1. 1st time Took it to dealer first t they said " yup its normal .
2. 2nd time when it got loader Yup its normal again
3. 3rd I called toyota customer car they said : " its up to the dealer to see if there is a problem and we cant do anything if the dealer says its normal
I went to the dealer ( its now summer and the knock is not as load when warm but you can still here it ) and they said" we could hear it "
WTF does toyota TCC and dealers just blackball their customers now
Now my trainy is shifting hard and slips a bit when letting off gas then coming onto it again .
KL67- can you give me some wording to use when I call toyota customer care so they wont give me the same BS run around
I am really fed up as I thought toyota would be a best built truck and worth the extra money than buying from the big 3 but this 5.7 L is looking like a lemon
Don't know what had happen since then, but it's flashing right now, I've been driving with the "flasher" for 40K miles now. costco tire checked and the sensor does broadcast, you are right about 120$ per sensor.
However, for some reason, it runs sluggish and I was told by the mechanic that I need the fuel filter change. But when I talked to a Toyota mechanic, he told me that I have to change the whole system; fuel pump since it came with it. And on top of that it would cost me $1000.00.
Can someone give me an advise, I am confused since other mechanics don't charge me that much in their bid.
Thank you,
Craig
Toyota is not telling anyone of this problem so I will. Vehicles with flex fuel have a problem with starting. The ignition turns over but it will not fire. Eventually after several attempts it may start however from that point on the vehicle will run rough as if the choke is on. It will definitely run more rich until it is fixed.it will need to go in for service every time you get 7-8 fillups.Toyota indicates all you have to do is move to a warmer climate where it's over 50 degrees, don't drive less than 5 minutes. Never run less than 1 quarter of a tank of fuel.they also said that I can bring it back for service anytime it does this. It happens to me about every 2 weeks. I drive almost 50,000 miles per year and it doesn't take long to fill up 7 times.Toyota will not let you out of your lease and will not offer a new vehicle so itthe only solution that I could see is go to the lemon law and get an attorney.Toyota has to pay attorneys fees under the lemon laws. personally, I feel what they are doing is fraud. They know there's a problem they do not have a fix they continue to sell these vehicles and do not let you out of your lease or replace the vehicle.
I am a repeat customer of Toyota many times but that doesn't seem to make any difference. Beware of Toyota's problems they do not provide any quick solution.I bought a new vehicle thinking I would be able to depend on it. I don't have time to drive to their service garage every 2 weeks. They have had my truck for 2 weeks this time this is the third time in.
good luck to anyone with this problem.
