Chrysler 300: Care & Maintenance
Talk about 300 care and maintenance here.
Granted, bumpers are no guarantee against damage, but they sure do help!
Any thoughts on this? It's a really sharp car but this worries me a bit.
I must say though that after spraying with the garden hose, letting it soak, spray again, and give it some soap. the front nose came spotless. It appears that all the bugs finally just slid right off.
how will it do in snow with front wheels pulling 32% and rears pushing 68%?
I thought to be the best in inclement weather it should be the opposite?
Can someone advise me?
trying to decide if 300c awd for my choice in snow.
I found my set up in the 2006 300C a little different:
The coil on the top of the plugs looked like this
[IMG]http://i39.photobucket.com/albums/e155/ies99/spark plugs/DSCF0006.jpg[/IM- - G]
Disconnect the wire by squeezing the plug at the top left to release it.
Take the two small screws holding the coil/boot assembly in place.
Here I have removed one:
[IMG]http://i39.photobucket.com/albums/e155/ies99/spark plugs/DSCF0007.jpg[/IM- - G]
Gently pull the assembly out from the plug caverns. The assembly looks like this:
[IMG]http://i39.photobucket.com/albums/e155/ies99/spark plugs/DSCF0008.jpg[/IM- - G]
The cavern entrances look like this:
[IMG]http://i39.photobucket.com/albums/e155/ies99/spark plugs/DSCF0010.jpg[/IM- - G]
Take the plugs out using a narrow plug socket.
Insert the new plugs after applying anti-sieze and dielectric grease.
Tighten the plugs to 13 foot pounds
Insert the boot/coil assembly
Replace and tighten the two screws holding the coil on.
Reattach the wire.
Go on to the other 14 plugs. :shades:
They want 400 bucks!!!
Jimbo3134
I really like the car thus the reason for me tolerating the aggravation I am experiencing. Are other 300 owners experiencing a range of problems with their 300s, or, do I have a lemon?
every few days. I stop get out , eyeball the tires and continue on. The light
then goes off. Any of you have the some problem ??
Charlie
all different.
