The PAX tire cannot be removed from the rim it is "molded" onto like a regular tire can. PAX tires aren't mounted on the wheel like regular tires and wheels. Replacing tires costs a fortune because of it, and is the reason my aunt avoided the new Touring model and got a "plain ole" EX.
As of today you'd have to put a set of four rim/tire combo 'assemblies' in order to replace what was delivered, not just swap rims. You may want to consider buying just two for the front to save some moolah. For serious snow dogs the Ice-X (PAX snow tires) might be an option but I see no need for them here in sunny FL, wink. Anyone in dire need should consider zip code replacement therapy IMHO.
Partially true.
The PAX tires CAN be removed from the PAX rims but it does take specialized PAX mounting equipment. I would be surprised if any Honda dealers have the necessary PAX mounting equipment which is why the Honda dealers only deal with complete PAX system 'subassemblies' (ie. wheel/tire combo).
However, according to the Michelin website - "There are approximately 200 Michelin-authorized servicing dealers nationwide with the appropriate PAX System-capable mounting/demounting equipment."
http://www.michelinman.com/difference/innovation/paxsystem_faq.html
It would seem that those individuals seeking to mount PAX snow tires should determine if any local Michelin dealers have the necessary PAX equipment before investing in complete wheel/tire assemblies from their Honda dealer. Also, it seems likely that those Michelin dealers who have invested in the PAX mounting equipment are more likely to actually have PAX tires in stock, saving the buyer from having to order assemblies from their Honda dealer.
$2400 versus $1600 is a rather signifcant difference.
I am 6'4" and am quite comfortable in my 2006 Odyssey EX-L. I would say that it is equivalent to my 1995 Suburban that I just sold. In my opinin, part of the comfort issue is not just the leg room, but where your legs go. The Odyssey works quite well for me.
The point I was trying to make is that proper inflation and near perfect alignment are more critical on the Ody with PAX tires than with conventionals.
You theoretically could put regular rims and tires on a Touring but you'd have some issues, namely the TPS going haywire all the time that's why no one does it (also speedo error due to different outside diameter). TPS works well so why mess with it? Consumers should recognize that this technology has drawbacks along with benefits. With a PAX Ody (Touring only) smart folks will rotate frequently, check/adjust pressure regularly, and be aware of treadwear trends. Those complaining about very premature wear on any tire probably ignored one or more of these duties. That may or may not be the case on a Sienna. These tires are not set and forget even with TPS, just like any other.
The Odyssey TPS will monitor that all tires are within programmed limits. It may not sense the 2-3 PSI variance that can affect wear unless close to high or low limits. For example, when I was in Atlanta, I got a warning the left rear was low. This happened right after a cold start (four hours of Lennox shopping) with ambient at 32F. I pulled over in less than a mile and checked pressure and it had climbed to 32 as the tire warmed up. I gave each a shot of air as cold weather insurance even though the dealer had adjusted pressure and rotated within the last 1K miles. My lesson learned was to keep tires in the middle (or even top end for better MPG) of the recommended pressure range, running 33 rear, 35 front on ours (cold at 65F).
Bottom line is if you can't afford to replace tires about every 30K miles then perhaps the Touring isn't for you.
P.S. Please, whatever you do in life NEVER become a financial consultant.
Thanks for your help.
Your right, Mon!
Let sleeping dogs lie. That's good dog-gone advice.
My 04 Ody EX(made in July04) has been flawless and is just great fun in embarrasing all its competitors in the curvy exit ramps with its acceleration and handling/cornering!
PS: Premium gas is not required for the Sienna - with automatic timing, it will run OK with less HP. But premium is required to get its max advertized HP. This is one sensitive area that any manufacturer would shy from disclosing.
The Ody gets it max advertized HP(10+ more than Sienna with premium gas) with regular. Great for lead footers!
BTW, I also own a MB, BWM, Lexus, and Odyssey. I also have more money than any financial consultant.
Just how many HP and how much torque does the "silver bullet" have on 87 octane gas?
Certainly not a performance vehicle!
The Odyssey is rated a lot more that 10 HP more than the Sienna since Toyota revised the Sienna ratings and that does not take into account the premium/regular difference!
As I said before, if someone wants quality and reliability, there is only one manufacturer name TOYOTA/LEXUS
--end of story--
--end of story--
There is no "end of story" on these forums until noone else posts. Someone my dad works with owned his Camry until, at 55,000 miles, he was on transmission number three, ignition two, and second windshield wiper motor (pivot points wore out prematurely, causing wipers to flail around on the windshield when turned on at speed).
We owned a 2000 Ody that ran like new when we traded it in this year. Each car company has good days and bad days at the plant, it seems.
I'm not saying either car company is terrible, as both Honda and toyota are amazing in their field.
Well, its not a wash, the Ody weighs 240 pounds more, about the weight of one large person. With 30 horsepower to offset one person's weight, I'd say the Ody has a definite advantage. Throw in that the Sienna requires premium to achieve max performance, the Ody increases its advantage further.
Well said!
We owned a 2000 Ody that ran like new when we traded it in this year. Each car company has good days and bad days at the plant, it seems. "
It is refreshing to come across folks like you with a broader vision.
A colleague of mine got rid of his Toyota Tacoma due to Toyota's engine sludge problem. But that would not blindsight me into buying a Toyota vehicle that suits my purposes. Both Toyota and Honda are recognized as leaders in quality vehicles. My Ody has been flawless and fun to drive since buying it.
My husband and I are expecting our third child in May and are looking to replace our 2000 Ody. We haven't been to the dealerships yet- will do that sometime in the next couple weeks. Our concern is whether or not the 3rd seat in the middle row is meant to be used all the time or as an occasional seat. We want to keep all three kids in the middle row (I feel it's safer)- but we'll have to fit a booster seat, a convertible car seat, and an baby carrier for a least a year in the middle row. Does anyone have any suggestions or advice regarding which van would fit the car seats better? In looking at the Toyota web site, the extra seat in the second row looks a little bigger than the Ody. But it seems as though you can only get it in the LE and without leather seating. We also want leather and a moon roof. Are we asking for too much??
Any advice would be greatly appreciated.
Are you sure the child in the booster doesn't want in the third row for a space all his/her own? My daughter sure escaped back there as soon as we would let her. Of course, by that time, she was able to buckle herself in.
Good luck in your search - its gets confusing, with all the vans offering completely different features.
You can use the Honda PlusOne seat all the time, but it is quite narrow. That may limit who can be seated comfortably and what carseats will fit properly.
I wouldn't worry about any danger with the third row seating. The outboard seats are likely to be more dangerous, given the frequency and severity of side impacts vs. rear impacts. Any rear seat will be very safe for kids provided they are properly restrained in a correctly installed child seat.
I was about to buy an 8-seat Sienna to have all the kids in the second row, but found that my older kids needed a bit more separation. I have a lengthy review comparing the 2006 8-seater versions at epinions.com if you want more details.
These might also answer some questions:
http://www.suvsafety.info/thirdrow.html
http://www.car-safety.org/odyssey.html
Good luck in your choice. You really can't go wrong with either one, but one may be better suited to your situation.
And if anyone want to beat it beyond death take a look at the blog entry on class-action lawsuit against Toytoa and feel free to add your comments.
Run flat tires wear quicker and cost more than regular tires
We recently purchased a 2006 Odyssey EX-L with the extra middle seat. With the arm rests down the middle seat is good for a young skinny child. With the arm rests up the seat is acceptable, but not great. We have three kids (3, 8, 13) and my 8 year old loves the back seat. Sometimes he gets all three seats, sometime two and sometimes one depending on how the seat is arranged. I do not feel that the very back seats are any less safe than the middle seats and it can make for much more pleasant driving with the kids separated. BTW We replaced a Suburban with the Oddy. In the Suburban the kids usually sat in the middle seat, and although it was wider than the Oddy, it was often too close, so I am happy how accessible the back seat of the Oddy is.
Well, its not a wash, the Ody weighs 240 pounds more, about the weight of one large person. With 30 horsepower to offset one person's weight, I'd say the Ody has a definite advantage. Throw in that the Sienna requires premium to achieve max performance, the Ody increases its advantage further. "
It is definatly a wash.
Consumer reports got both of them 0-60 in 8.6 seconds and 0-30 was 3.3 for Accord and 3.1 for Sienna, quarter was 16.9 @ 84 mph for both. You can't get much more even than that. If anything the Sienna has a slight edge off of the line. HP in inself means nothing - it is the total package that effects acceleration. Besides - who is gonna race these things.
ok - is the 2000 reliable? is it paid for? have you forgotten how much diapers cost?
i have three. personally - the further i can get them from the driver's position the better.
i think a child seat could be installed with an attachment onto my roof rails. i've got one of the three with no fear that would be willing. i think the GA patrol wouldn't take kindly to it... but i can imagine the smiles and thumbs up from those in the passing lanes.
what do you want to do, be able to feed the three from the front seat? you need to work on your backward toss. my wife can hit any of the three (youngest in row 2, older 2 in row 3) with a stray food item or errant plastic toy without looking in the mirror... forces the kids to be vigilant and develop better reflexes.
and anyway - we feel safer as it's harder to get hit up front by a sippy cup from row3 than from row2. by the time they graduate to row3, they no longer need sippy cups anyway - mine are into starwars figurines and light-sabers.
hope it helps.
I'll play your silly game - 0.
But I don't think that means Sienna buyers must automatically put up with run-flat tires due to the lack of room under the van for a spare tire. The Odyssey doesn't stow it's spare tire under the vehicle; it's stored upright on the left side of the rear cargo area. Are you implying that Toyota simply CAN'T figure out how to store a space-saver spare in the van and that a space-saver spare MUST be stored under the vehicle?
This is not a silly game. It is a serious question for a lot of buyers.
Chevy Uplander LT
Buick Terraza CX and CXL
Pontiac Montana SV6
Saturn Relay
I don't know if these AWD systems require the use of RFT's or not.
The reason why I made the comment regarding 'silly game' is because the gist of the complaint regarding the Toyota AWD vans was the fact that the RFT's on the AWD models had problems. You seem to think that Toyota had NO CHOICE but to use RFT's on their AWD models since the AWD drivetrain intruded on the spare tire storage space.
My point is that if Honda was able to find room inside the van to store the spare tire (without occupying storage space), why couldn't Toyota? Are you saying that Toyota simply COULDN'T design a place to store the spare on the AWD models and were therefore FORCED to use RFT's?
On the current generation Odysseys equipped with standard tires, Honda provides a donut spare stored upright behind a panel on the left side of the storage well behind the 3rd row seat. I haven't checked to see, but I sincerely doubt there is room in this storage location for a full-size rim/tire (the flat). I don't know if Touring owners can purchase as an option a donut spare to go in this same location; I've been told the space is used for part of the stereo system in the Touring (either an additional amp or a subwoofer; we don't own a Touring so can't expound on this any further).
Like Toyota, Honda apparently feels that those owners of their vans equipped with RFT's should have no reasonable desire (yeah, right) to carry a spare. Personally, I think this is a bit short-sighted on both Honda's and Toyota's part. Many folks are not sold on the whole RFT concept and have a real desire to carry a spare. Personally, I think Honda should have left the space alone on the Touring models so their owners could put a donut there if they desired. I also think that Toyota could have figured out a way to store the spare inside the vehicle; regardless of if the van was AWD or FWD.
Keep in mind that the little angels, no matter how cute they are now, are territorial beings and will fight to death to defend their own personal space and belongings. WHILE YOU'RE STUCK IN TRAFFIC FOR OVER AN HOUR.
By the way, why pay for another new vehicle only to mess up the interior with spill juice, grind cheerios, fries...
As a Touring owner I get my donuts at the Krispy Kreme drive-thru, thank you. I have to turn down the 300W stereo when ordering and don't care if I could carry a temporary spare tire in this third row 'stereo' space (can I store other goodies there instead?). Because of the donuts, I carry my spare tire around with me all the time and am comfy doing so in knowing I have 150 miles before any flat is truly flat, plenty of distance to reach a Mich or Honda dealer in 95 percent of North America. I am completely satisfied that PAX has the right logistics in place, something Toyota overlooked, possibly because even they felt the technology was still evolving.
I hope you aren't offended if I honk at non-Touring Ody owners changing a tire on the side of the road? As you turn your head to see who did that, note that the '06 Touring has two badges on the left side of the rear hatch, LOL.
...note that the '06 Touring has two badges on the left side of the rear hatch, LOL."
Whoa, that was you? I thought it was all the badges on the left side making the van lean over that way.... :P
