Chevy 4.3 Vs. Ford 4.9
1. The 4.3 is a 90 degree V6. The optimum configuration for a V6, with regard to vibration and balancing, is 60 degrees (6 cyl X 60 degrees = 360 degrees or 1 revolution). The reason the 4.3 V6 is 90 degrees is because it is derived from the Chevy 350 90 degree V8. A 90 degree block is optimum for a V8 (8 cyl X 90 degrees = 720 degrees or 2 revolutions). Anyway, what this translates to is the fact that the 4.3 V6 is not very smooth and early 90s models had a rough or uneven idle and a fairly low redline. I believe later (>94 models) and current models have a counter rotating balance shaft to help tame this vibration somewhat. The 1990 model engine does develop good torque down low in the RPM band, about 235 ft-lbs, but only about 160 HP.
2. The Chevy 4.3 V6 inherited the valve guide seal problems of the Chevy 350 V8. It is fairly common to see blue smoke at startup on these engines once they get about 80,000+ miles on them due to oil leaking past the valve guide seals.
there are practically as many 4.3's out there as there are 350s. VERY popular engine in the Blazers. Also, a highly popular engine in mid size marine craft. thousands of 15-17 ft ski boats out there with Vortec 4.3.
4.9 is bulletproof, but 4.3 outperforms.
I know of a couple of others,one in a Monte Carlo that are close to 300,000.It looks like the motor will outlive the car.
The 3.8 is a nice one. Lopped off 305, right?
My brother in law owns his own shop and has seen quite a few 4.3's go over 200,000 miles in full size trucks without ever having the valve covers off. I have a 4.3 S10 and it has been great.
That was a near-miss! You were about to praise a Ford motor! Heavens forbid! (GM's Heaven, that is)
The 2.8/3.1/3.4 GM family are 60 degree V6's.
The reason for the new engines is ease of manufacture, the inline 4,5 and 6 will come from the same assembly line. All cylinders in a row, no second bank to machine. One head not two.
And since they're all inline its much easier to use DOHC on them, (all versions are to be DOHC)
vs a "V" engine.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
