Bob
I saw a white Ridge as I traveled home last week, the only one I have seen so far in Fresno.
Glad you like your Ridgeline. How did it do in the snow the last few days?
John
It beats the Corvair hands down, I can sit in the driver's seat to change plugs.
When the carb needs work, just move over to the passenger's seat.
3 on the tree too. Now the truth is out--there is stiff competition here for looks with the Ridgeline.
John
Bob
John
Look at the absolutely in-your-face, upright, flat plane that the International-like Ridgeline's grille is on, and look how the Ridgeline's front fenders are pulled back, much like the International shown here. Plus the wheels are set back, again much like this International with the set back front axle. I really think Honda was trying to capture some of the "big-rig" feeling with their truck. I'm not saying they were totally successful, but I do think that's what they were trying for.
Bob
I know I am an odd duck, but I thought that the pickup versions of old '60s vans were far more functional/practical than the pickups themselves. The biggest reason is just that they made such better use of space! Nevermind that they were hideously out of proportion, they were functional. I love my '69 Econoline van, but if it was a pickup version of itself, it would be even more functional than it already is... and all in a very compact package. It is about 2 feet or more so shorter than my standard cab, 8' bed '69 C20 and has just as much cargo and cab space if you forgive the intrusion of the "dog house."
Okay, so I am hopelessly off topic. What were we talking about again?
1) There is no place for the engine heat to go, except into the cab
2) The speedometer is so far away from the back of the tranny, you have to custom fabricate the cable and guide, this was about $100 5 years ago.
Other than that, you are right.
Interestingly, my E-100 Pickup has a 400 lb cast iron plate bolted underneath the bed between the fuel tank and the bottom of the bed. This is to keep a little bit of weight on the rear end.
Sorry way off topic.
John
What are folks getting for MPG?
Thanks for the help
Savvygal
How often do you tow, and how far? Many (any?) steep hills? If it's not too often, or too far, or too hilly, the Ridgeline would be okay I would think.
Bob
Thanks for the input
Anyone else with thoughts? These Ridgelines are so new around here that I can't find anyone locally to ask.
Bob
I've heard from a Honda factory worker that motor oil will fix up those scratches. Let us know if it works. Personally I will be using a 4 X 5 foot piece of plywood in the bottom of the bed for those occassions when I haul things that would leave deep scratches. You could paint the plywood flat black and it wouldn't even be noticable.
"I saw a white Ridge as I traveled home last week, the only one I have seen so far in Fresno.
Glad you like your Ridgeline. How did it do in the snow the last few days?" Not enough snow to notice. I see a woman driving down the hill in a white Ridgeline every day when I'm on my way up.
So I guess some people think it looks like an Escalade pickup. Someone else asked if it was a new H3 Hummer pickup...
I thought I was doing it wrong! I have the same problem. Did the dealer figure it out?
I have had my RTL with moonroof for 2.5 weeks and already have a 8-10inch thin white scratch on the floor. I was really surprised to see how easy it scratched.
Thanks for the tip to get trim paint from auto Zone.
bcp1 :surprise:
Anyway, if they can easily do over-the-rail edges or the edge on the center of the bodyline on the Silverado and have both look clean I don't see why they can't accommodate your in-bed trunks and still cover the rest of the painted surface for you.
Seems to me this is one small oversight on Honda's part so far that will affect people using these as trucks, even for general homeowner use. I wouldn't be too surprised to see them make some sort of change in the next model year or two to fix the issue either.
It would appear the Ridgeline's bed has the same problem.
Also how tall is the side of the truck bed? It appears too tall to lean over and pick something up from the bed floor. Lets say like a hammer or some other tools. The new F150 has this problem unless your well over 6' 6" tall. The sides of the bed are just to high.
I did see one at the local Honda dealer when cuising by. It is better looking in person than the pictures.
--jay
If it were my truck, I'd probably take the extra second to toss stuff into the trunk.
The Pro-Tec beds have held up very well in extreme conditions. I would expect the Honda bed to hold up well also.
The scratching issue is a cosmetic problem, not function. Steel bed will scratch easier than the composite.
As far as throwing firewood in the bed in below zero weather, don't worry, you could throw bricks in it and it may scratch, however, it will not break.
Perhaps they have bigger fish to fry.
To Other Post: I read somewhere you CANNOT put on bigger tires.
Both of them have temporary use spare. Had to order a replacement tire and this rendered vehicle unusable for anything other than a very short trip.
Full size spare tires only please!
Spare tire location in the "trunk" of the Ridgeline is fine. There is no perfect location.
I understand that no surface can be 100% impervious to damage, but sure sounds like Honda screwed up given the advertising it did about the benefits of it's composite bed.
Either way it still should perform better than a conventional metal bed that is easy to scratch and rust. After all the bed is designed to be used for hauling all kinds of things, and the only way to keep it brand new is not loading anything in the back.
What happened to the reviews that referenced Honda's tests that dropped a full payload of rocks into the bed, removed them, and then showed that the bed looked as good as new with no scratches, dents, etc. More false advertising?
The surface is impact resistant and dropping a rock or hitting it with a hammer has little effect. Drag a sharp, heavy object across the surface and a scratch is possible, if not likely.
If you don't care for a composite bed, there are other truck choices available with a steel bed.
Ridgeline owner in Wyoming
Question: has anyone had a good experience plugging an iPod into the Aux jack? I used my Bose head phone connector to plug my iPod into the jack, but the sound that played through the stereo system sounded like it was coming out of a tin can. I probably did something very wrong. The owner's manual gives no guidance on this.
Anyone have a good experience they can tell me about? How do you do it right?
--John
Have you found one?
