A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Calculate final drive ratio?
How can I calculate the final drive ratio of my
Silverado? It originally came with 3:73 gears and
245 75R 16 tires and I want to find out what the
final drive ratio was before I installed the 285
75R 16's Goodyears that I now have on it. A formula
is all I really need. Thanks.
First, the final drive ratio will not change unless the ring and pinion gears are changed in the rear end. What will change by changing tires is the distance covered when the engine turns a specific number of RPM. Tires that are larger will cause the odometer and speedometer to read lower than actual.
I've never seen the formula that Quad is suggesting. Knowing Quad from this forum I'm sure that the formula is based in fact.
There is another way to determine the percentage of error by changing tire sizes or brands. Most tire dealers (even Wards) have a book that lists tire sizes and brands and tire revolutions per mile. If it were me I would just look up the revolutions per mile and use the formula of:
(Old Revs - New Revs) divided by Old Revs
This will give you the percentage of change from The OLD to the NEW. If the percentage works out to be, say, -10% then when your speedometer is reading 54 MPH you are really doing 60 MPH.
You also may want to consider having your truck dealer correct the speedometer / odometer for the new tire size.
Remember that when you increase tire size both acceleration performance and calculated fuel mileage degrade. (The fuel mileage stays the same it's just the calculated number is worse.) However, on the bright side, your commute in terms of miles is suddenly less
Rich
than actual.<<<
roll them both one full turn.....the 4 footer went further...but the center..(driveline)...is the same no matter what size...
If the center is turning the same...but the huge tire is covering more ground...(going faster)...then the speedo will read low with bigger tires..
- Tim
R....
- Tim
R...
you could say that yes..it has changed...by the means of what the tires are doing...but the gearing has not changed..
Mixed up yet?
- Tim
- Tim
So it's not what has changed inside, it's basically just what you are feeling by the seat of your pants
yes I am confused, but I guess it could make sense too.?.?.?
R.....
the amount of RPM that the engine could develop. Catch 22 again.
Bookitty
Ring-pinion.com and try thier final drive calculator there.I think everyone here is right just a matter of sematics.
The taller tires don't really technically change your final drive,but in all practicality they do because they do the same thing.I have always heard that changing tire size is the poor man's ring and pinion swap.Well if nothing else hopefully ring and pinion service listed above can help.
Ring and pinion would be cheaper than tires....if you did it yourself?...depending on what tires you got...perhaps even cheaper having it done as well?
- Tim
I guess theoretically it is easy to set up but I'm beginning to think there is a little bit of Vodoo involved in getting them absolutely right.
Well...regardless unless your buying two super expensive tires the tires are probably still cheaper,I don't know about Chevys and Fords but new gears for my Mopar are 155 bucks plus another 100 bucks for the kit to set them up,and another 135 bucks for the tools unless you already have them.
LOL
- Tim
Besides...if the gears are too deep I won't be able to hear Dwight Yoakam on the stereo.
I think the reason the Richmond Gears whined in my application is because they made a 3.23 to fit a 2 series carrier. With everyone else, you had to go to a 3 series carrier. There must be good reason for this. My problem was solved by putting in an Auburn limited slip 3 series carrier (oem standard), and GM pinion and ring.
The Z28 sound nice...have fun with her...every good car needs a proper name my Cuda is named Betty the Barracuda,she is part of the family and I've only had to fix the stuff that wasn't broken in the first place.Trust me name your Z28 and it won't let you down.
Good old Muscle cars....they did one thing and did it good....went fast in a straight line!
Turn??
Stop?
Who needs to do that?
Good old 4 wheel drum brakes....
Every race had two contests....1 to see who could accelerate the fastest.....and the other one to see who could stop before the next intersection!
LOL
I would mash that pedal....the have both hands pushing the steering wheel and both feet on the brake.
AHHHH
Those were the days..
- Tim
Rich
...Killer..
LOL
- Tim
Now on a race track it might make a difference,but on the street she is still competitive.
Greg
Bookitty
Greg
Bookitty
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
