Visitor Agreement.
May not matter now but my original reply to Andre was the fact that in 1979, a $10,000 Corvette ran as quick from zero to 60 as a $20K Porsche or a $40K Mercedes. Proof of how difficult it was for any car maker to build performance and comply with emission standards back then. Better engine control technology was still many years away.
My later reply mocking the Porsche 911 Inertia Denial fan club was even delivered with a "pblt" emoticon. :P
A 79 Corvette is a generally unloved thing, really. You can't hardly give away a '79 Corvette these days if it needed any work. It would not be my candidate for a Corvette restoration. The 78=83 Porsche 911SC was a great car, All turbos were designated 930s, and, as you say, pretty deadly, but the SC n/a was a fab handling car. They are not tail-happy.
A 930 Turbo is probably worth 4Xs what a '79 Vette is and is a fantastic car to drive....IF you respect it. But you never want to lift the gas in a turn---no, no.
Most people I think who harp on the 911s handling never owned one for any appreciable time I suspect. Eveyone says the same about the 300SL, but most people who are lucky to own one never sell it.
This evening was the first time in about 3 1/2 months that I started the sucker up and moved it out of the garage. The power steering pump started going bad, and the mechanic I had been dealing with wanted too much $ to replace it, so I had been considering just cutting my losses and unloading the car. But this week, I found a guy, a friend of a friend, who said he could do it for $300. He's very local, and came by this evening to look at the car.
I guess that's one problem when dealing with cars this cheap. Just about any little issue can total them. And, if it's sort of a guilty pleasure, which is my case, rather than everyday transportation I have to depend on, so sometimes it's really a hard call as to whether to keep it or not.
Here's a pic of it posing with the LeMans and the other NY'er...
They were all very well behaved. All three of them started up and moved under their own power!
Here's one more shot of the old beast...
Wow, I just realized, my 10th anniversary with this car just came up! IIRC, I brought it home on October 20, 2001. I remember it was a Saturday. I guess, all things considered, it hasn't aged too badly, over these 10 years.
No, that's the placard from the Mopar Nationals at Carlisle, which, incidentally, was where the power steering pump started to go south.
Thanks. The tires/wheels are my next project. A couple years ago, I bought some aluminum Cordoba/Mirada wheels,
that look like this.
Eventually, I'll get new tires mounted on them, and put them on the car.
If I lived a few thousand miles closer, I'd help you indulge your "guilty pleasure" for free! I like to turn wrenches now and again.
Any time! Come on over! :shades: Actually, I wonder how hard a power steering pump really is to replace? Lemko mentioned doing one once, and said that the big hassle was getting the pulley off the old pump and putting it on the new one. I had thought about trying to get a used one from the junkyard, presuming they'd leave the pulley on it when they sold it.
I wonder if there's anything special you have to do with regards to the high pressure/low pressure sides, or if you just put the fluid in and it sort of bleeds itself out?
I just had my 1989 Brougham to my local mechanic for inspection/emmissions, oil change, and coolant flush/fill yesterday. Good thing I took it yesterday as the weather is lousy this morning whereas it was beautiful yesterday. The car, once again, passed with flying colors. I drove it back to Philly from my Grandmom's place upstate on Sunday and the car got phenomenal fuel economy. I thought the gas gauge was broken, but I filled up the car yesterday and it really did only use about 5 gallons for the 106 mile trip! I swear it gets better fuel economy than my 2005 Grand Marquis!
Straight highway the older General Motors cars did really well. The OD gear is so tall that at 65-70 the engine is just loping along at a really low RPM. That is great for FE, but they do tend to downshift on mild hills.
Speaking of FE, my new LaCrosse is not doing so hot. First tank was around 17 and the second tank is hanging on at 15.8. I think it will get a little better after break in, but, my previous cars did better being driven in the same manner (and they were similar in size/power too).
Can't be any harder than removing an alternator, can it? Biggest problem I would see is breaking loose the hoses that run from the pump to the steering unit (recirculating ball on that car?), and even that should be fairly easy if you enough room to work.
If the pulley is that hard to remove, I think they would leave it on the pump. How many people are going to want just the pulley?
As for bleeding the system, I have not experienced any problems with them when simply removing and reinstalling the lines, then topping off the pump. After running it, you may need to re-top the fluid level.
Oh, and Andre, those wheels are going to look great on that car!
And, sure enough, it didn't. I'm pretty sure by that time, they were only putting smog pumps on California and high-altitude cars. And the 360-2bbl is one of the engines that was actually banned from CA.
While I was under the hood, I looked at the pump. Honestly, it doesn't look like that big of a deal. It looks like it has two bolts holding it in place, the one it pivots on and the one that adjusts it. The low pressure hose is just held in place by a little clamp you can take off with pliers, and the high-pressure hose narrows down to a metal tube that screws into the back of the pump, and looks like it might take a 9/16" or so wrench to loosen it.
My guess is the biggest issue would be that high pressure hose, if it's rusted on and breaks. I probably could do it myself if I could muster up the ambition!
If you do try it, soak all the bolts/fittings with PB Blaster or Liquid Wrench to break up some of the corrosion.
What happened with the V6 Altima?
I'm tempted, but at this point, I already promised this friend of a friend he could do it, and he gave me what seems like a fairly reasonable price. Plus, he's already ordered the part!
That was just wishful thinking, although not totally ruled out. I'm trying to hold off buying a new(er) car for as long as possible. Eventually though, my pickup is going to probably have to be retired, and at that point I was planning on selling the Park Ave to my roommate (he's been using my truck) and then I'd get something new when that time comes.
If I do buy a new car though, I'm going to get something in a color that I like, unless it's a really killer deal. And those white, gray, and silver Altimas just weren't exciting me that much.
I hear ya .. with 2 silver and 1 gray vehicle in my household, I'm hoping my next car will be in a more vibrant color.
However, $21K for a V6 Altima is certainly the "killer deal" you are looking for.
The ION will pass 60K either today or tomorrow.
I don't blame you there. I am frankly tired of the lack of color choices today, so I bit the bullet and bought black. I always stayed away because its hard to keep clean, but the heck with it. I've had enough white cars, and silver or gold just doesn't do it for me.
I was surprised to find that people are saying they love the white paint! It seems especially popular with some of the ladies in my life. Bizarre. I think of white as a non-color and it would neve rbe my first choice. But you never know.
On another note. I think those Cordoba/Mirada wheels are some of the best-lookiing ones Detroit ever produced.
First, it's a 1965 and second who would put that much work to restore a straight 6 sedan? If it was a big block 4 speed 2 door, it still might not be worth restoring. What is he warrantying? That the plants will keep growing through the floor?
Wait, boat->artificial reef! That's what that car is good for.
Anyway, I'm satisfied. And not as damaged in the wallet. My regular mechanic estimated at least $500 to fix it!
Oh, and at some point I still want to get some new tires mounted on those aluminum Mirada wheels, and get them on the car.
Yep - my dad's '63 Polara with a 383 4bbl had smaller tires than my 198cid Duster. You had to work to NOT light them off!
'Vert
Great Winter Beater
Gold
Catalina
Needs Resto
I'd put my money on that Buick residing in Lakewood.
'Vert: I can practically see it shaking and twisting in hte pictures.
Beater: Sure, why not.
TA: Gold chains and hairy chest required for test drive.
Catalina: looks nice and fair price.
912: run far, far away. $500 at the absolute most to part out. The subframe is most likely swiss cheese and you are instantly so far underwater that daylight is just a speck.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150694857553+&view- item=
That could be a nice, fun project car for you - it looks good enough
Personally I think these cars are dogs---clumsy, slow, heavy..about as much fun as driving a Prius through a school zone at 25 mph.
This one has the typical biodegradable seats that have gone south--and in this case, the manual transmission was probably not the best choice, as the M41 feels like a truck tranny and then you have a very finicky and expensive overdrive unit to deal with.
Not that the original Borg Warner slush-box was any better, but seems to me an automatic suits the car more.
I think the car is already fully priced at $2700. They are hard to get parts for, too.
This was Volvo's attempt to compete with Mercedes in the late 60s, early 70s.
ER......no.
Anyway, just wanted to post that in case my comments before had scared anyone away from Hagerty. Apparently, I was mislead by other sources.
As new
