1332333335337338854
  • fintailfintail Member Posts: 58,732
    LOL at the Corolla
    The Velox and its clones have a cult following in the UK among the 50s nuts...over here it's just a freak. Same for the Oxford... insanely rare here, but nobody on this continent cares. In England it'd be back on the road already.
    That Camargue looks amazing. Memories of my first large Bburago car. 1985 is the end of that model, and somehow I don't recall those headlight wipers, very amusing and I suspect uncommon or a late model addition. Certainly a money pit, but much cooler than a period RR sedan. I almost want to like it. I'd take it over a Shadow/Spirit/Spur any day.
  • gsemikegsemike Member Posts: 2,451
    The Rolls is rare but so not interesting, especially from the back. What is a real price for it?
    The Rolls does look amazing for it's year, except for the centre dash. It looks pretty crude/rough. But I guess for the 80s that was top of the line.
    That seller apparently imports many luxury vehicles from Japan, and I wouldn't be surprised if the Rolls came from there as well.
  • andre1969andre1969 Member Posts: 26,113
    That center console does look a bit strange. It makes me think of something that might have been built to go into a motorhome or conversion fan.
    I'm not so crazy about the style of the car...in fact from the rear it sort of looks like a Monza or Sunbird notchback, especially with those tailllights. But I'm amazed at how white that interior is! I wonder how hard it would be to keep it that clean?
    **edit...oops, I totally missed the center of the dash, I was just thinking the center console. But yeah, like Fintail said, it's probably messed up like that because of having a radio swapped out.
    It's also a 1975 Italian design, so some of the details are not of the best quality. As was said in the post before, the rear end is kind of clunky. I suspect that dashboard originally held a period multi piece stereo that was replaced by the cheapo modern unit.
    Your Japan theory is probably true, the low mileage supports that too.
    Regarding the price...he wants 55K CDN, which is roughly 44K US...I'd say something around 30K is probably realistic, if it is mechanically perfect and has recent brakes and servicing. With production for the global market of about 50 units per year, it is very rare...but demand has to be tiny.
    A RICH masochist at that! The BDSM community has nothing on this guy!!!
    Oh, those are the "aircraft inspired" instruments and switchgear Rolls pointed out in their design of the Camargue. I guess this is what passed for "high tech" in the mid 1970s when the Camague debuted.
  • texasestexases Member Posts: 11,174
    Too bad the aircraft doing the inspiring was a Cessna 150 :P
    Yeah $30K for a really nice one. If you shop around, anywhere from $20,000 to $30,000 a pop should get you a boatload of Camargues. At $55K he is simply out of touch with the marketplace entirely. They made over 500 of them so they're around. In the heady days before the bust in 1990, you could get $45K for them, and maybe a very low miles, celebrity owned car (like with 5,000 miles on it) could break $40K.
    Rusted Porsche 914 -- crusher.
  • steine13steine13 Member Posts: 2,827
    ... have gone cruising on the seattle craigslist.
    but i searched for "conversion", hoping to unearth some cool older conversion vans... instead i got this and thought y'all would appreciate the humor:
    http://seattle.craigslist.org/est/cto/1034000537.html
    Project car hell
    roll it off a cliff?
  • gussguss Member Posts: 1,167
    Did he mention he just does not have the time to deal with it.
    So he's going to unleash Franken-Van on the general population?
    Screwed up projects like this NEVER get done, because there is no sound foundation.
    Well, it took my much longer than expected (about 15 hours), but I finished the t-belt, tensioner, water pump, cam/crank seals, t-stat, spark plugs, oil change endeavor. I spent at least a good 3 of those hours just removing the crank timing pulley. I can only assume it has never been removed, which is interesting since what I've read tells me the crank seal typically needs replacement at some point, and at 156k miles, you'd think it needed to be done before. Anyway, it was quite the chore "unfusing" it from the crank. There was probably another couple of hours in there spent "making tools" to do certain things. Like reshaping one of my gear puller tangs with a file to get just the right angle or cutting down a piece of PVC pipe to press the seals in place, for instance.
    I also replaced the trans oil and installed a post-cat exhaust gasket that was missing entirely (remember in the ebay description that it had a "small hole in the muffler" ... yeah, the leak was about 2.5 feet ahead of the muffler, chief). SOOO... all told so far, I've put about $330 into it. $130 of that was JUST fluids! Synthetic oils are so damned pricey.
    Last night I ventured into the small bit of rust repair it does need. Its a small area on the lip of the rear passenger fender. Its just surface rust where the paint chipped, but I don't want it to spread. I've never tried it before, and I know it will look bad, but if it stops the rust, that's all I want for now. So I sanded it with rough, then medium, taped off the surrounding area, and threw on a couple of coats of rust-inhibiting primer. I have a can of red enamel on the shelf, so I think I'll spray that on. Or I could go splurge on the proper factory code paint. But, is it really necessary? It won't match either way, right?
    Next thing I think I'll actually spend money on is a detail shop to buff the paint. Just don't know of one nearby or convenient.
    So the crank pulley is held on by a slotted key? I remember on older Volvos how careful one had to be with stubborn cam pulleys. You could break the tip of the cam off very easily, and many people did.
    yup. crank has a key "holding it on." But, really, its the damper that does most of the holding, as once I cleaned off the rust, the crank pulley went back on without fuss.
    The camshafts, on the other hand, have a fixed notch and the pulleys are held on by the bolts only.
    Geeze, q, I should have brought the Celica up your way. You could have done a major disaster brake job on the back. Instead I paid retail....
    i charge less, but take longer. ;b
    what's a "major disaster brake job" anyway?
    That would mean the calipers as well as pads and rotors. This was the first mechanical work I had done on it since what I put in right when I bought it about 10 months ago.
    I did have to replace the rear curtain on the top. Once the weather allows the top to go down again I'll be happy about that.
    Had to put two tires on my daughter's car today just to add to the fun. She hits me first thing this morning with "Dad, my car is making a clunking sound." I tak eone look and say "driving on a flat will do that." :sick:
  • jlflemmonsjlflemmons Member Posts: 2,242
    Yeah, had that happen a couple of years ago. Wife called while returning from long road trip to tell me "the van is making a funny vibration". My son (young at the time) followed my intructions to go look closely at the tires, then called back to tell me most of the tread was gone off one of them. :confuse:
    Seems she would have noticed that. Not.
    I had a friend who drove across the entirety of the Golden Gate Bridge after having lost the tire AND wheel. Thought it sounded funny, but they were going slow and just thought it was a flat tire. They were flagged down and towed off the bridge, of course.
    Reminds me of a time back when my sister first started driving. Well, I say "first," but it was her 2nd vehicle, so I imagine she was at least 18, which would make me about 15.
    Anyway, she came home from school and told me her car is making a funny noise. I go out and ask her to pull it in the garage. Well, she pulls it in as it is making the very loud and fast ticking noise from the engine. I yelled at her very quickly and loudly to SHUT IT OFF! SHUT IT OFF!
    She had run it nearly dry of oil! Surprisingly, there was no damage, and she got a lesson on one particular "bad noise" she should be on the lookout for.
    The M3 ad fails strictly for the name of the dealer ... "We Be Autos"?? Seriously? That's what you named your company?
    66 Plymouth -- distributor in rear, ergo a 318 would be my guess.
    1990 Corvette convertible -- price is pretty much high retail for an automatic with over 100K on it. If it were a pristine, low miles stickshift, well maybe there's a bit more money in it.
    1988 Corsica -- that's about what it's worth, yeah. $1,000 bucks.
    1972 Chevelle SS -- that's what it should sell for WITH decent paint on it. (aka "clean driver"). Nobody wants a '72 Chevelle anyway.
    My daughter did the oil trick - unfortunately she was in the left lane of the parkway in Monmouth County when it seized. She defied death twice on that. Once when she got to a shoulder in one piece and again when I didn't kill her....
    Not just We Be Autos, but We Be Autos on Lawn Guyland. It's perfect.
    I see the M3 convertible as the poser model. It has weight gain and no benefit but the ability to be seen.
    Civic should be a bargain for someone.
    Yeah, that's the old 318 "wideblock", as it was known. It was a poly-head engine dating back to 1955. It has kind of a massive look to it, so it often gets mistaken for a big-block engine. The more common 318 was the wedge, which was based on the 273 block. It looks considerably smaller, although I think the wedge only weighs about 50-60 lb less. I forget what year the 318 wedge came out now. Either 1967 or 1968.
    A good engine, but in a car of that size, certainly not a neck-snapper.
    when parents stop kids from blowing your college fund.
    link title
    turbo M3 -- yeah, might as well show those stupid BMW engineers that you know way more than they do. Now you've got a car that is almost sale-proof unless you take a big hit. Someone has to pay for that turbo kit and the ugly wheels, and it's not going to be the next buyer.
    unless he finds another kid who's willing to blow his college fund to buy it.
    42lb injectors
    Holy cow, man! That's 250 lbs added to the curb weight!
    ;b
  • oregonboyoregonboy Member Posts: 1,650
    I noticed that the kid trying to sell the modded M3 neglected to mention what year it was or how many miles it had... never a good sign.
    He did mention the miles on the "rebuilt" engine... again not a very good sign. :(
    The engine has 62k so the car itself must have a ton of miles
    But they're EASY miles!
    -Mathias
    http://lansing.craigslist.org/cto/1039564439.html
    I'm thinking the price is borderline high even with a perfect body.
    It must be something in the water.
    -Mathias
    Borderline high? With 152k miles, I don't think it's worth fixing if it were free.
    Parts car. :sick:
    And he claims $700 in damage. Good luck.
    Not a project....
    "New" W126
    I'd say it's worth it to the right person.
    2001 Audi A4: Damage is about $6,000 from what I can see.
    CRUSHER. More teapots for Turkey. Current value? About $300--$500.
    Brand New 1983 Benz: Brand new but what would you do with it? Drive it? Then you lose $9,000 immediately in depreciation. "Show" it? Where? The 80s 4-door Concours? don't think so....
    Nice old car but c'mon---get real on the price. Okay $7,500 is all the money in the world for it.
    I would love to know where you can get a hood,trunk,rear quarter panel,headlight assembly,tail light assembly and get them painted for $700. Are things that bad in Michigan that they are just giving parts away ?
    $14,212.89 for a new, unregistered 1983 280SE. I'd like to hear the story behind that one.
    Just found a new (to me) Brit car show, "Wheeler Dealers", they spent 2 episodes getting a W123 230E for 400 quid, spent 600 fixing it up, sold it for 1500 pounds. Just had to replace a fender ('wing', sorry) with a cheap repro, new steering box and windshield, and that was about it. Of course they don't count the hours of work in the fixup cost. Looked like a good buy for $3000.
    And those are just the things that you can see that it needs! (I suspect that it also needs front and rear bumper covers, front grill, and maybe the L front fender.)
    Yeah I wouldn't drive that W126. I'd keep it detailed to assembly line cleanliness, and take it to local MB club events. The general car nut won't care about it, but MB people have a lot of respect for that series. They are only new once, and the 126 is considered by many to be the zenith of what MB was really all about.
    Also notice while moderately equipped for Euro/UK spec, it is optioned below anything sold here.
    What network airs that show?
    With the pound depreciating as Europe experiences a financial disaster and future almost as bad as ours (or maybe worse), 1500 GBP is now under $2200. Those cars are pretty sturdy, it could be a good runaround car for that money.
    Maybe an eccentric dealer or some weird estate situation. Old low mileage cars seem to pop up now and then, some survive better than others.
