With drum, you better watch out for those springs if they decide to go airborne at you. Yes, I do remember those days with 4 wheel drum brakes!!!
For repeated stops from highway speeds, yes, disk brakes have the advantage. Most minivan drivers won't be pounding the brakes from 80-30 in rapid succession, unless they are open tracking the car (of course, the Ody HAS been referred to as the BMW of minivans.....)
Coming down a mountain? Put the van in D3 and use engine braking. Just because disk brakes dissipate heat better than drums doesn't mean they are immune to brake fade.
"Guys"(and some gals) who are into cars and the "driving experience" will prefer Ody.
Most women/Mom's and guys who aren't too into cars will pick Sienna because of the smooth drive.
That's why I think the Ody wins out in most of the car magazines because most of the test drivers are dudes who mostly care about the "fun to drive" factor. I think the results would be different if they went out and got a bunch of random Mom's who are the primary drivers of minivan's. Although I do know that apparently demographics are changing and more guys are buying(according to CR).
Regardless, both great vans. Just my 2 cents.
Agreed. But I don't believe that many drivers think of using their engines to slow down their cars while going down mountains.
Howvever I do believe that using the engine to slow down your car must be very stressful mechanically to your tranny, and other drive train parts. I remember during my teenage kid years shifting my manual tranny down from 4, 3, 2 to slow down my car because it made an "impressionable sound" with my "straight-thru" muffler. I have destroyed a couple trannies then. Seems like a long time ago!
Personnally, I would only use the engine/tranny to slow down my car during an emergency. I would use my brakes on all other situations because it is far cheaper to replace disc pads or even rotors than a tranny or other drivetrain part.
It depends on where you fit in the spectrum of driving styles and preferences that I have described in past messages.
Mostly because of weight. Most big SUVs weigh 1000 lbs.+ more than a minivan, and can carry more weight on top of that. All else equal, wider tires have a higher load capacity.
"Do wider tires give the car better emergency-handling capability, braking power, and stability?"
Yes, all else equal. However, they aren't equal here. Body on frame platforms with a higher center of gravity (big SUVs) are inferior to unibody platforms (minivans) in just about every respect other than towing capacity. I doubt you're going to notice any handling differences going up 10 mm in section width. The type of tire you choose would have a much bigger impact. OEM minivan tires are generally pretty mediocre. Choosing a better tire could increase grip significantly.
The Sienna has a softer ride and the Oddessy drives more like a car. I think the Oddessey is faster, which may not be a priority in this market, but what'd I rather be in while merging onto the freeway with a carload of passengers? The Oddessey.
The Oddessey's 8-way configuration seems better than the Sienna's, b/c the Oddessey's middle seat can double as a table and fold into the floor. Oddesseys 2nd-row seats, in general, move more easily than the Sienna. I think this is a minor point - we've had our Minivan for over a year, and once we found the config we like, it hasn't changed. Bottom line: If you want to go with the 8-seat config, but aren't sure you'll use that space all the time, the Oddessey has a slight edge. Otherwise, it's even.
Based on the above, I don't think you can go wrong, though I give a slight edge to Oddessey. Frankly, I'd copare the 2 with the options I want and see who'd give me the best deal.
You cannot go wrong with either one.
The other "non-option" option are rear seats that will only be used on occasion should fold flat easily and in separate parts. Both Honda and Sienna now have the split-folding seat. When I was looking at them, Honda didn't have it. We didn't view it as a big deal, but went with the Sienna anyway. It's so nice to be able to keep part of that back seat down! It gives us lots more storage that way, and if our back is full when we take on that extra passenger, instead of unloading the entire trunk, we can shove it over to 1 side and convert the other to a chair. It also makes each portion a little lighter and easier for my wife to convert the backseat on her own. It's a great idea. I think a 2nd row seat that folds flat into the floor is nice in this way, too, but not necessary.
Anyone else know of any "necessary" options?!?
As I said, I'd love the auto doors, but NEED the 8 passenger and Toyo doesn't offer it in XLE. So, I really don't have much of a choice. I'm trying to hold out to see of the 2006 will have an available XLE 8 or LE with 2nd slider(at least), but I've not gotten much confidence from the toyo dealers.
Lugging 3 kids around, I'm sure my wife would LOVE and appreciate all the auto doors, but getting the 8 is more important to her so we may be SOL!!!
There is not such "theory". Energy mostly dissipates for bending rubber and compressing air, not for friction (unless you spin wheel or slide in the corner). Width is not that important - load, sidewall construction, elastic properties of the compound and void ratio and inflation pressure are the things to watch.
You completely mixed up a well founded (and supported by all available professional reviews, from Consumer Reports, to Car&Driver, to this site) opinion that the Odyssey is the best available minivan in 2005 with the notion of "perfect".
Of course it is not. It is is just other are even less perfect.
Basically, my wife will be driving this thing primarily and I've left it up to her to make the call. She is also much more comfortable with the REAL 8th passenger seat in the Sienna. That definately WILL work with a car seat. The Ody is questionable and she really isn't comfortable(nor am I) having that question/risk hanging over our head.
Take those things away...the 2nd power door....and honestly on that day, there was no comparison. Sienna won by a landslide. It wasn't even close. Then you come here and read everything and try to think logical and I'm wondering if I should go back and drive them in reverse order this time or something(we did them both on the same day..Sienna 1st....we had seen both several weeks apart previously and were leaning Ody before we did them both back to back). It makes me wonder if we're crazy or something.....how can you possibly pick something over the Ody....I mean that seriouslly too. It is strange.
That may be one of the reasons why those specialty vehicle competition to get the highest gas mileage uses those skinny bicycle tires. The skinny tires also present a smaller frontal/cross section area for less wind resistance as well for higher gas mileage.
What is more important is how the vehicles stand the test of time over a long time of say, at least 100K miles, which is the actual reliability or the maintenance of a satisfactory quality level over that 100K miles or a number years of use. CR is a good example of an agency that provides those reliability statistics from owner surveys covering many past years of usage.
I wouldn't look for a certain type of opinion on either the Ody or the Sienna. It seems that pricing and dealers are very different according to region, I would worry more about that since either choice will likely serve as a reliable vehicle for years to come.
enjoy the drive
I didn't read your first post on what the Sienna has on it, and you sure couldn't go wrong with Toyota. Not sure if many could put the Honda down for second place on luxury. But I know from experience, looks soon wears off and then you wish you had all the goodies you passed up for looks. If the wife is going to be the main driver, a power tailgate would really be a blessing to most women, unless they are sort of tall. It isn't that easy to close the tailgate on these minivans, especially for shorter women. One could get by with one electric sliding door. That should be one thing women try doing when deciding on options on a minivan.
I'm guessing that the Sienna's seat cushioning is a little cushier than the Oddessey, and there's more leather used (you know how some fancier cars have "folds" or pleats of leather in the seats and door?) in the SIenna. Not sure about the Honda's trim, but the Sienna's wood trim is also very nice.
Not sure when that happens - we have a year old Sienna. Had the interior carpet professionally cleaned from spilled (and ultimately spoiled) milk, the color on the driver's seat is wearing off, and the back is filled with toys, strollers and cups, but every so often, my wife and I look back there and think, "Man, what a pretty car!!!" or as Thomas the Tank would say, "What a useful engine!!!" So glad my kid is past Barney and never got into the Wiggles!!!! :P
Ody- BMW of minvan
Sienna- Lexus of minvan
Sums it up. The Sienna's ground clearance, interior ride is nicer and AWD appealing in New England
Ody drives more like a car, sportier. Priced better, but more int road noise and lower to ground and no AWD
Neither have bluetooth! wanted the NAV and the rear camera
Sienna XLE limited with NAV RES 38k
Ody XLE with Nav Res 32.5 K (didn't the the touring was worth the extra)
Based on other postings, I'm leaning toward the Sienna. But price and having driven an accord for 7 years and a civic before that have me still thinking about Oddy
will either 2006 have bluetooth?
Write down your priority options that you (or your spouse, if that's who will drive the minivan the most) really must have, based on how you will use the minivan and your driving style, and bounce these against the two choices.
For example, do you value conversations/listening to your favorite radio/CD while traveling the interstate freeways? Maybe the one with the quieter interior is better. Or, do you value a "sportier" ride above all else, especially when you're city driving (stop and go stuff)? Choose the one with the "perceived" better handling. Is price a factor or not? Choose what you can afford. Do you typically get rid of vehicles after a few years to upgrade? Make a decision now then change it (and lose $$) after several years. Or do you hang on to them regardless of what your neighbor/friends bring home from the dealer (get the one that pleases you the most with the most features you want because you're going to live with it for awhile).
Also, something to consider is that in a few months both cars will have newer models (Sienna to get a facelift - - front and rear; Odyssey to iron out the "first-year bugs"). Prices for 2006 may go up, too.
Let us know what you decide.
Cheers,
Wayne in Belgium
I don't know about the rollover senor, but the Sienna can be bought with all the airbags. Something to consider is that if you have kids in full carseats, you may not want the airbags. There are always warnings about how they're dangerous for kids, and if you attach your carseat correctly and strap the little ones in with the 5 ppoint harness, they won't need an airbag to prevent them from hitting the roof, side or seat in front of them. Airbags are only useful to prevent our heads and bodies from hitting other parts of the car upon a crash.
Sienna does not have the rollover sensors. Finding Siennas with the side/curtain airbag option (if desired), can be problematic, particularly in the CE and LE trims.
"There are always warnings about how they're dangerous for kids, and if you attach your carseat correctly and strap the little ones in with the 5 ppoint harness, they won't need an airbag to prevent them from hitting the roof, side or seat in front of them."
The only potentially dangerous airbags are the front impact airbags and the side airbags built into the sides of the front seats. Which is why children should not ride in the front seat. The side CURTAIN airbags are NOT dangerous to occupants unless they are sleeping with their head actually against the window. In which case, in the event of a side impact, I think the occupant has more to fear from the large object attempting to gain entry to the vehicle by way of their head than they have to fear from an inflating airbag.
They won't need to airbags to prevent them from hitting interior portions of the car? You've made a couple of huge assumptions: 1) they stay in their seat and the seat stays in place (a fairly safe assumption), and 2) the roof/doors/side of the vehicle remain where THEY are.
EXCELLENT, EXCELLENT, EXCELLENT POINT!!!! Thank you for pointing that out - it was so obvious I completely overlooked it!
One more test drive this thursday with the wife and then purchase time....
I think the traction control only works below 30 KMPH? I had a 2002 that I took over the mountain into Yosemite in the middle of a snowstorm. I would take the low route if I had it to do over again, but the Ody went up fine, and the traction control worked well. But you had to go slow, not a bad idea in snow anyway.
But AWD would probably be better, in my opinion.
Cheers,
Wayne in Belgium
Well, I think it's safe to say we won't be exceeding 30,000 MPH in an Ody anytime soon. :P
But seriously, where have you heard the 30mph limitation? I've never heard of this before and I don't recall seeing anything about it in the owner's manual. If there is a speed limitation, is the Sienna fitted with traction/VSC also only effective at speeds below 30mph? :confuse:
FYI
Toyota Ken
Again, this is the first I've heard of ANY kind of speed limitation either traction control or VSC. As pointed out above, the Sienna has no limitations on the speed at which either system is useful. So why should Honda go to the trouble of installing a speed cutoff point after which the system is no longer functioning????
Secondly, as Toyota states in their glossary, Traction Control is generally needed when starting up (thus Honda's slow speed limitation) and sometimes on acceleration on slippery surfaces. However, the latter requires some more sophisticated decision-making software with pretty precise controls (to avoid making the matter worse which can happen very quickly indeed at higher speeds). Toyota has apparently provided that added sophistication to their system, while it seems Honda has not (apparently using the speed-limit on their Traction Control to avoid having a less complex system exacerbate rather than solve slippage problems at higher speeds).
In both makes, the VSC/VSA (Vehicle Stability Control/Assist), is a much more complex system including sensors for yaw, steering angle, and G-force to help determine over/understeer and activate throttle and individual-wheel braking to attempt to improve things.
Toyota wisely goes so far as to strongly suggest safe driving habits by pointing out that even their marvelous system is still subject to the laws of physics (being unable to provide more traction than could possibly be available in a given situation).
Let us hope that the programmers of these systems use near-Space-Shuttle levels of error tolerance acceptance in their coding and testing practices. I would hate for some Monday-morning-code glitch to decide that I should really drive straight off the highway rather than to follow the pavement. So far no such reports have surfaced. Let's hope it stays that way.
I'm only slightly exaggerating here. For someone who experienced the car "taking over" in a bad way like that, it would be like the ocean suddenly rising for the first time in human memory as it did in the Indian Ocean. It takes a while to willing go near the water (or vehicle, in this case) again once it proves that it won't necessarily behave like it is supposed to do.
I think I'll prefer my vehicles stay somewhat less decisive for the foreseeable future so that I can attempt to avoid any that run wild on their own. (Being a programmer/analyst/trouble-shooter myself makes me even more nervous knowing the many ways to miss something in coding, then to consider the many ways sensors can fail... Shivers run down my spine!)
http://www.safercar.gov/
See the "Safety Concern" they note in bold letters. Shame on Honda.
So, let me see, your wife gets hit driving it, she's ejected and killed....
If you don't skip this vehicle for that reason, you aren't human !
