Dakota 4.7 or 5.9
                    I am an extremely satisfied Jeep Cherokee owner
who likes the new Dakota Quad Cab. I was hoping to
get an auto trans with the 5.9L V8, or the 4.7 V8.
I am told that the 4.7 is the same engine as on my
Jeep automatic, which has 200K miles with no major
problems. However, I was hoping to tow a large
boat, so I am looking at the 5.9. Does anyone have
any bad stories/experiences with either of these?
Most of the problems I've seen here relate to the
5.2.
Also, I was hoping that the Dakota's
shift-on-the-fly part- or full-time four-wheel
drive was the same transfer case as Jeep's Select
Trac, which is outstanding. Does anyone know?
Thanks for your input.
5.2.
unlike the 5.9 and is way smoother!....oh by the way the new dakota with the 4.7 is faster than the x-cab r/t in the 1/4 mile....hmmmmm
In deciding between the 4.7 and 5.9 for towing, it would depend a great deal on how often you tow, under what conditions (hills/mountians), and how heavy a load.
How heavy is your boat and how often do you plan to haul it? A 4.7 with a 3.92 rear will tow quite a bit. Then again, so will a 4.7 with a 3.55. Unless this is a monster boat, the 4.7 will likely suit your needs equiped one way or the other. The other benefit is you will not have to suffer the pour mileage of the 5.9 when not towing. Quadrunner500 is right that, for heavy loads, there is no substitute for cubes and torque.
y2ktrd,
Can you or anyone tell me where this test was done or where the times were published? or is this just a "it feels faster" type thing. I agree the 4.7 does feel very quick, but I find it hard to belive that it will accelarate faster in the 1/4 than a 5.9.
Yes the 4.7 is close on HP to the 5.9, but is lacking in torque which makes a HUGE difference when accelerating a heavy vehicle with an automatic. In an identical truck, 10 more ft/lb of torque will make a truck accel quicker than 10 more hp. Given the same gearing and tire size, is it possible that the new automatic mated to the 4.7 is so much more efficient that it will out accelerate a 5.9? Possible, but I doubt it. Especially once higher speeds (wind resistance) becomes a factor.
I think a 4.7 will tromp my 5.2, especially down low, but comparing the two when cruising at 70 and stomping on the gas, my 5.2 seems to accelerate faster than the 4.7 from that speed. Yes, that is an "it feels like" statement.
It would be interesting to see numbers on identically equipped (tires/axle ratio) vehicles except for engine and tranny and get some hard numbers on 1/4 time, 0 - 60 time, and 55 - 70 times.
Please post if you see any reviews that have such numbers (even if it is only on the 4.7).
Chad
>>torque will make a truck accel quicker than 10 >>more hp.
It depends on where that 10 hp is in the rpm range. If the extra 10 hp is around the 2600 rpm range, for instance, that translates into about 20 added lb-ft of torque (using the formula hp = torque*rpm/5250). Since trucks rarely go over 5250 rpm, 10 hp is always more than 10 lb-ft of torque.
I think your point, though, was that added torque down in the low rpms verses added peak horsepower (usually in the high rpms) is better.
I agree with that.
-powerisfun
A TEST ON IT ALONG WITH OTHER TRUCKS ALSO.
(I FORGET WICH ISSUE IT WAS THOUGH SORRY)
THEY SAID AT THE END OF THE ARTICLE THAT DODGE SHOULD TRY AGAIN WITH THE R/T WITH A MODIFIED 4.7
The 4.7 is probably faster in a quarter because it breathes better on top,and it's lighter rotating mass revs quicker.It probably picks up the few thousandths at the big end of the quarter,at about seventy where noone on the street will ever care.
And now a little information...
at 1000 rpm the 4.7 makes roughly 50hp and 225 ftlbs,5.9 makes roughly 85hp and 325 ftlbs
at 2000 rpm the 4.7 makes roughly 85hp and 255 ftlbs,5.9 makes roughly 140hp and 335 ftlbs
at 3000 rpm the 4.7 makes roughly 140hp and 280ftlbs,the 5.9 makes roughly 205hp and 345ftlbs
at 4000 rpm the 4.7 makes roughly 200hp and 290ftlbs,5.9 roughly 240hp and 340ftlbs
4.7 peaks at 235hp@5000rpm,295ftlbs@3200rpm
5.9 peaks at 250hp@4500rpm,345ftlbs@2500-3500rpm
This being said I think that the 4.7 would probably still pull any boat the Dakota's frame will handle,if your boat is approaching the 6000 pound plus weight rating of a Dakota then I would suggest a fullsize anyway.The real issue between the 4.7 and 5.9 is one of how much power do you like,not need.Either will do the job the 360 will give up gas mileage but will deliver more torque and more perceived acceleration between stop lights.The 4.7 will give plenty of power,gain some gas mileage,but is still an untested design compared to the venerable 360.Anyone who tells you the 5.9 liter is a dog has probably never driven one,or something was very wrong with the one they drove.
I have posted elsewhere a topic on the replacement for the 360 and it is not related at all to the 4.7,it is a clean sheet design,the bore centers on the 4.7 limit it's size.The new engine will be a true Hemi,354 cu in.
robert
5spd manual? Somebody earlier said the shifting
could be rough. Any thoughts?
The more general comments I made about the new generation engines downshifting more than the old seems to be across all manufactures and I suppose is do to the lack of low end torque when compared to the engines they replace. Most do still have plenty to get the job done and more horsepower, but I am talking about comparisons with the engines they replace. The powerbands are just different and the new engines seem to need rpm.
You probably meant the 5.3 in your friends silverado. 5.4 is the Ford Triton engine.
The first thing I noticed about a friends 99 Silverado with 5.3 was how much it downshifted on the hilly backroads compared to his previous truck. I know it wasn't just me because he said he was finally getting used to it shifting more often. It downshifted out of overdrive way more often than his previous Chev with a 350. He (and I) still love the truck, though, and he has had none of the problems some other Silverado owners have had.
Chad
good luck,
robert
Under fairly heavy throttle acceleration at speed, my 5.2 seems to either stay in overdrive with the TC locked or downshifts in this sequence: first TC unlocks and a second later it downshifts(At full or near full throttle, it, of course downshift immediately). It seems to take a real precise effort to get my 5.2 to only unlock the TC without downshifting. Dragging the brakes at highway speed being the only time I've seen it (this was when the truck was new and I was seeing how the TC was setup).
There is not near as much rpm change when my TC unlocks as I experienced with the 4.7, but this could be attributed to different engine/tranny designs or it could have actually been a downshift. I'll have to go for another 4.7 test drive and pay more attention to that particular thing this time. Good excuse, anyway.
I have not order my Quad yet. I will likely wait until they are off restriction (4x4, limited slip, and handling package, all of which I will order). May end up in a 2001 if this keeps up much longer. Thats OK though, still happy with my 98 extended cab.
Chad
Bad news (to date - is it just me?): This little pickup sucks (fuel) = about 14.5 in mixed driving. Of course a tankful (about 300 miles) of my typical driving is usually 50% 'zipping' quickly through town, 20% of 75 mph cruising and about 20% at 90 mph (or so) on totally empty, brand new, smooth as silk two lane blacktop - with 10% dirt road & an occasional (maybe) hour of idling. When I try to get some real figures (driving sanely), I get 15/19 @ best. Needless to say, my O/D switch is off a lot of the time. Come to think of it, it's pretty good mileage all things considered...
Also, several of us including: henne, bpeebles, myersed and others EXCEPT bookitty (who will never get his truck) :-O are trying various ways of adding additional mileage. Won't know till they're all 'broke in' and all the goodies (KN filters, upsized tires, different rear gear sets, cat
back exhausts, etc.) have registered in with some longer term results. All that said, the 3.9 'might be' a little 'underwhelming' in this particular truck, and haven't, by any postings - or my local dealer reports - been getting any significantly different mpg's.
Bookitty
4.7 whisper down the road and roar when i ask it,
and its all thanks to (houtslaw), that tsb fixed my
ticking and my truck is so quiet i cant believe
its the same truck, the dealer was so confused that
this would actually work, but whammo, ticky gone,
ticky gone gone.
the tsb is for trucks with the 4.7 made before nov
23rd 1999, so go get this done now, it will change
your whole outlook on your truck.
robert
Whichever engine can do the job for the least cost. (Fuel, Maintenance, repairs....etc)
Anyone who has to truck for a living will tell you this.
It has already been stated that the 4.7L uses less fuel and "just makes the most out of its power..."
If the 4.7 fits this criteria.. so be it!
Only the test of time/miles will satisfy the rest of the equation... (RELIABILITY!?!)
Why then is it such a great towing engine? Not suggesting it isn't - just asking.
evidently someone at Dodge missed this when printing the brochures and caused a lot of problems for them. the 5.9 runs very well and could tow almost anything if not for this oversight. R/T owners were offered several options all the way up to repurchase of the truck.
since my dad does not tow anything heavy he chose the $500 in Mopar Performance Parts. he got the new PCM engine computer and man what a difference!
before I thought my 4.7 would give it a good race, not now! throttle response is instant and it lights the tires up!
Bookitty
it is unwieldy to manage, and difficult to use for "newbies". There is entirely TOO much topic duplication, so I will be doing some SERIOUS topic consolidation in the next few weeks, getting us down to not more than 2-3 topics per vehicle type, and ultimately down to 200 topics or less.
THIS weeks consolidation candidates are: F-150's, Silverado's, Dakota's, and Dakota Crew/Quad cabs.
In that vein, please consolidate this Dakota topic to Dodge Dakota - III and continue these discussions there.
Front Porch Philosopher
