an 01 Town Car and I noticed every time it rains or I go thrue a puddle the passenger floor gets wet. The water is coming from inside the dashboard and dripping down. I've talked to about 20 other TC owners and they're having the same problem. Anyone have any idea how to fix this?
  • egkoregkor Posts: 24
    I have a '95 TC. When I turn off the windshield wipers, the wipers go to the "up" position and stay that way, instead of going to the "down" (concealed) position.
    Any help appreciated!
    -Gary K
  • Just read your post, if not too late, I can tell you of my similar experience.
    If you will look at posts in "Lincoln Town Car" at numbers 1040, 1045, 1049 (diagnostics) and 1052 they will relate my experience with a faulty blend air door motor.
    Why did yous guys hafta change the wheel in the 05 Town Car? I'm renting one in Florida this week, and the control buttons on the spokes are too large, hard to press accurately and unwieldy. Big mistãke if you ask me. Bad design. Like my Navigator wheel much more.
  • My '99 did the same thing last year, but on the drivers side. Dealer resealed the windshield and no more leaks.
  • towncar2towncar2 Posts: 1
    hi we have a 2001 town car and the front heater fan has stopped working every thing else works but the fan any one have any ideas if there is a know problem
  • chuck11chuck11 Posts: 1
    The interior panel brake light in my 1999 Lincoln stays on most of the time when the vehicle is running. There is no noticeable drag at any time while driving. Often it will go off when backing up but reappears again. Any help on this would be appreciated.
  • beernutbeernut Posts: 329
    Sounds like a parking brake light switch adjustment. Its down on the pedal.
  • rudybrudyb Posts: 1
    HAVE SAME TC & SAME EXACT PROBLEM--WINDSHIELD WAS REPLACED IN 3-2003--GLASS SHOP RAN WATER LEAK TEST IN SHOP BELOW WINDSHIELD--REMOVED BLACK PLASTIC LEAF/RODENT GAURD & RAN WATER IN LEFT CORNER ON BODY--SAW LEAK INSIDE AC BOX-NOT A WINDSHIELD LEAK--
    -GASKET BETWEEN AC BOX & BODY LEAKING INTO BOX & ONTO CARPET BELOW GLOVE BOX ON PASSENGER SIDE--REMOVED SCREWS--LIFTED PLASTIC--APPLIED SILICONE SEALANT TO GASKET & REPLACED ALL---LEAK GONE---GUD LUK---RUDY IN LA.3-17-05
  • I had the same problem recently. The dealer said that this is a common issue with TC. There is a air supply intake for the A/C system that can develop a leak at the gasket. The water will run down inside the door and soak the passenger carpet. They fixed it the first trip and I have not had any problems since. Be sure to leave the floor mats off until the carpet is completely dry.
  • euphoniumeuphonium Great Northwest, West of the Cascades.Posts: 3,425
    When you face downhill, the rain water seeps into the trunk instead of running off.
  • pollockpollock Posts: 1
    My car is stored during the winter and it has 65000 miles on it. When the car is driven the air conditioner is used 95% of the time. So one day the sun was out but it was cold, I decided to take it for a run. When I set the temp at 90, the air was cold so I shut it off. I then drove the car till the temp was normal and turned the heater on with cool air coming out. I took it back to my garage and put a temp probe in the vent and it was 64 degrees. I moved the temp from 60-90 then 90-60 (1 cycle) and the temp move down to 62 degrees. I cycled this about 6 times and it moved down to 52 degrees. But the heat side only moved up to 67 degrees.
    It took many cycles (90-60 then 60-90, moving the temp 1 degree at a time with a couple of times with 2 degree movement. When it hit 86 Degrees it jumped to 103, but when the car was shut off and restarted I was back to square one. I was assuming that the blend door was sticking but I thought why is it defaulting to the air conditioner side. Also I thought there was a safety function in case this happened that would let you go to defrost and you would get heat. This doesn't work, I get cool air out of the defroster too. This happen last summer but the situation was reverse. I drove down to Las Vegas using the heater and when I switched to air conditioning, the air was maybe 72 degrees; just guessing. I stopped at a shop and the guy told me I could do a self test by pushing the OFF & FLOOR buttons at the same time and then within 2 seconds push AUTO. The temp window displayed a clock hand rotating and finally stopped with zero codes. I then pushed the BLUE button. When I tried the air it blew cold air. On the way home the heater also worked when I needed it. The car was driven about 500 more miles before being parked. I have also disconnected the battery with the problem still there.Any advice would be appreciated.
  • buck8buck8 Posts: 1
    I have a 2000 t/c w/28K miles. I took it to a independent mechanic that I have used for my other cars, to have it serviced. He contacted me and told me I have a head gasket leaking oil on the back corner, drivers side. I might add, I've known this person for some time, and know him to be an excellent mechanic, as well as extremely honest.
    He also told me that the 4.6 engine was called a romeo engine, that the heads were finished to a glass like finish when new, and during assembly, it was not uncommon for metal flakes from the assembly process to get in between the heads, gasket, and block, and that with the expansion and contraction it is fairly common for them to develope leaks.
    Of course, the car is now out of warranty. I'm just wondering if anyone else has encountered this problem?
    Thanks to all,
  • sacdl7sacdl7 Posts: 3
    The power windows in my 1984 Town Car now refuse to function. If I use a jumper battery with wires to the back of the door-switches, I can make the windows go up or down, but NOT with the switches themselves. The fuses are alright. A test-light shows that there is no electricity getting to the door switches. I have put in a new power-window relay (in the right passenger-side kick-panel area). The power-windows STILL refuse to function. Any suggestions? Thank you.
    I'm not saying your mechanic is lying, but this is the first time I've ever heard of a 4.6L engine having a head gasket leak. I've heard of a few 5.4L's having that problem. It's certainly not impossible. But as for "fairly common" for them to develop leaks? That, I'm a little dubious about as I'm very familiar with this family of engines, and it's the first time I've heard of it.
  • kjfkjf Posts: 2
    I had a '92 TC (also 4.6) and I sold it to my brother with 130K miles, and he drove it 4 more years, junked it last year at 190K miles on original engine, and no head gasket problem. My '01 Signature TC (4.6) had the intake manifold gaskets replaced under warrantee. It has 63K miles nows and no problems with head gaskets, but I was told it needs lower ball joints today.
  • kjfkjf Posts: 2
    Re: Gas and brake too close... I have had same problem with my '01 Sig TC since I bought it in July '01, and told the DLR that I had heard they were fixing this on Taurus and other Lincoln/Ford vehicles. They had a tool that they measured the space with, and if it "passed" they did not fix it. Mine "passed" but I still step on Gas and Brake at same time with my size 13 right foot more often than not. It was not like this on my '95 Crown Vic, but they told me that was cuz the car was made for cops with boots on.. and Lincoln was not. It is a definite safety hazard. When I don't feel the car slowing down for the pressure I am exerting, I shift my foot to see if it might be on both pedals. The biggest problem is that the brake pedal ends up down at (and below) the height of the gas pedal when you step on the brake. If brake pedal engaged at higher point, it would not have this problem. Good luck...
«13456737
