Hybrids exempt from smog tests?
Should hybrids be exempt from smog tests (and the fee associated with them)?
Just heard on the 5 o'clock news that the Honda EV, Honda Civic hybrid and the TOYOTA PRIUS will be EXEMPT from bi-annual smog (tailpipe emission) checks in California. Go Prius!
Congrats to all Prius owners in California.
mfullmer - Grew up in El Sobrante, still in Contra Costa County.
Rich
First post to this board - I ordered my Prius in April, it's due in August (maybe September), and the dealer says that when I get mine, it may be an '05. Should I expect any particular differences from the '04?
On the other hand, the new governator is trying to increase the fees you pay per year so you don't have to get a smog test for the first six years(?) (TBD obviously). Since the Prius and the TDI are both exempt from either smog tests, you should probably let your representatives know that you do not favor higher fees!
Last year I smogged my '84 Corvette and they performed the "dyno" test on rollers.
Didn't we have an earlier post alluding to somewhere in the midwest, Kansas, Nebraska or around there where the state was going to impose an "extra fee" on vehicle registrations for hybrids that don't pay as much at-the-pump tax due to high mpg? I wouldn't put it past the state gov't here in California to find some other way to get money. If they can't find it in the right pocket, they'll get it from the left pocket. I hope that the bill that's up before the feds gets passed allowing hybrids to use the "diamond" lanes (high occupancy vehicle) during rush hour regardless of number of passengers. Currently only natural gas powered and selected others are exemptto the number of passengers req'd.
Rich
If a Prius replaces a older vehicle that has high emissions is the net effect a decrease or increase in emissions when you consider the emissions that went into the creation of the Prius? I do not have the answer.
You highlight one reason why I personally want to go over the 8.5 year average age of the passenger car vehicle fleet and put more than the normal 100-150k miles on! (my own goals 500-1M miles)
If indeed making new cars is the resource "waster" and all those societal "bad things" that it is made out to be, industry is more than capable to make the platform modular and also longer lasting! So all you have to do is swap out the offending part; such as engine etc etc.
In answer to older cars polluting more, my 14 year old TLC with 250k was in "total compliance" with the smog test and the laws that governed it. At the 14th year it was actually emitting very very close to when it was brand new!
As far as the smog tests go, the Prius really doesn't idle and if tested at 1200 rpm on a dyno track, the gas engine may/may not be running.
Rich
http://www.tceq.state.tx.us/comm_exec/communication/media/08-04nt- rdgrants.html
All the Northern California diamond lanes I've seen are just another lane with a dotted line between them and the regular lanes and diamonds to mark them. One can freely transition in and out of them (except the special case going from 80 West to the Golden gate bridge where they have their own overpass). Even up here there are some other variations like some of the lanes require 3 in the car and some only 2.
The diamond lanes in LA area are generally marked with a double solid line plus a dotted line. When the carpool lane is left of the regular lanes (as it usually is) the dotted line is on the left and the double solid lines are directly to the right of the dotted line. My understanding is that this marking means you can only join the carpool lane where there are gaps in the double solid line but you can leave whenever you need to. Some of the carpool lanes in LA, especially those near downtown, make me very nervous to drive in because you can be zipping along in a tight channel at high speed with a concrete barrior on your left and a solid line of stop and go cars on your right. If anything should go wrong there is no room for the slightest swerve much less changing lanes to get out of the way of trouble.
Friends in SanDiego tell me that there in and out of the lanes is even more tightly controlled. You can only enter and exit at certain points.
I have until the end of August ...
If anyone has done a smog test on a Hybrid, I'd love to hear from you.
DJ
What??? Here in CA they don't make you get a smog test for 5 years on a new car...
For the test I...
1) Had a change oil, then
1) Drove at high speed for 30 minutes to make sure the cat converter was at max temp so the ICE would not kick in to warm it up while on the idling test.
(Also it was to top up the batteries to max, again to minimize ICE kicking in).
2) Temporarily overinflated the tires beyond tirewall max so the car will roll most efficiently.
3) Turned off all accesories (including the energy monitor) then parked on the nearest spot to the test bay so minimal juice will be used.
When the technician saw it was a hybrid, he had this misconception the ICE would never run on the idle test. Called someone from the gov who also made another booboo and told him to test it like a diesel (spot for black smoke while idling).
Of course, tech knew that would never happen, so he just gave me a pass on a diesel test doc without so much as stepping inside the car.
Paid $35 bucks for a piece of paper that meant nothing.
Heres an article I found interesting but which I never tried. So take it with a grain of salt...
http://pesn.com/2005/03/17/6900069_Acetone/
passed the dyno test, with flying colors. the tester wasn't too happy it passed, becasue they also do repairs.
After taking my 4wd HH Lmtd to a smog test place, the poor tech was so confused when he just started it. I was almost LOL! He started it ... had a big puzzled-look on his face. Turned off the key and restarted it. I went to the window, winked and said it is a hybrid. He was red as a beet!
Back to the 'smog test'. The tech (and then the owner) informed me that they CAN'T test a hybrid, and especially a 4wd one. There is NO WAY to control when the gas-engine comes on. So I left with my wallet intact and the toll-free phone number for the California Department of Automotive Repairs.
Got home ... called. They confirmed that hybrids can't be tested at this time. They referred me to the "Smog Referee" when I asked what I was supposed to tell the DMV. (Didn't even know there was such thing as a "Smog Referee"!). Called him ... he confirmed that ALL Hybrids are exempt in California .. tell the DMV clerk to call their home office in Sacramento - they made the rule.
SO ... I went back to the DMV and the clerk insisted I had to have a smog certificate because the vehicle was purchased out of state (DUMB rule!). I asked for his supervisor, who didn't even know there was a HYBRID Highlander! I asked for HIS supervisor, who came over, changed the fuel description on their screen to "Q" instead of "G" and I was on my way. :shades:
What an ordeal! But, the outcome was okay.
In CA ALL Hybrids are exempt from smog testing!
Hope everyone else is helped by this saga.
Happy Hybriding!
DJ in Santa Clara
