Toyota Tacoma: V6 vs 4Cyl
What's up Taco drivers? Own the road.
I need some hard core facts and advice here
concerning power plant choices for my
soon-to-be-purchased Tacoma. My dilema is whether
to choose the V6 or 4Cyl. Specifically, I am
interested in mpg experiences from owners of both
engine types. Also, how happy are you with the
performance/response among these two engines? Tell
my why I will be satisfied with the smaller engine
you 2.7L drivers. I currently drive a 2.0L Mazda
PU, so massive power is not something I am
accustomed to. Is anyone with a V6 experiencing
20mpg or more? I have had numerous dealers tell me
that the mpg difference between the two engines is
negligable. Needless to say, I trust your opinion
much more than the dealers. Thank yas.
The difference in power between the 4 cyl. & 6 cyl. is pretty large. The 6 cyl. does not pose any real challenges other than smoking Ford & Chevy's at traffic lights.
I did get better mpg when I switched over to Amsoil oil, oil filter and air filter. I am changing the oil & filter every six months and
have gotten superior results and a much happier engine as a result.
Go with the power, v6, and you will be a happy camper. Get the 4 cyl., and the first time you need the power and you do not have it, you will be kicking yourself!
I use only genuine Toyota parts, except Amsoil air filters & oil filters, and have the Toyota Dealership, Toyota Direct, Columbus, Ohio, do all maintenance except oil & filter changes.
Find a good dealership with a good service department and become their friends. When your Toyota rolls 200,000 miles without major repairs, you will understand!
Toyota 3.4 190HP 220ft/lbs of torque, Chevy 4.3 190HP 240ft/lbs of torque, Ford 4.0 160HP 225ft/lbs of torque (Soon to arrive 4.0 SOHC 205HP 245ft/lbs of torque for Ranger) Ford 3.0 152HP 192ft/lbs of torque, Toyota 2.7 150HP 177ft/lbs of torque.
Hope this helps answer your question. Real truck owners look for Torque not HP. If you want to race buy a Corvette.
If you are going to load the Tacoma and do work with the truck, the 4 or 6 cylinder engine will make very little difference in operating costs. The basic physics are that it takes a certain amount of energy to perform a specific amount of work. The energy comes from gasoline and the work is moving the weight of the truck. Every engine has an efficient operational range.
In short, if you run the 4 cylinder in the lower part of the efficiency range you'll get better mileage than the 6 cylinder. In that case the 6 cylinder will be too much horsepower for the required work. HOWEVER if you load the 4 cylinder and run it beyond the efficiency range you'll get worse mileage than the 6 cylinder.
So if you're a flatlander and the steepest hills that you have to worry about are the bridges over the freeway you'll be happy with the 4 cylinder. If you're a mountain man, you won't be happy with anything less than 6 cylinders.
Rich
However, if you are just doing light hauling, and don't get all the options. The 4's are a great choice.
Incidentally, it is for sale hate to part with a great truck, but the family is growing.
5-speed went 16.5 in the 1/4 mile...
I have the 2.7L 4cyl 4x4 right now and my lease is almost up. I love my toyota but want more power...so I am going to get the top of the line V6 and want to throw a supercharger on it.
Has anyone done this?
If so, what do you think, is it worth the $$?
Cool sign on. Anyway, I have a 96 Tacoma V6, full power, SR5 and love the power and towing capacity. The mileage I get is about 18mpg but if your worried about $$, the truck runs great on 87 unleaded. I never need to worry about lack of response, whether blasting the AC, towing up the grapevine or the I-15 to Vegas fully loaded, or any combination thereof. Go with the six. It's better to have more power and torque and not need it than to not have it when you need it. I live in CA in the foothills. With the mix of flat and hills that make up my commute, I'm glad I have the V6.
Killtaker,
When I bought my truck in Jan. of 96, the TRD supercharger was not available. Now it is so cheap, and installed on a new truck you can get the factory warranty. If you feel you need 260hp and that much more torque(stock is@ 220lbs) go for it. I would have. Keep in mind, that's a lot of power and if you don't have self control, you're going to end up a CHP statistic. 4X4's have a higher center of gravity, and even though my Tacoma handles great with 31-11.5's and Rancho 5000's, I think with that much power it's too tempting to pedal to the metal more often than I already do. Also, Toyota has a factory fuel injection cutoff at 105 mph for the Tacoma. It's there for the protection of the general population and those drivers like myself, who lack good judgement every so often and take a 4x4 in excess of 100mph(not too brite) Sometimes my Tacoma thinks it's a Supra. Like I said, you don't need that much power, but if you do supercharge it, you'll turn an already powerful mini-truck into a tasmanian devil.
Last footnote, your towing capacity won't increase much because, the weight of the truck( it's too light and you'll lose stability towing a 5000lbs plus) and the suspension(my only downer) already a bit squirrely on curves with bumps or patchy spots would not be able to handle the added power on cornering and winding roads at higher speeds.
I still have some time to check it out. I drove a supercharged V6 4runner at the dealership because it was all they had with a supercharger, and I'm sure it would be faster in the Taco. They didnt have any v6 tacos for me to test out(I havent driven a v6 taco 4x4 yet)
I am scared of the gas milage increase that a supercharger would bring on because I know that I would use it often. I am one of those people who needs a truck for stuff like the band and camping & off roading but likes to race people every once in a while.
I'll post back when I eventually get my new taco
(all this talk of tacos is making me hungry (joke joke))
it is unwieldy to manage, and difficult to use for "newbies." There is entirely TOO much topic duplication, so I will be doing some SERIOUS topic consolidation in the next few weeks, getting us down to not more than 2-3 topics per vehicle type, and ultimately down to 200 topics or less.
THIS weeks consolidation candidates are: Tundra's, Tacoma's and Rangers.
In that vein,please consolidate this Tacoma topic to Are You Happy with Tacoma - II and continue these discussions there.
Front Porch Philosopher
