Towing Truck?
I need to get some opinions on the best truck for me to pull a load of about 2500lbs daily. I currently own a Tacoma and need to go bigger. I want to go as inexpensive as possible, under these prerequisites:
Used truck
4 real doors
Diesel or gas?
Nothing fancy with interior
I will be driving around Texas daily and want something that will last for quite some time.
Used truck
4 real doors
Diesel or gas?
2500lbs could be towed by ANY truck, that is nothing. Chevy has a 1500HD four door that comes with the 6.0L gas V8, that would be a good choice. The chevy trucks have the nicest ride by far. The drivetrain should last a very long time. In a Ford, you have to go to an F250 or 350. If buying a Ford, I would find an example with the 7.3L turbo diesel, I have one with 240k miles on it still going strong. These are excellent trucks. I am not a big fan of Fords gas engines ie; the 460 and 351 V8's. The newer 4.6 and 5.4 V8's are much better but low on power. The V10 is a big gas hog, I wouldn't go there. Like I mentioned, no Dodge four doors until 2003. I do like the new Dodges the best with their Cummins diesels. That is by far the best engine ever offered in any light truck. I have owned several of each brand and say that based on experience.
Give us a little more info, let me know what you think of what I have thrown out so far.
kip
Make sure any truck you do buy has the towing package, esp. aux tranny cooler (if auto)
The other thing you will want to consider is brakes, at 2500# your trailer may or may not have its own brakes, if it does, great just keep them in good working order. If it doesn't I would stick with a newer full size truck that has 4 wheel discs.
