Addblue is that chemical that is used to "detoxify" the exhaust. The downside to owning a Bluetec is that Addblue must be refilled periodically. I prefer the CDI.
U.l.s.d. is slightly rasing the price of diesel where I live (south Fl/ cutler ridge)being the most convenient station is selling it for $2.55 in the mornings and $2.59 in the evenings. I personally don't like that place.
-Cj
last year in Germany. They said: NO Bio Diesel. When I asked why not, they answered that Bio Diesel would interact with the plastic like the fuel tank. I was not quite happy with the answer, so I wrote to MBUSA and their answer was: only 5% Bio Diesel was approved. There was no explanation on why not. Needless to say, since I am still in warranty, I stay away from Bio Diesel.
Best Regards,
Shipo
Check out the article linked in KarenS, "Article Comments: 2007 Mercedes-Benz E320 Bluetech" #1, 4 Dec 2006 2:50 pm and post your reactions there.
Best Regards,
Shipo
i have not encountered any local stations changing from "car nozzles" to "truck nozzles" and would be quite annoyed if they did that locally. possibly there is a Shell "zone office" which would have info about this for you. or if you could contact the shell station manager, s/he might know why the nozzle change.
- Most cars (diesel or otherwise) have a fuel tank located under the back seat these days. Said location is somewhat removed from the fuel filler port and as such requires a filler "neck".
- Most diesel trucks have a very large screw top opening directly on top of the tank(s).
- With the lower flow rate of the smaller diesel nozzle, the "Auto-Shutoff" has enough time to sense fuel back-up in the filler neck and shut off before fuel comes spurting out of the filler port.
- With the direct fill method for trucks, the filler nozzle is directly in the tank and as such the auto-shutoff will sense a rising fuel level well in advance of overflowing said tank.
- Filling a vehicle with a neck-restrictor/remote tank setup (that has had said restrictor removed) with a truck nozzle will push the flow rate far too high for the auto-shutoff feature to engage before a considerable amount of fuel has backed up and pushed out the filler port and onto you, your car and the ground. Ewww.
FWIW, I have seen filler nozzle reduction devices at truck stops made specifically so that in a pinch, one can fill their car from a truck pump. That said, all of the devices that I've seen carry plenty of warnings about filling by hand (i.e. not engaging the auto-shutoff feature) and only at the lowest possible flow rates.
Best Regards,
Shipo
Best Regards,
Shipo
Same reasoning applies to the GC, although I'd estimate that the drag coefficient isn't as high as the Wrangler.
There are other factors involved as well, but the drag is a major factor.
Read some older posts and you will find people who had severe damage that is not warrantied by MB.
You can always contact MBUSA.
Hello
Sorry, this was a misprint. I meant DPF = Diesel Particulate Filter. This filter prevents Diesel soot from getting out and burn them in regular cycles (every 1000 miles for instance). This technique was pioneered by Peugeot in Europe and is very widespread there with new vehicules now.
Old DPF required regular maintenance, which periods extended gradually with the help of new technology. I heard that current DPF are "maintenance free"
I don't think DPF could be installed as aftermarket, although this would be a sensible offer
I think you got a case for a legal action against both your dealer and MB.
1) Lack of Contradictory written information regarding B100
2) Absence of proper documentation when taking possession of the car
3) You clearly indicated your dealer you intended to use Biodiesel and he did not objected in any way.
RPF stands for te German word RussPartikelFilter. that is the German Acronym of DPF.
DPF should be mandatory for all diesels including trucks. they drastically reduce soot
It seems the car develop nearly the same HP and are of similar size and weight. How about performance wise as well?
Well, I know that the MB is maybe twice the price of the Toyota, So this can't be taken into consideration.
Waiting for an Edmunds Comparison test with anticipation
J
I do think it is a flaw, perhaps. Have wondered if one of the drain holes is either blocked somewhere, or if maybe the deck lid gasket isn't positioned properly. HOwever, as I don't drive the car all that much, and it is always garaged, I haven't remembered to follow up on that little idiosyncrasy.
Let me know what you find out. And perhaps I'll follow up at the dealer myself.
J
Anyone else with this same problem?
Well, here's what happened at the dealer. They called and said that the problem was fixed. When I went to pick her up, they explained that "someone" had put too long a screw into the bottom license plates holes and had pierced the trunk lid, thus allowing water to enter the trunk. This seems a little far-fetched to me.
1. Who would FORCE very long sheet metal screws into a new MB license plates bracket. How can you NOT notice when you are busting through the steel lid.
2. I am the 2nd owner and the bottom two screw holes were empty when I purchased the car. How can a large quantity of water enter two vertical screw holes? At that size hole, water would appear to be too dense? to force it's way into the holes instead of continuing to run down the lid. Besides, these alleged holes are BEHIND the plate and bracket and UNDER the overhanging license plate light.
Anyway, they said it wasn't a warranty item and charged me $140 to plug the hole with silicone. A month later the trunk lid is full of water again and the floor of the trunk is soaked. I bring it back and the service writer says this time it's a missing grommet. When I pick it up he says it wasn't a missing grommet. The repairman SOMEHOW missed the fact that there were TWO license plate screws and he had only plugged one the previous time!
I still don't buy the story about two long screws being drilled through the lid. Why would someone replace the existing factory screws with something else? This does not sound plausible or likely to me at all.
Has anyone gotten any substantial discounts on certified used vehicles from a dealer or are the diesels too popular to be able to get much of a discount?
dave
To answer yout question I paid what I did because it was EXACTLY what I wanted.I followed many web sites;Ebay.Trader,etc. I am also a member of the Mercedes Benz club. A fellow member who is also a high end car broker had taken it in trade from a customer who wanted the new S car. Needless to say the car I bought was a special order as these cars are never ordered equiped as this one.
I would say that the price you are quoted is pretty good depending on equipment. We all know that dealers quote higher than they will usually agree to sell. I assume that you have checked all possible rebates etc. Personally I would go for a very good low milage preowned CDI. Maybe you could then get the equipment that you prefer.
Have bought 3 preowned MB's in the last 2 years. One had 1,800 mi,the second 3,500 mi and the third 2,700 mi. Dicounts off list were 15-25%.
Hope this helps. You have to look,look,look and be patient.The internet is your best friend although the one I just bought --a 2007 SLK350 popped up in our local newspaper. You never know where or when a deal will show up.
Dave
I will check to see about my license plate screws, but I agree, their story is fishy. I haven't yet taken mine to the dealer here on that same question. I won't get to it until late March now, but if I figure anything out, I'll let you know! (Unless you now have an answer that satisfies you?)
J
That has got to be the only way to get the sticker anywhere near that high.
How do you like it so far?
I told them that they had a problem then, as most of the FL cars have tinted windows and I guess that all were malfunctioning? Finally they replaced all the sensors and it worked.
With mileage at 47150, I only have another 850 until I have to make a decision on the extended warranty. Looks like a no-brainer with the problems I've been seeing. Still, I hate to shell out $3200 to add another 2 years and extend to 100,000 miles. Ouch! Thinking about getting another with less miles.
Full leather interior, hands free communication,wood/leather wheel,active ventilated seats,panorama roof,tire pressure monitors,navigation,electronic trunk closer,Keyless go,lighting pkg,entertainment pkg,rear seat package,drive-dynamic seats.
Total extras $14,975
Have had NO PROBLEMS. Car is now over 2 yrs old. Average milage 30-31 mpg. Hwy 35 mpg.
What's not to love?
1. How happy are you with the hands-free phone? Can you use some of the current gizmo-loaded phones available?
2. How much of the roof is transparent with the Pano, and do you still have a sunroof up front?
3. Do you really use the power trunk closer often?
4. Do the tire pressure monitors tell you the pressure in each tire, or do they just let you know when they are below a certain point?
2.About 75%or so. #2 Yes
3.Yes.
4.Displays pressure in each tire. Very accurate.
I was told the line must be replaced. Anyone had this problem.
The mechanic told me that the '05's were not built with the new diesel fuel formulation in mind. And he'd seen, as a mechanic there a pattern of leaky hoses once the owner switched to the new fuel. I would THINK that MB would have made any necessary changes to their fuel lines and other rubber-based fuel touching parts to ensure that they were resistant. But then that's common sense...
Second word of advice- as much as I love this car- be SURE to consider buying the extended warranty. I've tried to buy one (Mercedes) now that I have 47,000 miles, but forget it. Too pricey. Much cheaper to buy when new. And you don't have to buy it from the selling dealer. They often think they've "got you" when you buy it new and that you'll just add it on to the total. Price it out from other MB dealers online. I've been told there's BIG differences in price. I'm buying a JM&A ext warr.. Not the same as a MB warranty, but the next best thing and big savings.
A service writer told me that you usually don't need EW's on newer cars, but MB is different. Not because they are not dependable, but because they are so expensive on repairs. He said to replace a/c condenser on this car is over $2,000. That's almost the cost of the EW.
Hope I didn't scare you off.
D
