Best Diesel? Ford,Chevy or Dodge?
I am considering buying a crew cab diesel to tow a toy hauler. The Chevy 6.6, Dodge 5.9 and Ford 6.0 all have good/bad points. The Chevys from what I have read have the best transmission (Allison)& best mileage (acording to MotorTrend). Negatives are lowest tow rating (w/3.73 gear) and somewhat dated look. Dodge is the loudest at idle, has a harsh ride, tightest back seat and only a four speed trans w/questionable reliability. It has the best maneuverability, towing rating and lower pricing. The Ford seems to have the best ride (will even be better with the new front suspension), towing acceleration and roomiest cab. Its the least maneuverable (at least until the new suspension) and gets the worst mileage (a full 2 mpg less unloaded at highway speed than Chevy, .7 less than Dodge according to MotorTrend). The mileage is a big concern for me since 90% of my driving will not involve towing. Any input will be appreciated, especially about the milage.
See Also
Edmunds Diesel Center
See Also
There are a growing number of Allison transmission owners that might disagree with the comment about reliability. Although probably durable enough there are a fair number of owners reporting excessive noise and inconsistent or irratic shifts. Then there's the GM driveline clunk which is more germane to the platform than the transmission.
The new 48RE transmission in the Dodge is so far every bit as reliable as the competition.
The Cummins engine is bullet proof and in my opinion the best of the three choices.
Good luck with your decision.
Dusty
While I am comfortable with the reliability of the Dodge I do not know much about the Powerstroke. I have no plans on tricking out the engine but want a vehicle that will last. Any thoughts about the electronic switch for putting the truck into 4 wheel drive vs the manual lever?
Any thoughts or perspectives would be welcome - sure wish Dodge would come back with the extended/super cab again.
In addition I have been adding a diesel treatment to my fuel every other tank - advice form the mechanic who replaced injectors on the 94 any one else doing this or am I being taken - he said it was due to lower sulfer in fuel thus I need the additives.
kcram
Smart Shopper and Wagons Message Boards
kcram
kcram
My 96 Cummins (3500 club cab 4x4 dually) has gotten a documented 24 mpg highway at a dead-red 57 mph when the tach was at 1700 or so. At 70 mph/2000 rpm, that drops to around 18 mpg.
kcram
There are several performance enhancing chips/tuners available for that Cummins that actually claim to increase fuel economy. I can't comment on their claims, but I can tell you my experience. I have an F-350 Powerstroke Dually. I have a Western Diesel chip good for an extra 75hp and 125ftlbs of torque, putting me at 325hp and 625ftlbs of torque. I did not notice an increase in mileage after the chip, but didn't see any decrease either(I keep very detailed fuel mileage records). However, I suspect I would see an increase in mileage if the darn thing weren't soooo much fun to drive now. I routinely surprise so called sports cars at stoplights. Granted I can't beat them from one light to the next, but they never get more than a couple of car links ahead either. And the roll-on acceleration from 70mph is phenominal.
As far as voiding the warranty, the Magnusson-Moss Act takes care of that. Basically they have to prove that the chip/tuner actually caused the problem. However, I'd say that's something left up to you and how good of a relationship you have with your dealer.
The big 3 need to start selling 1/2 ton diesels and SUVs that get in the mid 20's or better MPG wise at highway speeds.
I think I'll wait and see what happens in the next couple of years.
Around here, where most of my driving is back and forth to work, I average around 18.5mpg. When I load the Jeep onto the flatbed and spend a day off-roading, that tank will average around 16.5mpg. Any 3/4 ton diesel should get you 20 or better.
But you're right, a 1/2 ton diesel pickup would get in the mid to upper 20's.
I don't think that there is much question as to which is the best of the three engines. The Duramax has known injector issues. An estimated 20% in a poll on a pro GM diesel site have had failures. GM has extended the warranty on injectors for '01-'02 Durmax trucks to 200k miles. Ford might have the issues resolved for '05 finally. Prior to that the 6.0 has been problematic, lots of computer related issues and engine oil leaks. The Cummins on the other hand doesn't seem to have a single weakness. In addition it gives the best milage of the three and the most power.
The thing to really consider is the total package and how you will use it. The GM trucks are the most comfortable by far. They ride the smoothest and they have the nicest interiors with the most comfortable seats. I also found my last two Chev D/A trucks to be the most troublesome when compared to my Ford and Dodge trucks. If you need four door room the Dodge runs a little short. The crew cabs from GM and Ford are bigger. My kids are only 7 so the Dodge will work for years to come for me. I also found the ride and handling superior on the Dodge 3500 vs the F350, yes, even the new '05 version.
So since I have little faith in either the GM or Ford diesels living for the long haul, I bought a Dodge with the Cummins and love it. I now have two '03s at work that have been flawless and a new '05 at home. Nice trucks.
As to the milage, I have seen 19mpg cruising at 85-90 mph in a Cummins. My D-max gets about 13 mpg run the same way. The best I could ever coax out of a D-max was about 15 average, and I have owned two of them. The Cummins is easily capable of nearly 20 average with my heavy foot.
Good Luck choosing!
What was the Powerstroke in the '97 F350s? 7.3L? Those, despite the excessive noise, are darn good workhorses. I help my grandfather move his 32' cabincruiser once or twice a year and he hauls it on a quad-axle gooseneck with his F350 auto crew. This truck pulls that boat (all 8? tons) at 65-70 mph all the way from Chugiak to Seward.
I guess we'll see about the long-term reliability of the engine, but we do not have to worry about the rest of the truck.
I have to agree about the Cummins engine being trapped in the Dodge truck. I bought the Ford because I think Ford has the best total package going.
