Ford 2001 Heavy Duty F-250
MPGs: Folks here with a similar configuration to yours report somewhere in the 12 to 16mpg range..
A few get less than 12 a few get more than 16, but thats the ballpark.. I've not heard of any significant difference in mpgs between f250 and f350.
The above is not first hand experience. I have
00' F250 SC 5.4L 4x2 5sp 4.10LS
As far as fuel economy, I think the V10 is a pig either way. I averaged 10 MPG combined during the first 1200 miles. Changed the oil and am up to almost 11 MPG combined and I absolutely freaked during a 300 mile highway trip at a painfully slow 75 MPH cruise and got 14 MPG. This is with a Crew Cab V10, 4.30 LSD, auto. 2WD.
IMHO, get the 4.30's and never have to say, I wish I had more low end."
Since your not towing, and you have '4 wheel low range' to for the snow plowing duties, I think the 3.73 would be the best option for you..
You'll get better mileage on your highway stints, and the V10 has more than enough power to handle the 3.73.. If you tend to drive at 70+ mph, then you'll be turning around 3000rpms or more with the 4.30's.. That wont hurt anything except mpg's.
This is why I feel it's a personal thing: Drive'em both, if you can, I felt the way the 4.30's tached quicker and jumped off the line was worth a possible 1 MPG but that's me. It seems to me that when looking at V10 monsters that fuel economy shouldn't be a priority, that performance should be and that 1 MPG aint gonna break the bank.
I have 99,f250,v10,super cab,auto,4x4,3.73
Brother's is identical except 00 and 4.30 gears.
I tow 27' St (loaded 7700lbs) @ 75mph and get 9.5 to 10 mpg. I tow 34' St (loaded 10,500lbs) @ 73 mph and get 7.0 to 7.5 mpg.
Brother tows same 34' St (loaded 10,500) @ 73 mph and gets 6.0 mpg if he's lucky. The engine is screaming at around 3700 ram, needless to say he only did that on one trip. Now he tows at 65 mph and gets about 6.5 to 7.0 mpg.
I had the wise idea that he needed the 4.30 because he was going to be towing a lot more weight and more often. He will go to his grave telling me about how dumb that was. Sure he can smoke the tires, but I can to (with a little bit of power braking).
Normal street driving in Atlanta(that reads 80mph)combined mpg on mine is 13 mpg. While he lives in Mobile, he still drives like me, and gets 10mpg on a good tank.
Bottom line for us, the V10 has all the guts you need with the 3.73, and far better mileage. I don't have any doubt that Mod tells it like it is, but I find it odd that he got 14mpg and my brother gets 11.5 to 12 empty at that speed.
Does that guy you talked to have too many 4.30's on the lot. Those are for pullin 10,000 plus all the time. By the way I put in a I&N filter and a two chamber Flowmaster and my brothers truck can't pull away more than a truck length in about a 1/4 mile but by the time we are reaching 70 mph I start pulling up and away.
Sorry so long.
Thanks for the correction. I did make a miscalculation.. At 3000 rpm's with the 4.30 assuming stock tires you'd be travelling around 85mph..
So the mechanic who told jay he'd be 'taching out' probably assumed he was towing. If your towing with OD off your turning around 3500 rpm at 75 with the 4.30s, vs 3000 rpm at 75 with the 3.73.
Given that 'fun factor' is an important issue for Jay, I think he'll be leaning towards the 4.30..
Plus, if he thinks the RPM are too high, he can increase the fun and put larger tires on..
Fordtuf, I'll admit I was surprised at the 14MPG, but realize it's a 2WD compared to a 4WD(which easily could account for 1.5 MPG) and I made a CONSCIOUS effort to keep it at 75 as opposed to the normal 80+ I usually drive. One other important tid bit, your brothers truck has 35 more horsepower AND 15 pounds more torque vs, your '99. Power doesn't come free!!!
I didn't tell you my brother is a Ford salesman.
Anyway I was looking at my exact truck in a 01.
I thought it didn't have as much power (seat of the pants feel) as mine did. So what would you do if your brother was the salesman and he said "stop and get your truck and we'll find out".
I was right, mine jumps off the line first, it winds up faster from 0 to 30ish then they were about even. I wish I new what the numbers are, now, on my truck.
As for 3:73s vs 4:30s a lot of the choice depends on where you are, if you are towing anything in the Rocky Mountain states, you should definitely lean towards the 4:30s. Other areas with relatively flat terrain and rolling hills and an occasional steep grade 3:73s wil do fine. Climbing one of our 10,000 foot mountain passes, you'l be glad for the 4:30s. Good luck on your selection.
there for the break-in period??? Anyone change the programming chip to increase engine's
performance and fuel economy?? Can you give me tips??
I've got a V-10, but can direct you to place for best info:
http://www.ford-diesel.com
I believe they also have a FAQ section that covers PSD break-in. Good luck with your new truck!
I am very close to pulling the trigger on ordering an F-250 SWB 4x4 Super Crew Cab with the V-10 motor. Comments anyone??? My buddy (who happens to work at a Chevy dealer says I'm crazy -he owns a 2500 Dodge diesel). Anyway he says don't buy the V-10!!!
Just sold my 1997 GMC Suburban and I like the F-250 Super with V-10. I was comparing and considering the Chevy 2500 HD 4x4 LT.
I will not use for allot of towing or heavy use. I just want a BIG TRUCK!!!!!
Can anyone give me a push towards a decision???!!!
My 2 cents if your not towing a LOT (over 10,000 lbs)of weight or doing it ALL the time don't mees with a diesel. They add 4700 to your sticker, are quite a bit more to maintain, they smell bad, and are not very good for daily driving unless you commute over 30 minutes. Don't bother with the 5.4L for about 575 you can have the 6.8L v10. The gas mileage is almost identical between the gassers.
BTW I am biased, I own 99 F250, 4x4, supercab, V10, 3.73 gears.
What part of the country do you live in? My brother sells Ford's in Mobile, AL.
No, I will not do allot of heavy towing. I have a utility trailer and will pull a boat occasionally.
I live in Dothan, AL. Used to live in Mobile. I have a connection at a Ford dealer, not in Dothan, who is selling me the above vehicle at $200 over invoice. Used Edmunds.Com to price out my vehicle!!!
I've decided against the Chevrolet HD2500. Ford offers more options and packages. Having been use to a Suburban I wanted a BIG Truck. Realistically, I don't need a BIG Truck... I just like the looks, like the power, and I like the resale. So, I'm going to get what I want.
Looking forward to my new truck's arrival. Once recived I'll write back and advise my thoughts. Until then, I'll keep watching the news and reviews on Edmunds.com.
So, first deisel. Will be interesting what my opinion is after a couple of years. 12,500 miles though and it's the best rig I've owned, albeit not the cheapest.
and need some advice. Have been hearing some talk
about vac. seals going out on the shift on the fly
auto hubs (new trucks). Anyone experiencing this?
Considering on sticking with manuals, since they
lock in right away. Cost not the issue, just the
reliability factor. Currently own 10 yr. old Chevy
with their version of shift on the fly, and have changed
elec. actuator three times now. When it goes you cannot
engage or you are locked in. Of course last time this
happened it was -7 degrees with 5" of snow on the ground,
and my garage was full. Rather cold in the driveway at
nine pm. changing this thing.
manual after experience the Chevy, felt like you
should lock in before entering into anything that
looks suspect traction wise. Then engage transfer
case in and out as needed.
'01, F350,XLT, CC, 4x4, V10, 5 spd, LS, LWB, Camper Package, roof clearance, CD
I ordered my truck fully loaded, Lariat package with ALL available options. Paid $200 over invoice. Patience is hard to come by, but I'm waiting on the dealer's call to advise my BIG truck has arrived.
Still patiently waiting. I ordered on 8-02-01 and with the VIN my dealer says the delivery date is listed at 9-17-01.
Just interested in whether the VIN can tell me anything about my ordered truck while I await delvery!!
2000 or 2001 - F250SD 4X4, SC,LWB, V-8/auto,
373 rear end. What kind of gas mileage are you
getting? Same question - with V-10/auto/373.
Order time hopefully coming soon, and don't really
need a diesel for my needs. Thanks!
I have an 00 F250 SC 4x2 5.4L 5sp 4.10LS
Overall average 16.0 mpgs.
I use it mostly driving to from work which is mixed city/highway driving..
With the 4x4 and auto tranny, your going to be in the 14 or 15 mpg range average, little higher with all highway, little lower with all city.
I do recommend the 4.10 with the 5.4L, unless you regularly cruise at 75+mph.
one the parts counter guys at the local dealership
about this. He said that they had quite a few
problems with hubs in 99's and early 2000's, but
he has not seen any with 2001's on. Problem was
with a teflon seal - it had a foil/plastic wrap
for protection during man/shipment. Seems that
it was not being removed during hub assembly. Often it would get hung up, not allowing for a
good seal (vac.) as a result hubs were not engaging, or sometimes not disengaging. He showed
me a whole box of replacement seals on the shelf
currently collecting dust. Sounds like the prob.
might be solved.
I think you'll see the most difference in ride depending upon how much air you put in your tires. A while back I made several trips carrying almost 2 tons of concrete, so I aired the tires up to 80 psi in the rear and 65 psi in the front to carry the load - you could feel the weight, but it handled and rode fine. The next day I was in a hurry and drove off empty with the extra air still in the tires and I almost shook the fillings outta my teeth. After about 10 miles of back roads I couldn't take it anymore and reduced the pressures to ~45 psi and suddenly my Superduty was back to acting totally refined and civilized. I'm quite impressed with the package, it can legally carry >3000 lbs payload, tow 13000 lbs and still be remarkably comfortable while doing it. ( To be truthful though a friend has a 4x4 F150 SuperCrew that really rides more like a passenger car than my '350 but he doesn't have half the capability of my SuperDuty.)
My dealer has provided me with the VIN # for my ordered F-250 Super Crew V10.
Is there any information I can gleam from the provided VIN #??? If so, where can I retrieve information???
Still waiting on arrival of ordered 2002 model.
Jim
I think I'm getting old because in the past I would have bought the $1500 Fab Tech pre-runner suspension,(extended radius arms, shock hoops etc.) wheels and some 37's and pretended it was a Baja runner. The truck is just too big to hammer off road so I've left it stock with the front end a little lower than the back. The 285's do look better though(black side out)
The 4WD's in stock form do sit [non-permissible content removed] up also but I don't think I've seen one with the snow plow package. Maybe the stiffer front springs level it out??? I also know the first Super duties were so high in back the dealers would put lowering blocks in the back for free. I think this was to appease the 5th wheel crowd.
Deciphering the VIN (Vehicle Identification Number):
Digit Definition Code Definition
1 MANUFACTURING COUNTRY 1 UNITED STATES
2 COMPANY/MAKE 3 AM GENERAL CORPORATION
3 VEHICLE TYPE 7 COMMERCIAL VEHICLES
4 ENGINE D 5.7 LITER (L05) GASOLINE-GM-8CYL
L 5.7 LITER (L05) LEADED GASOLINE-GM-8CYL
W 350 CUBIC IN GAS-LTI-GM-8CYL
X 6.2 LITER DIESEL - GM - 8CYL
Y 6.5 LITER DIESEL - GM - 8CYL, NATURALLY ASPIRATED
Z 6.5 LITER DIESEL - GM - 8CYL, TURBO CHARGED
5 TRANS/DRIVE A 4 SPEED, AUTO/LHD - GM - 4L80E
E 3 SPEED, AUTO/LHD - GM - 3L80
6&7 TRUCK LINE, SERIES 82 VLC2 - TRUCK-2 DOOR
83 HMC4 - TRUCK-4 DOOR
84 HMCS - TRUCK-STATION WAGON
85 VLCO - TRUCK-OPEN BODY
86 HMCF - TRUCK-2 DOOR FLEET/INDUSTRIAL
87 HMR2 - TRUCK-2 DOOR RECRUIT
88 HMRO - TRUCK-OPEN BODY RECRUIT
89 XLC2 - TRUCK-2 DOOR CAB
90 HMCO - TRUCK-OPEN BODY WITH FULL HARD DOORS
8 G.V.W.R. 3 10,001-14,000 POUNDS
9 CHECK DIGIT 0 THRU 9 OR X -
10 MODEL YEAR N 1992
P 1993
R 1994
S 1995
T 1996
V 1997
W 1998
11 PLANT CODE E MISHAWAKA
U LIVONIA
12-17 SERIAL NUMBER - -
I'll let you know what I think of my 2002 F-250 Super Duty 4x4 with V-10 once it is delivered and I have a chance to put a few miles on her.
This will be my first owned Ford. My last vehicle was a GMC Suburban 1500.
