Mazda3 Maintenance & Repair
1878890929398
    dridedride Member Posts: 139
    Does anyone have tips on how to replace the passenger side low beam headlight. I can not seem to get the new bulb "locked" in place. I wish my hands were smaller.
    matthewm19matthewm19 Member Posts: 1
    I am 85% sure that I will be purchasing an '09 Mazda 3 within a week or so. Any word of advice on buying it, breaking it in, maintenance issues, etc??
    This is my first car, and I am kind of freaking out.
    ahightowerahightower Member Posts: 539
    Congrats! I wish my first car had been as nice as yours will be. There's tons of advice on the site and in the forums for buying and maintenance. Theories differ on breaking in new engines. Some say it's not necessary at all, let her rip right out of the box. Others say you must be extremely delicate, let it warm up for a few minutes on each start before moving, change your oil after the first 1000 miles. I believe the truth is somewhere in the middle. Don't obsess, but do take it somewhat easy for the first 500-600 miles. Keep your revs low, brake gently, vary your speed (mix of city and highway, don't take a several hundred mile highway road trip right out of the box). Don't be too disappointed in the gas mileage from your first tank, it will improve. Then after a couple weeks (I know I always get my first 500 in about three days!), have some fun. Cars are meant to be driven!
    My grandfather used to say you shouldn't use your cruise control for the first 500 miles, and I never really understood why (maybe what he meant was to avoid long highway trips until broken in, and therefore no need for cruise control), but I always follow that rule anyway because it's fun to remember him.
    shiposhipo Member Posts: 9,148
    The absolute best advice that anybody can give you is to READ THE OWNER'S MANUAL from cover to cover. In that booklet you'll find answers to virtually all of your questions on the care and feeding of your new ride. ;)
    Best regards,
    Shipo
    roadburnerroadburner Member Posts: 17,362
    Owners Manual?
    What's that?
    Can I get it on a podcast?
    Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
    :blush:
    jeffyscottjeffyscott Member Posts: 3,855
    My grandfather used to say you shouldn't use your cruise control for the first 500 miles, and I never really understood why...
    That comes from the advice to vary speed during break in. I don't know why or what the consequences of not doing it would be, but it is considered to be bad for the engine to be run that way when it is new and being broken in.
    For my Mazda6 with the 2.3 engine, they give the following advice in the owners manual:
    No special break-in is necessary, but a few precautions in the first 1,000 km (600
    miles) may add to the performance, economy, and life of your Mazda.
    l Don't race the engine.
    l Don't maintain one constant speed, either slow or fast, for a long period of time.
    l Don't drive constantly at full-throttle or high engine rpm for extended periods of time.
    l Avoid unnecessary hard stops.
    l Avoid full-throttle starts.
    shooterdanshooterdan Member Posts: 1
    i will tell my story which is very similar. i have a 2004 mazda 3, and on around 67000 km on dec 11th my cel came on. i called the dealer and they said seeing as the car was running fine( no loss of power) they told me it could be the gas cap not being tight enough and that after about 7 cycles of engine starts it should reset. well it hadnt reset by dec 18th so i decided to make an app. to have it looked at. well two days before my app. the light turned off. then two days later it came back on, and like before it stayed on continuiosly. so again i waited as the car was driving fine, but this time it hadnt shut off on its own, so again i made an app. when they did their tests it came back saying the thermostat was staying open, and that it would cost 350 to fix. they didnt have the part today but assured me that it would be available by friday, but he also said something about a "flash" for the computer which they did and reset the engine light...so i guess i will have to take it in on friday to replace the thermostat, but if the light comes on again after 500kms, i will be pissed. i will keep you informed
    autonomousautonomous Member Posts: 1,769
    Curious. Replacing a thermostat is relatively inexpensive so there must be more to the "fix". How exactly are they going to fix the problem?
    mariodmariod Member Posts: 28
    350 to change your thermostat... Are you kidding me.... The part costs 43 USD...
    And i don't think a bad thermostat would cause a CEL light to come on. The only thing it would cause is your car to Hot or stay cold. Nothing to do with emissions.
    Agreed. That's outrageous.
    Yes it can; if the car doesn't reach its normal operating temperature the engine management system may never go into closed-loop. It also may run a very rich A/F ratio. Either can trip a CEL.
    My suspension is creaking. Not very loud when driving, but I hear it when backing down a steep driveway, for instance, and can re-create the sound by "bouncing" the left rear side of the car when parked. Do you suppose this is something a little grease could solve, or is something broken? It's still under warranty (2008 3i sedan), but I don't want to take it in just to be told it's a routine maintenance item that will cost a lot. Chassis lube, perhaps, I could get any shop to do that pretty cheap. Thanks for any suggestions.
    I it doing it when the ambient temperature is 40F or below? If so, welcome to the world of Mazda suspension bushings...
    That may be the case. I will have to pay more attention to the temperature and report back if it still occurs when it warms up this weekend.
    raysmith4raysmith4 Member Posts: 1
    Owner's manual sais nothing about transmission fluid change. Should it still be changed?
    mazdazoommazdazoom Member Posts: 43
    Yes it needs to be changed/flushed, if you did not do it at 30K then I would darn sure do it at 60K, and again around 90-100K, then repeat every 30K miles if you want it to stay tip top, if not do it at least every 60K. I have 100K on my 2004 Mazda 3 and I change it every 30K miles, runs as good as the day I got it.
    "Yes it needs to be changed/flushed, if you did not do it at 30K then I would darn sure do it at 60K, and again around 90-100K, then repeat every 30K miles if you want it to stay tip top, if not do it at least every 60K. I have 100K on my 2004 Mazda 3 and I change it every 30K miles, runs as good as the day I got it."
    Hmmm, I'm thinking that I have a problem with the above statement.
    1) While a transmission pan drop, filter change and a top off with fluid may well be a good idea every 30,000, it does NOT seem to be recommended by the Mazda engineers that designed and built our cars.
    2) As a general statement, the flushing of automatic transmissions is a VERY BAD idea and has been known to kill many-many transmissions shortly after such a "service" has been performed. As far as I know, there isn't a single manufacturer from anywhere in the world that recommends flushing the automatic transmissions that they put in their cars.
    While I've been wrong before and could certainly be in this case, I rather doubt it. Want to prove me wrong? Cool, I'm always willing to learn; please provide links and citations that support your recommendations.
    Best regards,
    Shipo
    I drain/refill the ATF in my X3 every 50K; I think that's a reasonable interval for a autobox in a street driven car. As for a transmission flush, I can't see that it's needed.
    Many (most) manufacturer's no longer have transmission fluid changes in the maintenance schedules. In the old days it was typically 30K mi, but they now use long-life synthetic fluid.
    I think suggesting that the trans fluid still needs to be changed every 30K mi, is similar to suggesting that if synthetic motor oil is used, you still need to change it every 3000 or 5000 miles or whatever you would do with conventional. I don't know if the new transmission fluids are truly "lifetime" but changing every 30K is likley overkill.
    My plan is to maybe look into this issue and see if some sort of new consensus on synthetic trasmission fluid changes has developed when we get to about maybe 75,000 miles. Since we do not put a lot of miels on, by that time our cars will likely be at least 10 years old.
    KansasGirl30KansasGirl30 Member Posts: 3
    Last night I had my first real issue with my Mazda3. Ive got 110,850 miles on it. As I was driving down the street, the car acted as if it had lost power then recovered and repeat. THe RPM's were going from practically 0 to 4. My dad first thought that there was moisture in the gas tank. We drove it to Auto Zone so they could use their machine to give me a code as the check engine light flashed a few times. The code that was given was PO303 Cylinder misfire detected in #3. So, I bought some spark plugs and my bro installed then took for a test drive. He said when he was getting on the highway it jerked a little bit, but not to the degree as before and then rode like nothing was ever wrong with it. However, the check engine light came on and stayed on. I took it for a spin - same thing - acted like nothing was wrong. When I Got home he disconnected the battery to see if the check engine light would come back on after it was reset. It didnt. I drove it a bit today without any issue, but that was very scary! I know nothing about cars and I called the dealership. They told me that if its driving fine now, to wait it out to see what happens because it was going to cost $115 to put it on their machine plus 2.5 hrs of labor. Has anyone had this happen to them? Any suggestions?
    Ive had to replace my driver side wiper arm twice and they are pricey! Everything with my Mazda seems to have to come from the dealership which sucks. My brother was able to tighten the arm once and that helped for a while.
    laser92awdlaser92awd Member Posts: 2
    Sounds like it just needs a tune up (spark plugs and plug wires), no big deal. You've already done the plugs, you should also replace the spark plug wires. Also ask your brother if he gapped the spark plugs, that's also something to check if you are still having a random misfire (a misfire is the same as what you described as "lost power then recovered and repeat" & "on the highway it jerked a little bit").
    ecoganecogan Member Posts: 26
    I am new to the Mazda world, and just bought my first Mazda3 (2009 Grand Touring HB). Noticed that the owner's manual recommends oil changes every 7,500 miles or 6 months, whichever comes first. Because of the long intervals, I suspect synthetic will be used. But I am not 100% on that, since I got mixed messages from 2 salesmen.
    I know lots has been written about synthetic v. conventional, but I am curious to see what most new (2009) owners are doing in terms of type of oil. Parallel to the regular 36K / 3 yr bumper-to-bumper, I have an extended (came with the purchase) warranty of 100K miles or 8 years, that requires all servicing be done at the dealer or the warranty is voided.
    I want to hold on to the car for a long time. Love the looks and the way it rides. What oil type is everyone using?
    Thank you for your feedback/input.
    I bought a 2009 Mazda3 sedan a little over two months ago and I'll be hitting 7,500 miles in the next two or three weeks. After spending some time on the bobistheoilguy.com web site, it seems that 7,500 miles is very doable on the factory oil (which is a 5W-20 conventional by the way). That said, my plan is to switch to Mobil 1 0W-20 at the first oil change and use that every 7,500 miles, at least through the warranty period. In addition, I will send in an oil sample from each of the first three or four oil changes for Used Oil Analysis (UOA), just to make sure all is well with the oil selection and the engine break-in.
    A brief note on extended warranties... The last one that I bought was on a car I purchased in October of 1988, and when all was said and done, even after 100,000 miles I hadn't made back even half of the initial cost of the warranty. Said another way, that was the first and last extended warranty I've ever bought. Since 1993 my wife and I have bought eight new cars and driven them an average of about 100,000 miles per (the high was 170,000 and the low was 30,000 due to the fact that I bought a sports car one day before we found out we were expecting our first child, and car seats and that car didn't mix).
    Had I purchased the extended warranties that were offered for those eight cars I would have spent something over $16,000 plus the various deductibles (typically $100 per visit). Against that I've had to pay about $5,500 in unscheduled maintenance (including one transmission), so on the surface, I'm over $10,000 ahead in sixteen years. But wait, there's more! The transmission that I mentioned failed at 109,000 on that vehicle, some 9,000 miles after the extended warranty would have expired, and as such, it would not have been covered. Said another way, by my math, I'm some $14,000 ahead of where I would have been had I bought the extended warranties.
    Granted, on any one car an extended warranty might well pay off, however, over the driving/car ownership lifetime of you, me, and virtually everybody else, the bet is that "self-insuring" will be way-way less expensive than buying extended warranties.
    Long story short, my advice to you would be to ask for your money back on that warranty and then invest it in a CD or something. Should you be faced with an extraordinary maintenance item at some point after the standard warranty expires, simply use the money that you've saved to pay for the repair.
    Best regards,
    Shipo
    First off they don't drop the pan and change the filter anymore, most dealers and shops will use a flush machine that will push fluid through the entire transmission under pressure, and in doing so remove the old fluid and leave new in. If you inspect your fluid every 60K miles (or watch the old fluid flush out versus what is goingin) it will not look the same, the old fluid is dirty, used, and broken down.
    Granted you could run a car for a long while and never change it and it will run, will it run top notch? I seriously doubt it. I also agree that a 30K change is a bit overkill, 60K should be just fine. However I tend to overkill many things I do on my cars, then again my cars last 250K miles plus. To each his own I suppose, if you never want to change your tranny fluid then good luck. All fluid breaks down after continued heat, friction, and pressure. Never changing it... I for one think that is the bad idea.
    "First off they don't drop the pan and change the filter anymore, most dealers and shops will use a flush machine that will push fluid through the entire transmission under pressure, and in doing so remove the old fluid and leave new in."
    Granted that a number of dealerships use the transmission flush scam to increase their profits, however, in the grand scheme of things, dealerships that screw their customers in this manner are still no where near a majority much less "most dealerships and shops".
    "Granted you could run a car for a long while and never change it and it will run, will it run top notch? I seriously doubt it."
    Do you have any scientific data to back that up or are you just guessing?
    "If you inspect your fluid every 60K miles (or watch the old fluid flush out versus what is goingin) it will not look the same, the old fluid is dirty, used, and broken down."
    Back in the days of conventional oil based transmission fluid this was true; however, the color of modern synthetic oil based transmission fluid is a very poor indicator of the fluid's fitness to continue serving the needs of your transmission.
    "I also agree that a 30K change is a bit overkill, 60K should be just fine. However I tend to overkill many things I do on my cars, then again my cars last 250K miles plus. To each his own I suppose, if you never want to change your tranny fluid then good luck. All fluid breaks down after continued heat, friction, and pressure. Never changing it... I for one think that is the bad idea."
    Believe it or not, like it or not, synthetic transmission fluid has been shown time and time again to be very much up to the task of lasting the life of the vehicle (in applications where a "lifetime fill" has been installed at the factory). At this point we only have one vehicle with an automatic transmission, and yes, it came from the factory with a "lifetime fill" of tranny fluid. It had been my intention to run that vehicle until it dropped without ever changing the fluid or the filter, however, at about the 112,000 mile mark, the pan gasket started slowly weeping out fluid, forcing me to do a pan drop (and filter change while I was at it), and a top-off of fluid.
    Just for kicks and giggles, I sent off a sample of the factory ATF to Blackstone labs for a UOA, and guess what; the report came back showing that the ATF was still well within the spec range for new fluid.
    Best regards,
    Shipo
    Shipo - I fully agree with you on extended warranties. This one was "free" but the hook is that I have to do all service at the dealer. I am very skeptical of dealers, and think that they will try to gouge you at every opportunity. In fact, just today I called the service dept. and asked about the 7,500 miles or 6 months oil change intervals. (Those are free as part of a "Customer Care Program".) The service manager suggested that I still change the oil (regular oil) every 3K or 3 months, because of the "stop and go that we do around here." (That one, of course, is on me...) The skeptic in me kicked in. What do you think? Think I need it? My wife and I are gentle drivers, and will probably do about 15k miles per year, and about 50/50 highway/city.
    Thanks for your thoughts.
    EGC
    The problem with any predetermined Oil Change Intervals (OCIs), such as 7,500 miles per the engineers that designed our cars, or the lucrative 3,000 mile intervals that your dealership and Jiffy Boob suggest, is that YOUR driving environment may or may not call for either of those intervals. To eliminate any guess work I typically send my oil out for analysis a few times early in a car's life, and every year or two thereafter.
    FWIW, my last two cars came with a factory recommended 15,000 mile OCI, however, both cars also came with Oil Life Monitors (OLMs) that measured the amount of fuel consumed since the last reset, and were very accurate at determining when the oil should be changed (confirmed by UOAs), and as such, oil changes were performed in as few as 12,500 miles, and after as many as 18,000 miles. That said, the last two cars that we bought for my wife came with 7,500 and 6,000 mile OCI recommendations respectively, and on conventional oil they were just about right. That said, the UOA results showed that when both vehicles were run on Mobil 1 0W-40, an OCI of ~12,000 miles was optimal. As I was only having UOAs run every two years, I targeted 10,000 miles for the oil changes on both vehicles, just to leave a reasonable margin of error.
    If you want to take advantage of such services, here is a link to the company that I use: http://www.blackstone-labs.com/
    Best regards,
    Shipo
    Thanks, Shipo! Great information. I will take a look at it, and arrange for the testing. My goal is to keep the car as long as possible, and at the same time not be gouged by the dealer/other facilities.
    Be well,
    ecogan
    FWIW, I've been running Mobil 1 5W-30 with a 5000 mile OCI in my MS3 and the UOAs indicate that it could easily go another one or two thousand miles. I'd bet that the NA 2.3 could run an OCI of 7500-10000 miles. In any case, the reason I change the oil at 5000 miles is because the dealer gave me free 5000 mile changes for as long as I own the car(which hopefully won't be much longer, but I digress). All I have to do is provide the Mobil 1.
    Thanks - good chatting with you. Excellent info.
    EGC
    I'd have to keep a car about 33 years to get that many miles on it, so in my case I am pretty sure no matter how often I were to change transmission fluid, I'd not get to 250K mi. :)
    You sent off a sample to the lab for analysis, and they were saying my work is overkill? As far as my statements I am speaking from experience, time in the forums, and friends/mechanics. This thread is helpful but I am not going to perform research to satiate your obvious desire to always be right about everything, we all love a know it all :) . A question was posted, and many experienced answers and “best guesses” were posted in response which is the nature of informal online forums. If scientific proof is part of your criteria to validate a statement made here, then the burden of proof is on you, as it was your unsolicited response that initiated this little fracas. I am sure the other users on this forum would rather not click through any further pointless posturing, on this site if information is useful you take it, if not you leave it.
    Good Day Sir
    Ha, yes I suppose that is true for many. I put on 20K miles in a year easy :) .
    I see, so you make an unsubstantiated (and technically incorrect) response to a question, and then when someone challenges your statements, you get ticked off and attack.
    MazdaZoom = zero credibility
    Let's back off making this about each other and stick to the cars please. Thanks
    I'm hurt; I thought I was "Mr. Know-It-All"
    :cry:
    Ha! yes yes, I prostrate myself before you and beg forgiveness :).
    mazdrvrmazdrvr Member Posts: 112
    Is the 30,000 mi maintenance service really necessary? If you skip the service, what do you do for maintenance instead? Honestly, i'm trying to hopefully save $ (dealership charges $365). I do know besides oil change, tire rotation the transmission fluid and air filter should be changed. Does the service include changing the cabin air filter? (I could not find the list of services online)
    Mazdrvr - I would not skip the 30K mile service. My brother-in-law has owned Mazdas for the past 20 years, and is convinced that Mazda has a very "honest" service schedule and does not try to sell unnecessary services. If your car has the usual 36K mile warranty, you definitely want to do the service, so as to not void the warranty. One thing you may want to do, is consult a local trusted auto place (I know, they are tough to find sometimes...) and see what they would charge for you for that service.
    Although dealers can be more expensive than local chain-type auto places, it may be worth the extra bucks to make sure a Mazda-certified tech worked on the car.
    I'd get the 30K service; just make sure that the dealer doesn't perform any more work than the Mazda schedule calls for.
    You have to do it but you don't have to do it at the dealer, as long as you have a detailed repair order stating what was done. If you skip it entirely, that gives Mazda an excellent loophole to deny you warranty coverage on any item included in the 30K service.
    You can also discuss with the dealer which items on the 30K list are "mandatory" and which are in fact "optional".
    Thank you very much to all who replied!
    ylzylz Member Posts: 45
    Hello all. Just purchased a 2009 Mazda 3 GT Hatch this week and it's a great car. But I did notice that the transmission seems to be guessing as to which gear it should be in. I mean there are times when I'm at 30 miles an hour and it's at 4th or 5th gear already. That's weird isn't it? Should I take it back to the dealer? I'm hoping that this is because the car is still new (not even 200 miles on it yet) and it will figure it out over the course of time. And also, I noticed that you feel every bump on the road with my car. I knew that the suspension was stiff but didn't realize you would feel EVERYTHING. Again, I'm hoping that this is because it's new and will smooth out later. Let me know what you guys think. Thanks.
    I'd call the manufacturer first and see if that is normal.
    That's a problem with many modern slushboxes; they are calibrated to upshift as early as possible in order to generate good fuel economy numbers. In your case it is probably normal. As for the ride, I have a Mazdaspeed 3 which is fitted with a somewhat stiffer suspension than a Mazda 3 and I don't find it harsh at all. I will note that I prefer a car that lets me know what the steering and suspension are doing. Maybe I'll want a rolling marshmallow when I turn 80, but at the ripe old age of 52 I want a car that is entertaining to drive.
    In my mazda6, it'll upshift early under light acceleration, but under hard acceleration it won't shift until redline. I see this variation as an advantage, not a problem...it could stand to be a little less "aggresive" on the early upshifts, though.
    Why not use the "manu-matic" mode if you don't like the automatic's performance?
    My Mazdaheap 3 isn't a slushbox; I was simply pointing out how modern automatics often perform.
    JPSalengaJPSalenga Member Posts: 1
    any updates on the new software and have you found out of what glitches the computer to send the engine light on?
    Mazda gave me the same story. The engine light appears and I take it in, they say it's the thermostat. But the car rides fine.
    They have ordered me the thermostat and it cost 75 for the part and 75 for labor.
    Then I read your forum and after you've replaced it the engine light re appears!
    If you have any new info to pass on of this problem.
    Pls. inform, that would be great
