I plan to rig my NAV unit up so I can switch the rear camera circuit on at any time, and also so I can enable all the features even while the vehicle is moving. I assume there are two wires leading into the NAV unit which provide voltage when the vehicle is in reverse or in motion. If so then it should be as simple as finding out which wires are used, opening the dash to get behind the NAV unit, and connecting two jumpers to the harness which are wired to two small toggle switches which can then be mounted in the dash. If anyone has already figured this out or knows where I can get a wiring diagram for the NAV unit then please let me know.
I purchased the wiring manual from the dealer for my 2002 Tacoma and it cost me about $50 - what a rip off when you pay so much for the vehicle to start with. For the Tundra it might be worth it though since I also have other electronic projects planned including the installation of a remote PC server complete with DVD drive, MP3 and video streaming, wireless networking, wireless keyboard and mouse, and dedicated video monitor mounted on the ceiling. I already have most of the hardware and just need to find time to complete the install.
Another thing I found out today: my expensive Tundra with MSRP of $42K does not include the glass break sensor even though it came with the security system. This is like selling you a car but then charging extra for the glove box. Grrrr.... :mad:
As for the Tundras being made in the USA: my understanding was that they are primarily made in Japan but then shipped to the USA where they undergo final configuration and installation of some option packs. If this is not the case and the truck is 100% made in the USA then I am actually sorry that I bought one. The whole reason I got Toyota in the past was because the Japanese manufacturing was superior in quality, durability, and reliability to anything else that was made in the USA. Don't get me wrong, I am a very proud American and prefer to support America first, but the ridiculous labor unions and other costs of vehicle manufacture in the USA have forced all American manufacturers to deliver a sub-standard product and/or a much higher price. If Toyota has in fact moved all manufacturing to the USA then I don't expect to get 200K miles or anywhere near that on the Tundra - for American trucks it is usually more like 80K-90K before major issues come up.
You are delusional...what a load of BS!!!
Sorry someone really mislead you on this. Ever since they came out in 1999 more than 75% of the parts and 100% of the assembly has been done here.
Almost nothing in the new Tundra comes from Japan. Initially the first few 5.7L's have since the Alabama engine plant is ramping up to add this engine to it's others.
Everything else is made here.
As to the quality of the American labor, at any modern manufacturer. your thinking is just wrong. With all the technology in place, which is the same at every plant, there's no reaason any modern vehicle shouldn't take you well over 100K mi if not 200k mi with proper care and minimal extra costs.
I've had two KY-made Camry's that went in excess of 175,000 miles and no extra costs at all and a Japanese-made MR2 Spyder that lost two electronic controlers @ 34000 mi which would have cost $4800 so I sold it.
just look at the camry/accord/civic...etc...then you'll realize that it doesn't make a bit of difference where the vehicle is MADE!
how about a small fridge and a microwave while you're at it? Then you could google, pop corn, get a cold soda, and listen to the boneyard on your way to Radio Shack to pick up a new pocket protector.
The wireless network is primarily so I can transmit MP3 and video files to the truck from the home or office, but also so I can surf the web via broadband for free while traveling. Why pay $10 or more per day for a high-speed connection in a hotel, or suffer agonizingly slow dialup speeds when you can connect via your Tundra for free?
And if it wasn't for the pocket protector I wouldn't have been able to afford this truck in the first place... LOL
Switch (Operation description only)
• Operates VSC, TRAC, and Auto-LSD
Features
When you first turn Tundra on:
Summary: VSC ON/AUTO LSD OFF/TRAC ON
How to operate:
• Step 1: Briefly pressing the VSC OFF
switch (See Image A) in start-up mode will put the
system in TRAC OFF mode, which will
activate AUTO-LSD and its indicator
light on the voltmeter (See Image
Summary: VSC ON/AUTO LSD ON/TRAC OFF
• Step 2: Press and hold the switch for 3
or more seconds with the vehicle
stopped to disable VSC, TRAC, and
Auto-LSD. This illuminates the VSC OFF
light on the left gauge of the
combination meter (See Image C)
Summary: VSC OFF/AUTO LSD OFF/TRAC OFF
• Pressing the switch a third time
reactivates all systems
• All systems will automatically be
reactivated if the Tundra is shut off and
turned on again (default mode)
For information on how these systems operate, please turn to
page 56 in the On-/Off-Road Class Section
EXT/INT/UTILITY CLASS
Image A Image B Image C
VSC OFF switch (above) located on the dash below and to the right
of the steering column.
VSC:
"The VSC system electronically monitors speed and direction, and compares the vehicle's direction of travel with the driver's steering, acceleration and braking inputs. VSC can help compensate for loss of traction which can cause skids. It utilizes some components shared with the Anti-lock Brake System (ABS) and an electronically controlled engine throttle as well as a dedicated computer and sensors providing information to the VSC system. These include a yaw rate sensor, a G-sensor and a steering angle sensor. When VSC is active, a warning beep tone and instrument panel warning light indicate that the system is functioning. In many cases, VSC reacts well before the driver is aware of a loss of traction. As with other safety technologies, such as anti-lock brakes, it is important to drive safely, since Vehicle Stability Control cannot defy the laws of physics, nor can it provide more traction than exists in a given condition."
TRAC:
"The sophisticated Toyota system is an all-speed design that utilizes both brake and engine throttle control. TRAC helps to avoid slippage of the driving wheels by slightly applying the brake on a slipping drive wheel and reducing the throttle to maintain traction according to the road surface conditions. The system eliminates the need for a subtle accelerator pedal operation and helps ensure vehicle control when starting or accelerating on slippery roads."
AUTO LSD:
"Automatic Limited-Slip Differential (electronic) system helps deliver torque to the wheel with traction."
The above definitions seem to overlap with each other and it is not clear when I would normally use each of the three modes controlled by the VSC OFF switch. Here is my best guess:
Mode 1: VSC ON/AUTO LSD OFF/TRAC ON
Use this default mode for normal driving. If you begin to slide, skid, fishtail, or slip then the VSC will kick in and try to correct the problem for you. The VSC dash light will come on and the warning tone will sound when VSC is in action.
Mode 2: VSC ON/AUTO LSD ON/TRAC OFF
Press the VSC OFF button once briefly to use this mode when a wheel is stuck in the mud, sand, or snow and you are trying to dig out. This transfers power to the wheels which have a grip to get you unstuck faster without digging further into the hole.
Mode 3: VSC OFF/AUTO LSD OFF/TRAC OFF
Press and hold the VSC OFF button for 3 seconds to disable all functions. Not sure when this would be helpful, perhaps for off-road driving?
Does this all seem correct?
Damn, I had NO idea someone could order a new Tundra from GMC.....this IS the Tundra Owner thread, isn't it?
Sorry, I'll go back and play on my own playground now.
the fuss is that only certain tundra's are out there, yeah, if you want a 4x4 limited, or SR5, they are there. But, I have yet to see even 1 4x4 TRD SR5. That is what i have on order. I have visited one Stillwater dealership (where i ordered from) and 2 dealers in OKC and 3 in Tulsa. NO TRD 4X4 SR5's, None!
yes, every dealer initially got at least 4 tundra's. but for that kind of cash, i wanted one built to suit. i wasn't going to settle for "what's sitting on the lot".
But wilee has given me an idea. I will be patient, but only to a point. I ordered a truck through my local dealership, but at some point soon, i will begin looking "out there" for my truck configuration. I will inform my dealership that I am doing this, and that if I find my truck, I will go get it. then the ball is in their court to get me one, or I will expand my search.
after all, i have not put anything down on my order. didn't need to since i have bought a camry from them last year.
Our family (even though we're in central Texas) has had good luck going to Las Cruces, New Mexico to get vehicles out of the Gulf States region (plus, their selection of 4wd vehicles tended to be better than what we saw locally).
anyway, i talked to him today and he told me typically "special" deliverys take between 30 and 90 days, and that i could expect closer to the 90 day mark. Another factor is that the san antonio plant has not been tested. we don't know how productive they are.
toyota on the other hand will start pumping 08 tundras on the lot next january. just the way they operate.
go ahead, jump in there!
DrFill
TROLL....
Once you sit in a limited there is no going back. Keep in mind I originally walked in there 100% sure to buy the Tacoma PreRunner or SR5, then when I sat in the Tundras there was no going back to Tacoma either. This new Tundra is like crack on a street corner in the ghetto: very addicting, gone within minutes, and if you are not careful it can get you in a lot of trouble, or even kill you... :-)
As I called around to 5 other dealers in TN I found most did have at least several Tundras on the lot as well. When I told them that Beaman had the exact truck I wanted in-stock but would not deal with me on price, several of them quoted me the same or a slightly better price and were hoping to get the truck on trade from Beaman, which was honestly not going to happen because Beaman wouldn't give it up, but when they called Beaman to ask about it this helped to motivate Beaman to drop the price some more.
When you walk in to the showroom and flash a lot of cash for the down payment, a pre-approved certified check from your credit union, and you offer to finance through Toyota or the dealership just to get them some extra points, this will get their attention in a hurry. If you finance through Toyota or the dealer you can just pay it off with your credit union check anyway and take advantage of the savings they gave you for initially financing with them. I also called several dealers in GA and KY even though I didn't really plan to shop there. They were close enough that Beaman knew I would make the trip to save $300 or more so this puts pressure on them for the price. On my RAV4 I found the exact vehicle I wanted in KY. Beaman beat the KY dealers price and then went to get it for me, plus they gave us $100 cash to go eat dinner and have drinks while we waited for it to arrive. I have tried lots of dealers for new and used cars but nothing beats Beaman if you know how to shop.
Their service is also first rate. Unfortunately I know them very well since my 2002 Tacoma was hit 4 times! in as many years. 3 were not my fault, 1 was no fault, and 1 was an illegal immigrant with no insurance when it was less than a week old off the dealer lot brand new. Talk about hopping mad.... :mad:
Toyota math???
Well, you'll probably need to buy one that often....
How about.....GM has a superior product??? There, that was easy.
You're really reaching now. Comparing crapola like that....
Starbucks and GE? Do they make trucks now too? May as well, they have just as much experience in this segment as Toyota does.
Toyota math???
Very funny wiseguy. Numbers were not mutually exclusive.
GM, Chevy, Ford guys can click here for the definition.
Your fault or not, sounds like you need to take a Defensive Driving course.
"Silly rabbit, Toy trucks are for kids"
I've got to test drive the CrewMax and see how much room there is in the back seat after two car seats and a 100 lb dog. My wife wants to wait for the new '08 Sequoia...I'm opting for the Tundra CrewMax. My wife is 5'1" - she's worried that a.) there won't be enough space in the back seat, and b.) she won't be able to get the kids up into the car seats. Anybody have experience with this on the double cab? I assume the cab height is identical.
What is wierd is that I am ready to buy that sucker right now today, and nobody can seem to find one; but, according to the build software and brochure, i can get one exactly the way i ordered it. kind of funny.
time takes time, i guess.
HAS ANYBODY OUT THERE EVEN SEEN A DC 4X4 TRD YET? EVEN ONE?
DC SR5 TRD leather 4x4, power bucket seats w/ console shift, xtra front skid plate, running boards, rear underseat storage, heated tow mirrors, cold kit, night mirror, shield package, faulty fuel gauge, dealer installed toyota backup camera, in blue streak.
$37, 200 out the door.
Spyder, you're the man! Your info has been on target from git go.
THANKS FOR YOUR ADVICE ALONG THE WAY TOO WILDBILL.
sure, I bought one in Clarksville, TN 11 FEB and noticed two today on the lot in Richmond, KY.
I guess they are coming though.
Or do you just post on here for your ego?
BTW, do you own a new Tundra? Or any truck for that matter?
If you would click on my profile you will see I am with Toyota in sales so I post on here to answer peoples questions about their new trucks, what options they can and can't get and to explain about the new features
so why again are you posting on this thred other than to be a TROLL
My Tundra right now is just the best you can get, averaging 18 mpg, nearly 4k miles, and it rides like a truck.
Best Gas Mileage: 21.1 MPG
Worst: 9.5 MPG
Average: 18.0
Current Mileage: 3899 miles
No problems at all. The 6 speed tranny is superb, quick and easy acceleration. BTW My Tundra has a TRD off road package, and just go through anything off road!
