yep, there's alot of BS on the net, and you can add that story to the list. I've been in mud and deep sand with the Ridgeline with no problem. I assure you that's a BS story.
My wife's partner also subjects her RL to rutted washbaord dirt roads on a daily basis and her struts are just fine.
are all LIES too huh??????????????????????
Bob
Just kidding, before anyone has a stroke!
This is what a Honda insider had to say, and from my personal experience with the Ridgeline, I believe him. It's sad when people are so proud they can't fess up top what they did.
Given the road they drove on, it is widely know this is a severe surface and road that must be treated with respect. They also failed to mention they failed two tires in this run due to the sharp shale on the surface. Due to the ride damping qualities of the Ridgeline, I suspect the vehicle was driven very fast over this surface at a high ambient temperature. Based on the description, the seals failed in the struts as well as the dust shield. The temperature extreme that was required to trigger this failure is so severe, there must have been an extreme input (temps greater than 300F).
I doubt that a Tacoma could be driven controllably on that surface at the same speed/duration as the R-L. With the live rear axle, there would be so much axle hop it would be impossible to replicate the speed that is possible in a Ridgeline. During a recent trip an acquaintance made on that same road on a rental SV, they experienced 2 flat tires that had to be replaced and saw numerous other vehicles broken down along the route. Edmund’s conveniently left out the detailed facts describing the route.
The only thing I would say is that 50 miles at 20 mph is a fairly long trip on a bumpy road. If the driver was forced to slow below 20 mph for specific rough patches, it is entirely possible he learned the need for slowing down after experiencing a few good hits.
It was 100 miles, 50 miles each way. If anybody has driven on a rutted washboard surface for even 10 miles at 20 mph, they know it's not only a long trip, it's an eternity.
The fact is I find even myself (having bought my truck) being impatient and going faster than any vehicle should on these kinds of surfaces, however; I'm not concerned about strut failure, but developing a squeak or rattle in the dash. 100 miles would be torture to drive that slow, and I doubt the driver would be that patient to take it slow when the vehicle will do 40 mph or more on this surface.
My BIL owns a Ridgeline and we'll end up wheeling it on a beach and maybe the trails at Paragon. That's probably a whole lot more than most other drivers will do. We'll see how it goes.
I've had the RL in deep sand without even needing to air down the tires with no problem, but there are many different kinds of sand, so you have some different options in the RL.
-air down the tires to 15 psi
The problem with this is that when the tires are down this low you can not turn off the VSA for safety reasons. You can turn off the VSA by simply removing the VSA fuse. If you do this, you should have a good sand machine.
Like I said, I have never even needed to air down, but it's good to know if you need to.
I know your pretty informed, so you might have already known that.
A simple search at ROC with the term "struts" will
suprise you. Several threads both new and old with
strut issues so its not limited to "first year jitters". Not to mention posts from owners of a ridgeline and
another honda vehicle with strut issues.........
I wonder if a few models use the SAME struts ?
I know about problematic vehicles !!!!!!!
I read about MANY vehicles. The ridgelines problems
are well known and posted on several threads.......
One of my customers has a new 'ridge and is having
water leak issues. The dealer has been stroking him.
Hes quite unhappy as the nearest honda dealer is 40
miles away!
I am sure he is over at ROC at this moment.................
You've got a job? That must mean your some sort of adult. That's kind of sad. I thought you were a kid. you should go back to pickuptruck.com and lick boots over there.
ROC on strut failures and replacement.
Denile is not only a river !!!!!!!!!!!!!!!
Should I bring all them to the top for ya or just post
links from here? Maybe a little cut and paste?
Check out the ridgelinesut forum also for more.....
JOB??????? Nah....i don't have a "job". I am the BOSS
and OWN my own businesses. i have LOTS of time!
If you're make accusations—prove them.
Bob
ANYONE can plainly see those strut problems from REAL
'ridge owners.............
Not to mention the Edmunds long term test vehicle....
so what's the big deal?
On the other hand, a search for "strut" in the ROC forums doesn't reveal a lot of strut failures as another poster implied. A lot of cases of wind noise and water leaks, which is well documented on many forums on the early Ridgelines, but I didn't see a lot on struts.
I have always valued Edmunds' reviews along with those of many other sites and magazines. If they say they blew 3 of 4 struts and were not abusive, I believe them. However, I don't see a lot of evidence from other sites/magazines about RL strut failure, so it doesn't seem to be as big a problem as the wind noise and water leaks were. Similarly, one of the struts on my new Civic lost a seal in pure street driving, but I'm not overly concerned about it.
Bob
http://www.automotive.com/2005/12/chevrolet/silverado/recalls/index.html
http://www.autobuyguide.com/2005/12-aut/chevrolet/silverado/recalls/index.html
http://www.mycarstats.com/auto_Recalls/CHEVROLET_SILVERADO_Recalls.asp
http://ohiolemonlaw.com/safety-recall-32.shtml
http://www.carcomplaints.com/Chevrolet/Silverado/2001/recalls.shtml
http://www.automallusa.net/2006/chevrolet/silverado/recalls.html
BTW, no strut recalls (or any recall) yet on the Ridgeline...
http://www.automotive.com/2006/12/honda/ridgeline/recalls/index.html
...but your beloved Chevy Silverado sure has had a lot of recalls.
Bob
That's right. The water leak was a much bigger problem. I had it on mine and it was fixed and I will be happy to complain to anyone about it. To keep going off on this strut issue is a waste of time, its the least of the Ridgelines problems. I did the search on the ROC I don't see all the strut posts that are alleged. I don't think that the strut complainer is going to change anyones mind here.
I'll be the first to ask Bob the Silverado guru a question.
Bob, for campaign 05V055000, how much time will it take a technician to complete the repair?
I don't see a lot of evidence that the RL does anything other than commute and make trips to Home Depot.
I have no idea, but whatever time it takes, it's time away from doing normal preventative maintenance and repair.
I will say this, at least all the recalls are keeping more mechanics employed.
Bob
Uh, so what? Is having a truck a a macho/poseur showdown? I use mine to commute and occasionally haul stuff. What do I care what someone else thinks. Go buy a Ram v8 with 10k towing, 8mpg, I'm sure everyone will be in awe of you. :sick:
the strut issues post on just ONE other site..........
That river of DENILE is deep, wide and murky !
http://www.ridgelineownersclub.com/forums/showthread.php?t=5845&highlight=struts- - -
http://www.ridgelineownersclub.com/forums/showthread.php?t=5202&highlight=struts- - -
http://www.ridgelineownersclub.com/forums/showthread.php?t=3023&highlight=struts- - -
http://www.ridgelineownersclub.com/forums/showthread.php?t=2578&highlight=clunk
http://www.ridgelineownersclub.com/forums/showthread.php?t=3268&highlight=struts-
There is just a FEW from a simple search at ROC........
And sure the Silverado has quite a few recalls and prob.
TONS of TSBs. But ya figure the GMT-800 trucks have sold
OVER 8 MILLION or so !!!!!!!!!!!!!!
Not a PALTRY 53k !
OVER 8 MILLION or so !!!!!!!!!!!!!! angry owners.
Bob
the WHOLE thread/posts from ROC on the strut issues
you SHOULD plainly note comments from other 'ridge
owners to new 'ridge owners that have strut issues.............
But I suppose there are NO water leak issues either eh?
Strut failures have also been noticed in articles/forums
at Car & Driver and Motor Trend. A simple on line search
for "ridgeline struts" will do the trick !!!!!!!!
But you folks already KNEW that !
No one is saying is saying that some early Ridgelines (or 05 Tacomas) for that matter didn't have a leak issue or some wind noise. Those are the only 2 legit issues that you could bring up that would be valid Geo, but Honda has addressed those so what would be the point.
It's simple Geo, if there were a strut issue, there would at least be a TSB on it and there isn't.
Nobody here is is in denial. Unlike you, we all just have put things into perspective. When we see a strut recall or a TSB, then we'll take it more seriously. So as of now, the strut issue is more of an anomaly than anything else.
Bob
He does drive his MDX hard, and he actually takes it off road, but it seems much too soft to handle the abuse. Don't throw too much hate my way...
Geo is their anyway I can help your mudslingin crusade against the Ridgeline? It just seems so unfair that legit owners here are gangin on you coz we can't find anything wrong with our rides while it seems you have uncovered tons of em.I could break a strut or two just to help your cause and give you a tad bit of credibility. Just say please.
By the way how did you got the screen name geo, did you get that from that GM crap with a loaner Toyota engine the Geo Metro? :confuse: No offense meant, just curious.
Thanks for your cooperation.
struts are made by MacPherson (spelling police?) and
other honda models are having strut problems also.
MacPherson is a suspension design not a strut manufacturer.
5,344 vs 3,875 up 38% over last year.
2) Whom has had issues and with what problem for a build date after Jan 06.?
3) Has anyone done minor off roading but with some rocks and such (mud) that has had issues with ground clearance.?
Not looking for a serious off road truck but do want some security that it can handle it if I take it on the Beach or down some trails/mountains?
Yes, if you need to go pick up a half ton babecue, or you need to tow 5,000 lbs of hamburger patties in a trailor to your barbecue, the Ridgeline will work just fine. If the barbecue is located at ranch where you have to negotiate deep sand BLM trails, the Ridgeline will also perform just fine.
Nice try.
