Bedliners
Personally, I vote for Line-X. It has a much more professional look than Rhino and is harder. The Rhino has a cottage cheese look and I hear that it fades much more quickly. The black turns a gray color in no time. I also believe that getting it sprayed over the rails is the only way to go.
I went with something that actually protects against dents and shovel like hits....A Duraliner Drop in.
For Drop ins..a GM brand (Duraliner) or an Actual Duraliner are the best. They fit perfect and do not bow up as cheap ones can. The new Duraliners have a grit like finish that is smooth....but also holds stuff in Place. You will pay $300 for one...But My dad always said....."you get what you pay for".
Spray ins are an awesome Idea....but too Disco for actual abuse....which is what we get a loner for right? If you don't use the bed enough to give it hard work....than a rubber bed mat may be the answer?
Good luck
- Tim
Yeah there is the factthat the wiggling around will cause friction and rust the bed. I took mine out a few times and it had minimal wear. One spot was all the way to the metal after 11 years. So I see that as no big deal. No surface rust ever was noticeable. Who takes there liner out to leave it out anyway? Once it's in...who cares if it scuffs?
A bed can very easily be re-painted. But if the liner didn't protect from dents and scrapes all the way down to the metal...(as a spray in does not)...what good will a paint jobe be? Course a sprayin can't be removed....at least not easy.
You will pay $300 for the best liner you can get..a Duraliner...or pay that much easy or as much as $550 for a spray in that offers less protection...but looks very nice...
Up to you
Good Luck
- Tim
The only problem with the bedrug is that stuff can get caught in the carpet. When I cut down a few trees and loaded up my truck with wood it was a pain to get all of the twigs and leaves out.
Like most things, which bedliner you get depends on what you want to do with it. I think the bedrug will work fine, but if you frequently carry messy stuff, like dirt or manure, then I wouldn't get one.
Anyway, would go with the GM Duraliner because in this case you really do get what you pay for. Dealers are quoting $247.00 for GM and $185 for Penda, not much difference.
On the scratching part of the deal. There is supposed to be a manufacturer that makes a liner for the bedliner that protects the paint from any scratches. I was told about this product by a friend, but he didn't remember who makes it. Anyone else heard of this?
Skip it.
The dealer probably makes more on the cheaper Pendaliner. Like I said...they fit like crap though. It narrowed my old stepside so much...you couldn't haul a 4x8 sheet.
Go with a Duraliner.
- Tim
To those who have the GM Duraliner bedliner, does it use the special "no-drill" fasteners to hold it in place? Specifically the under-rail model.
The tailgate piece uses 2 of the GM screws that hold the latch on for the center...2 screws on each side to hold the outside had to be drilled though. I don't see how it would be sturdy if you didn't screw the outside sections of the tailgate?
- Tim
The bolts in the center are a good coated bolt and they seem OK so farr. The outside screws they used have formed a coat of rust after 7 months already. perhaps the next one I will try the tape?
Good idea man
- Tim
~*Teaboy*~
I have yet to hear any stories of people that use spray ins..
lemme know
I love the Idea...but don't think they can handle work.
- Tim
I havent used the liner abusively yet. But my friend who has one,works in construction and he throws all his tools back there. Rhino liner holds up good. His has turned gray but stands tough.
No problems with its performance just might not look as pretty as a drop-in after a while.
Tea
Unless you get a disco Non-black type...or glow in the dark one..
I still say spray ins can't take shovels and prevent dents..
Long live the drop in!
- Tim
So that issue does not apply here.
Every Rhino I see looks like crap dut to fading very soon after. The only line X I have seen on a regular basis is my father in laws....but it stays under a cap....so hard to tell if it fades?
I know it couldn't take having a pallet slid in...scraped all the way down to the metal.
Like I said..Love the Idea....just not perfected yet for real protection.
- Tim
I know Line-X is different....I prefer it's finish to a Rhino. father in law had some slate on a pallet slid into his...a nail in the bottom scraped the line-x right off.
I like mine...you like yours...that's all that matters.
Good Luck
- Tim
If I had my choice to do it over again AND the Duraliner was not one with grit in it...... The one drawback of the Line X is that things don't slide easily.
It would take 3 or 4 sleepless nights and finally I would flip a coin. It's that close! The Duraliner is about $200 cheaper.... Maybe, there's my decision. I don't know. I still really like the Line X.
Rich
Where can I get a DURALINER for my 2000 Silverado? The dealer I bought it at said they get their bedliners from a local parts store and they are not duraliners.
- Tim
kyle
Someday if they improve....I will get one..
They can't take shovels...or heavy loads being slid on them...(line x in Father in laws truck got ripped to hell doing this)...
I would take a hammer and hit my duraliner as hard as i could...and feel safe.....any spray in owners feel the same?
Great Idea...just a little too ahead of it's time I guess?....needs more Improvement.
- Tim
I'm not sure about making repairs on other spray in liners, but Rhinoliner claims they can repair theirs if it gets damaged.
I asked about the fifth wheel hitch. The Line-X dealer told me to have the hitch holes drilled and then have the liner sprayed. Finally go back and have the hitch installed. The theory was that the spray would protect the bare metal where the holes were drilled.
I don't have an opinion on this one and I'm just reporting what the dealer said.
Rich
Do 5th wheel hitches have ways to pull out most of the hitch when not being used?...like a quick release system or something?
I would want the entire thing out when not using it...bolts and all.
I had a roll bar installed over my duraliner before...I was going to cut out the footprint of the base...but decided to bolt it down with the liner between the floor and the base of the bars. It held very tight...but it was not a fifth wheel hitch either...
I would imagine I would want a 5th wheel hitch to have nothing between the base and the bed...weather it be spray in or drop in....but again..I do not know anything about 5th wheels...
- Tim
Bed Liners: I've read ALL the comments posted here about them, and I've just about decided on a drop in, mainly because of response #20 of 34 above: He says "...The thing about the spray-in liners that I couldn't handle was that they sand the bed down to bare metal and acid etch so that (the product) adheres properly.."
You're right, I'm freaking out about a little scratch I put on one rail over the weekend, I doubt that I could take someone pouring acid on my bed so their stuff "sticks better".
Only comment is: Most of the writers talk about GM, some Ford, but NO DODGE owners with bedliner stories. Anyone out there has any experience with a Dodge-brand liner? They're about $250 for the over the rail, same price for under rail. Is an under rail better if I add rail protection after? or should I get an over the rail and be done with it. They also have some good looking mats, but for 60 bucks more, I'd get the whole liner. I had an over the rail in my Ford and it looked good and fit good.
I'd appreciate any help/comments.
Santiago
In terms of over vs. under I would go under if you are ever planning to put anything else on - rail protectors, tonneau, cap etc. Otherwise over the rail is fine.
it didn't rust though?.....so...protection wise..best choice...but it will wear the hell out of it.
Mine just sat loose....perhaps if you added some 3M red tape...it would stay put and not rub?
Good luck
- Tim
Also got the wind deflectors and they fit/look great. The shop installed all for nothing and in about 15 min. Great guys here in Melbourne (Truck City - Eddie Dunn's shop).
durability (no bed denting when carrying rocks,
etc.) of the drop-in liners. I'm thinking of a
spray-in over-the-rail with a drop-in
under-the-rail to protect the bed from rocks,
scuffing from the drop-in, etc. About half the time a topper would be on the truck (2001 GMC 2500HD. Other than expense, does anyone have any comments?
It also has a grit like finish to hold things in..most importantly....it fits right!
Spray ins are for looks...I would not get one for a truck that actually gets used.
- Tim
Want looks and Disco? - Spray in
want one to use? - Drop In
You have to decide yourself.
Good Luck
- Tim
They also spray a smooth finish in large dump trucks and I doubt they continue to do that if it didn't hold up. They have a rough surface type and a smooth surface, depending on what you want the material you're moving or hauling to do, ie. slide or stay put.
Examples of items with texture spray; pickup beds, bumpers, running boards, grill guards, picnic tables.
Examples of items with smooth spray; dump trucks, snow plow blades, diamond plate steel or aluminum.
This place can spray in any thickness you want. Of course you'll pay more to get more. They also have info posted from the NADA (Not sure of letters) used vehicle pricing guide. Trucks with spray in liners have increased value at trade in.
I'm not an expert on liners by any stretch of the imagination, but simply am forwarding info on what a local vendor has.
This spray in is applied hot and it's actually plastic. The sales person said poly-something, I think poly urethane? Anyway, I looked at some of them in the parking lot and someone I work with has this company's spray in liner. He uses his truck on a farm and hauls a lot, yet his spray in liner looks like he just had it done.
For what its worth... Good luck on your decision. I'm going spray in.
fat_fenders
One poor soul's mishap with the stuff
this topic is being "frozen." It will be archived or deleted in the next 10 days or so. Thanks!
Front Porch Philosopher
