"Like the Mexicans who drool over new cars for a spot in their lives in ten years,"
ARen't you making kind of a generalization about Mexicans? I know plenty of "Mexicans" who could buy one now.
You should watch your mouth.
I doubt a Accord Hybrid will cost $35K. I would guess it will be about a $2K to $3K premium over a Accord V6 EX. And of course it will probably be selling for full sticker.
99 pounds is not heavy.
> Hydrogen vehicles
Hydrogen technology is significantly MORE expensive. The process to create the fuel results in HIGHER overall pollution. And the efficiency is quite a bit LOWER.
There simply is no benefit.
And there will NEVER be such a thing as a pure fuel-cell vehicle anyway. It will actually be a HYBRID, taking advantage of regenerative braking and storing electricity for use later the same way hybrids do now.
JOHN
270hp plus good efficiency sounds good. It's worth paying more for.
I drove and liked the Prius, but 0-60 is slower than the Chevy Aveo (per C&D).
Looks like the Accord won't suffer a similar fate.
-juice
Typically, the best comparisons are made comparing Apples to Apples. The Prius uses a CVT automatic, whereas the Aveo tested was equipped with a manual transmission.
That said, a closer look of the Aveo 5sp's acceleration reveals that in real world driving, it is BARELY faster than the Prius, based on C&D info.
For their 0-60 figures, C&D uses racing techniques, I'm sure you are aware, to extract maximum potential from the vehicles. The rest of us just floor the accelerator from a stop, an event replicated in C&D's "Street Start, 5-60" test.
Using that measure, the times were:
Aveo 5sp 11.0 seconds
Prius CVT 11.3 seconds
It is only logical to conclude that the Aveo automatic would in fact be less sprightly than the Prius CVT in real world driving.
~alpha
I drove it and it feels adequate, actually, just not quick.
The potential for a fun/quick fuel miser is more enticing. That was my point.
-juice
My current impression is that Toyota's approach is the better one for improved gas mileage whereas Honda's approach is better for improved mileage within the higher acceleration performance market. Is this impression correct? Are there other trade offs, pros, cons?
Both Ford, Nissan buy Toyota's Hybrid System!
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
The 50kW motor in Prius is so smooooooooooth that you won't feel anything. There is no vibration from it like you'd get from an engine. So perception is skewed.
So to judge adequacy, you really need to focus on what the speedometer tells you and not what you feel.
JOHN
- Toyota's primary goal is to REDUCE EMISSIONS
- Honda's primary goal is to INCREASE EFFIECIENCY
That difference is significant. And it is by no means obvious. In fact, it is quite commonly not even realized. Studying the design though, it does become apparent.
Toyota has an electric motor 5 times larger than Honda and offers the ability to drive using just electricity. Slow moving heavy commute traffic is where pollution is worse. Emissions are drastically reduced in these conditions, by having that ability to crawl along without the engine needing to run. The steering & A/C are electric too. So that also reduces having to run the engine as often.
Honda requires the engine to run for almost all functions; however, that engine is well tuned for that. So if you do nothing but high-speed cruising on highways and don't ever have to deal with heavy commute conditions, the resulting efficiency will be rather impressive.
JOHN
of this segment is hardly 2 % of the Worldwide sales.
Sales volume was so low.
Again they are planning to sell a hybrid version of V6 Accord whose sales
is hardly 10 % of Accord's 400,000 sales in US.
No idea why Honda is going after such low volume segments.
On top of this, they are selling a manual version whose share is hardly
20 - 30 % in US & Japan which is going to increase their R&D costs.
Toyota is smart in the sense that they are just concentrating on 1 transmission
system and saving the costs.
Also they are going for the 5-door vehicles whose demand is surging every year.
I bet the Accord hybrid will be higher volume.
-juice
system and saving the costs."
That's because HSD ECVT is more efficient than a manual transmission and smoother than even 6-speed automatic transmission.
Dennis
Accord hybrid will have very little performance improvement and fuel economy. I do not think the premium you pay extra might be appeal to a lot of people. 2006 Camry hybrid might give you more bang for you buck. Let's wait and see until more information come out.
Dennis
Current Honda offering Pro:
- Save cost from one small electric motor
- Cost less to make smaller battery
Current Honda offering Con:
- Very little electric assist (36lbs-ft torque at 1,000RPM)
- Can not regenerate and drive with electric at the same time
- Ability to capture little from regenerative braking
- Wear out the battery more due to frequent deeper discharges thus, shorter warranty
- Costs more to manufacture manual/CVT transmission, alternator, starter, clutch/torque converter, etc..
- More complicate than a traditional car
- Variable Cylinder Management(will be in Accord Hybrid) reduces engine drag on highway only
Current HSD Con:
- Costs more to make two electric motors/generators(~20KW and 50KW)
- Costs more to make larger battery
Current HSD Pro:
- Can drive on electric only mode(Stealth)
- ECVT Transmission superior than manual or mechanical CVT transmission
- Huge electric assist (295 lbs-ft torque from 0-20MPH at 1,200RPM)
- Can regenerate and drive on electric at the same time thus, able to drive up hills and recharge battery at the same time
- Ability to capture much more from regenerative braking
- Battery usage is minor due to frequent recharge thus, longer warranty
- Elimination to manufacture manual/CVT transmission, alternator, starter, clutch/torque converter, etc..
- Simpler than a traditional car
- Atkinson cycle engine reduces engine drag(more efficient) in the city and highway with easy, minor modification and costs very little
- More efficient. (Compare lighter/smaller Civic even manual transmission highway 51mpg with faster Prius ECVT in 0-60 or 30-60 and highway 51mpg)
Dennis
Nope. Smaller Insight 1850lbs with 73hp manual(should really compare with CVT) tranny gets 0-60 11 seconds. Bigger Prius 2890 lbs with 76hp ECVT tranny gets 0-60 about10 seconds.
Toyota Volta claimed to get 0-60 in 4 seconds using Lexus 400h HSD.
Dennis
the current civic hybrid sure was an improvement over the last prius and i suspect the same will be true when the next generation civic hybrid debuts. hopefully the next civic hybrid will keep its more conventional dash and not such a "goofy looking" one as in the prius.
of course you only have to wait to this fall for the accord hybrid.
> as in the prius
Have you noticed lately how the body style of the Classic model is slowly become more and more typical? The rigid & boxy look is out. The SUVs are all taking on a rounded & curvy feel now. That makes the older Prius begin to fit in rather well. It also gives the Civic-Hybrid the impression of being outdated. Kind of makes you wonder what Honda will do this fall. Hmm?
So, that makes a person wonder how long it will take before the more practical dashboard layout of Prius becomes the "in thing". People crave change. And the fact that having a speedometer that is not obscured by the steering-wheel and you don't have to look down or refocus much to see it is more practical, makes it likely to catch on. Being the 21st Century and not having a screen on the dashboard is a bit odd too. Even the cheap cell-phones have color screens. Why shouldn't a vehicle, especially when the screen can be used as a cell-phone interface? It can also be used in conjunction with a camera to make backing up safer & easier. Info on the hybrid system operation is quite useful too.
JOHN
Those who can't live without a manual transmission might go for honda hybrid design. As for the next generation, I don't see improvements other than bigger battery and motor(s). Honda might adapt to Atkinson cycle engine. I don't know how it will go together with I-VTEC.
Dennis
In summary, I have been under the impression that Toyota's hybrid technologies are more advanced than Honda's, guessing that this was the case due to Toyota having gained exclusive patent rights before Honda for certain technologies. The longer lists of Toyota pros and Honda cons seem to confirm this possible reality.
My interest is in knowing more detail re: the Honda and Toyota hybrid efforts, in particular which company's technologies are better and to what degree exclusive patent rights come into play in the competition. I could care less about what Detroit is doing as they appear to be far behind.
Prius is a product of G21 Project started in 1992. The objectives of G21 was to reduce emission and increase usage of recycled materials. Hybrid was chosen because it was the logical choice to reduce emission.
I believe Honda was working on a hybrid at the same time. I am not sure the time frame when they started though.
As for patents, Toyota has six principal patents on the HSD. They are US5907191, US5914575, US6005297, US6067801, US6131680, and US6161640. They cover concepts such as, electronic controlled CVT, Stealth mode, electric assist driving up hills while charging battery, charge-discharge mode(converting engine HP to high torque at low speed when torque is most desire), regenerative braking, ability to recharge battery while driving in reverse direction without requiring additional mechanical gearing, ability to capture excessive energy from the internal combustion engine during it's most efficient RPM power output, etc...
I do not know when Honda patented their design. Ford, Nissan and others are licensing HSD probably because of those HSD patents.
Dennis
As I understand it, Toyota is licensing its first generation hybrid technology to Ford, Nissan, others, not its second (current) generation technology. As inferred in an earlier post, the licensing of their dated technology is not being done deceptively. Ford et al know full well that what they are licensing is dated, but necessary for their initial forays into hybrid production models (such as the Escape which has seen delays in introduction for reasons I am not aware - maybe due to licensing negotiations for all I know!).
In any event, Ford et al want/need to get hybrid product on the road or they will be left in the dust by Toyota and Honda. Toyota, on the other hand, is more than interested in having more hybrid product in dealerships across the globe in that doing so will increase interest in hybrid product overall. The licensing of dated product accomplishes that, but still keeps them ahead of the competition. As I said in an earlier post, smart marketing by Toyota.
I guess at this point, I will surmise that Toyota hybrid technologies are superior to Honda's and that they have exclusive patents as you have outlined above which aid them in maintaining their superior position in the technology.
In summary, I certainly look forward to seeing their hybrid power train being introduced throughout the Toyota and Lexus models - Highlander and 330 this fall, with other models to follow in short order.
I guess patience is the order of the day. Thanks again, Dennis, for your worthwhile information.
You are welcome. I notice you currently have two Honda cars. You must be technology driven type. Interested in latest hybrid technology and stuffs.
Dennis
He checked your town hall member profile :-)
Jeannine Fallon
PR Director
Edmunds.com
You must have a crystal ball. Yes, we have two Hondas - 1992 Accord and 2001 Odyssey - and think they are both outstanding motor vehicles. The Accord has 150k miles on it and still looks and runs like a brand new car; we are begrudgingly thinking of replacing it in order to gain access to current safety technologies as well as improved gas mileage over the 30+ mpg we presently obtain.
Yes, I am a firm believer in reducing dependence upon oil. Read the Pulitzer Prize winning "The Prize" by Daniel Yergin (an incredibly well written and insightful history of the petroleum industry); you will understand why. Candidly, as I see it, current hybrid technologies are the precursors to hydrogen fuel cell hybrid technologies - the ultimate answer for making significant inroads in reducing the world's consumption of oil. In reading Yergin's book, you will come to understand why Japan has made such a major commitment toward this end (hint: something significant happened during the 1973 oil embargo).
Obviously you are an 'insider' in the automotive industry - how about giving me a clue as to how you know what vehicles I own - not that I mind, mind you. My guess is from state motor vehicle records??
Yes, I respect and appreciate new technologies, particularly in the automotive industry which is where I 'cut my teeth' in industry after obtaining BSEE and MBA degrees. I have inordinate respect for Japanese automobile engineering.
Lee
reliable
dependable
good value
higher MPG than competition
Mildly Sporty
I guess the Honda Accord comes closest. The Big Three have cars that don't get high enough MPG numbers for me and the Koreans have the same problem. It seems the Japanese have the most efficient cars, and Honda has made the Accord a tid bit sportier than the Camry. (and more efficient)
I just took a glance at your profile. I am in the computer industry. All my knowledge are from research done with my own spare time. When I was a child, my dream car was to run either on solar power or water. Technology didn't move as fast as I wanted to. Hybrids are in the right direction especially HSD. We will be seeing fuel cells soon. I hope I live to drive a fuel cell car with solar energy absorbing paint.
Dennis
-juice
You are looking at EPA estimates. I was looking at CR's actual mileage. We're just looking at different sources.
In fact you actually made an error in comparing it to the 5 speed Accord, because there is no MT Malibu. 93% of people buy automatics and we should compare apples to apples.
-juice
Accord Auto I-4: 24/36
Accord Auto V6: 23/30
I don't have the EPA numbers for the Malibu though
So my point stands.
If you think EPA figures are best, that's fine, you're entitled to your opinion.
EPA puts cars on a dyno and then only simulates what it thinks are typical conditions. Some times they are accurate, often they are way off base.
This is specifically true for the Toyota Prius, owners aren't getting nearly what the EPA says they will. 46mpg is about average, and the EPA is way, way off at 60/51.
EPA might need to revise their testing methods to better capture estimates for hybrids. In fact I think Toyota issued a statement warning customers not to expect the optimistic EPA results.
Given we're in a hybrid-oriented topic, you'd be wise to get more sources than just the EPA estimates for the upcoming Accord hybrid before taking the dive.
-juice
That is NOT true.
The only real-world data currently available is from 2004 Prius that aren't even broken-in yet, many are in temperatures significantly below the EPA minimum testing criteria, and they are all using winter-formula fuel.
Once break-in is complete, the minimum temperature becomes a reality, and the same fuel the EPA tests were performed with becomes available, efficiency averages will climb to about 50 MPG.
And I know that for a fact, since my 2001 Prius delivered 50 MPG all last summer. Doing the same with my 2004 will be considerably easier.
JOHN
States like MD use reformulated fuels year-round, FWIW.
We'll see how much this improves in the summer. A/C might offset some of those gains.
One positive is that you can see how passionate Prius owners are about their cars. ;-)
-juice
gatrhumpy- maybe you should educate yourself a bit before you go instructing long-time board contributors on how to post, espeically since Juice CITED his number.
03accordman- CR uses the exact same test loop everytime, and provides a good measure of overall MPG.
The Accord 2.4L 5A tested at 24 MPG overall.
The Accord 3.0L 5A tested at 23 MPG.
The Camry 2.4L 4A tested at 24 MPG.
CR lists the Camry V6 MPG at 20 overall, but that is outdated since the tested engine/transmission (non VVT/4sp) are no longer available. The 3.3L 5A Lexus ES330 tested at 22MPG overall.
The Malibu 2.2L 4A tested at 24MPG.
The Malibu 3.5L 4A tested at 26MPG.
PERIOD. Same testing loop, procedures, and equipment, and no artificial dynos involved.
~alpha
