I still can't figure out the distribture thing. Only two of the three mounts are slotted, with the center drive hold fitting tight with a o-ring seal, how the heck would you be able to turn the thing.
I tried anyway, but of course could only bump it a fraction either way. ????
I have a 1990 Mitsubishi Sigma 3.0 V6. I just got it and have recently changed fluids, anti freeze, oil and transmission fluid. I'm noticing a leak that appears to be coming from the back side of the engine towards the top on the left side just above the tranny...it appears to be oil based on color...I recently had the brake fluid changed also but don't think this is what it is. Any idea's of where this could be coming from and how to correct it.
Bill
I have a 1999 ML430. My eng check light came on. I read the obd2 code as P0170 and P0173. I know what these are BUT not how to fix them. Anyone with ideas of what are the things that I should be checking for would be greatly appreciated.
Thanks in advance
P0170 (right bank)& P0173 (left bank) are fuel trim codes.
Check for vacuum leaks, air intake leaks (air cleaner tube), incorrect fuel pressure, bad fuel pressure regulator or faulty injectors.
Since both banks are affected, I would be inclined to think you have an intake leak.
Thanks - I will check them out. It sounded expensive
It may be a problem with the clockspring, which is part of the airbag system and something that should be done by a reputable shop.
But, it may also be the horn relay. The horn relay is in the Relay box, mounted in the engine compartment on the passenger side.
If you are standing on the passenger side, the horn relay will be the second one from the left. It should be marked E49.
Possibly you could have a look at the engine running in the dead of night to see if you can spot a spark jumping.
isn't there a spray that might temporarily seal the wires, for test purposes?
WD40 is also used to push out water, under distributors for instance, if you kill the engine in a car wash or crossing a creek. it can leave carbon tracking (aka shorts) if HV arcs across it, however, which is why I sorta prefer the plant sprayer of water.
Is there a trick? Maybe stick the tranny in neutral? He has the Chiltons and a Nissan service manual and is stumped.
Is it an automatic or manual?
I am assuming it is a manual trans.
Did he disconnect the clutch slave cylinder?
Usually the only time they hang up is when the splines of the input shaft have worn.
If he can support the transmission, put it into gear and work the output yoke back and forth while puttin g a little tension on the bellhousing, it may pop loose.
It's a manual and he doesn't think he disconnected the clutch slave cylinder (he'll have to look at the service manual again to figure that out, lol).
Thanks for the help!
Nooooo...you don't want to wail on or pry aluminum castings too much...in desperation, I'd rather see someone come-a-long it out from the tail shaft. Of course, a welding torch and a new bell housing is the ultimate last-ditch effort.
wail
whale
Whale on still doesn't look right to me either.
aka throwing everything you have at a project, related or not, sane or not, wildly chucking stuff at it until you either overwhelm the thing or die trying with a curse on your lips.
that's the origin of "whaling on" something, probably Ahab-inspired. many a project under my shade tree has gone in that direction...
Actually, "wail" might also fit obtusely, as in:
"to cry loudly, expressing sorrow"
But that would be more like "wail upon"
Thanks, I've been using it wrong(ly) for years!
cost of these little computer modules varies widely, part of the cost is whether the car or people would be destroyed if the item fails, and part of the cost is what the market will bear plus five bucks. an interior lighting module will be cheaper than the engine computer because it doesn't really matter, and doesn't have to be designed to work from -60 to +100 Centigrade, and doesn't have to be tested for three months with all conceiveable malfunctions to insure safety.
having said that, the GEM module for ford explorers runs something just over $250, and the backup sensor module runs about $125. if this is ONLY lighting, and honda is being generous, it's probably under $150, but could be higher just because of the "H" on the label.
I'd just call your service guy and ask him if this is a warranty service, and ask for an estimate if it isn't.
Now it will slip and grab on initial takeoff. I rarely do a quick takeoff, but my wife had commented about tires slipping last summer. After engine speed is up slightly you can floor it and there is no slip. Only from dead stop and idle and tipping in quickly does it let go and grab.
I had a trans shop drive it last eve. They indicate the slip could be a sprague (spelling) or the clutches. Fluid is red and normal. Is the trans shop making it more serious than the TCC apply control and a pressure controller there that can give trouble and would be replaced when working on the valve body? OR is it time for a full rebuild.
- Verify fluid level and condition. Note: some aftermarket filters have a slightly smaller neck diameter than original. Use of an aftermarket filter with the original filter seal can cause a pump suction leak, resulting in lower line pressure and friction element slip.
- Retrieve any stored diagnostic trouble codes and service as required.
- Road test with the selector in Manual Low position. If the symptoms are reduced or eliminated, a friction element slip is indicated.
- Verify line pressure. Requires a pressure gauge and scan tool. If below spec, correct as required. If within spec, the transaxle requires disassembly and overhaul.
in your case, since you've got a crusty gawdawful mess anyway, you should do a pressurized backflush of the cooling system to get all the gunk out, and for that a hose (typically the heater supply hose) is generally cut and a hose T is installed for water supply. drain is usually through the radiator neck. when you're done and the car is cool, you can get rid of additional crud by taking the lower radiator hose off and draining the water and rust flakes out of there.
probably worthwhile to use a chemical flush compound in the coolant before starting this procedure.
then you replace all evil-looking, soft, cracking, brittle, or deformed hoses... probably replacing the thermostat is a good idea as well... and pour in a good new 50/50 mix of coolant. burp out the air however your maintenance manual says to do it with your particular engine, and you're good to go.
It's my understanding it doesn't take much water in a cylinder to 'hydrolock' a motor. I would work on getting all the plugs out of the motor and then seeing if it will crank.
Take all drive belts off, then try to crank it. Small chance, but the water might have caused an air conditioner, alternator, power steering, etc to seize up. Try to turn all these by hand.
Other wild guesses - some electronic module, connection, or sensor is soaked. You've already broken the crank, cam, valve, etc from water getting into a cylinder. The timing chain 'jumped' and is jammed.
Definitely hydrolock is a possibility. A very good possibility.
Anything sooner would just be extra money in the shop's pocket.
Unless you are using the vehicle as a taxi....
Here's the kicker: the alternator was just replaced, right before we got the car.
Any advice you can give will be greatly appreciated!
John
at www.wheels4hope.org
Your best bet is to remove the alternator and take it to Chief, Pep Boys, Autozone, etc and get it tested - they'll bolt it up for free and run a load test on it.
Removing teh alternator and taking it there would be easier than the 43 jump-starts it would require to get the whole van there!
Good luck. One more thing - before you remove the alternator, take off the battery cables and clean them well, and look for corrosion (green powdery junk) - that stuff will shut down electrical current in a heartbeat. Check the terminals for tightness, check teh termination point of the cables, as well - make sure they're tight.
The automatic transmission has two major enemies. Dirt and heat, with heat being the most dangerous. As for dirt, there's no reason there should be any in a near new transmission.
He has to explain the workings from front to back (easy enough to find at howthingswork.com), but he has to explain the actual factors and calculations to his class and teacher.
Any ideas?
2004 Denali....HELP it's driving me nuts!
